Question about Dewalt 18v 18 Volt 1/2" Compact Battery Drill Dc759
Removing fewalt battery
Very difficult removal
    Genius:
  • 1,669 Answers
The next time you get it off, spray the plastic slide and receiver with WD 40 or CRC spray.
Posted on Jan 13, 2013
Replace ignition switch on 99 jeep wrangler
The ignition key must be in the key cylinder for cylinder removal. The key cylinder must be removed first before removing ignition switch.REMOVAL 1. Disconnect negative battery cable at battery. 2. If equipped with an automatic transmission, place shifter in PARK position. 3. Rotate key to ON position.4. A release tang is located on bottom of key cylinder.5. Position a small screwdriver or pin punch into tang access hole on bottom of steering column lower cover.INSTALLATION 1. If equipped with an automatic transmission, place shifter in PARK position. 2. Position key cylinder into steering column as it would normally be in the ON position. 3. Press key cylinder into column until it snaps into position. 4. Check mechanical operation of switch. Automatic Transmission: Be sure transmission lever is locked in PARK position after key removal. If key is difficult to rotate or is difficult to remove, the shift lever-to-steering column cable may be out of adjustment or defective. If key can be removed, release lever mechanism may be defective. Release lever mechanism is not serviced separately. If repair is necessary, the steering column must be replaced. 5. Connect negative cable to battery. 6. Check electrical operation of switch. ab7076e7-9719-44a3-b66a-8584c6b2a3c1.jpg bfaa43e6-23a3-4771-9d95-55c2c3bf0a78.jpg
Apr 08, 2014 | 1999 Jeep Wrangler
How To Remove Battery
Remove cables form battery. Look for a bolt that holds the holddown bracket and remove. It may be difficult to access without socket extension. lift battery out and replace reversing the operation.
Nov 05, 2013 | Cars & Trucks
Replacing alternator
Hard to say.
Depending on which engine you have, the alternator may be difficult to get to. You would need to remove the belt, disconnect the battery, and remove the mounting bolts.
May 30, 2013 | 2004 Oldsmobile Alero
How do I remove old batteries from Escali BFBW200 scales. The batteries are hard to remove.
Use a pen to push the batteries down towards the flexible metal contact tabs and continue to push the pen underneath the batteries. The batteries should pop out.
Any further questions call us at 1-800-467-6408.
-Noah Harber, Escali Scales
Oct 08, 2012 | Escali BFBW200 Body Fat/Water Bath Scale
Peugeot 206 removal
Not a difficult job on this car try doing a renault twingo or modus ,what about the mercedes A class thing now thats a job and half ,Disconnect the battery and take your time its not a difficult job .
Feb 04, 2012 | Cars & Trucks
How do you remove the battery from a 1992 corvette
Access is by removal of the exterior side panel. There are two 10mm bolts on top and bottom of the panel, the top needs to be removed, the bottom just loosened. There are 3 Torx screws inside the wheel well, difficult to remove with the tire in place unless you turn the steering to a stop, or use a Torx bit in a wrench. Bolt securing the battery on its base facing the driver seat needs to be removed.
Feb 28, 2011 | 1992 Chevrolet Corvette
How can remove guard protection in computer?
I am not clear what protection you want to remove but if it is the password for accessing the bios then you need to remove the main battery and the CMOS battery to clear the bios settings. The main battery is easy to remove from the bottom of the laptop but locate the CMOS battery is more difficult and can require dismantling the laptop.
Feb 24, 2011 | Computers & Internet
How do you remove the starter on a 6.0 chevy engine?
Not too difficult. Remove negative battery cable. remove battery cable from big stud on starter selonoid. Remove small wit from "s" terminal on starter selonoid. Remove starter retaining bolts, and lower starter down.
Apr 07, 2010 | 2003 Chevrolet Suburban 2500
How difficult is it to replace a heater-A/C fan
Disconnect the negative battery cable from the battery. Remove the the strut tower brace. Disconnect and position the ignition control module assembly out of the way. Remove the solenoid purge valve. Remove the inertial plate screws from the blower motor. Remove the inertial plate from the blower motor. Disconnect the connector from the blower motor. Remove the blower motor screws and remove the blower motor. The brake rotors should clean up on their own after using the brakes a few times.
Mar 16, 2010 | 1999 Cadillac Eldorado
How do I change the alternator on a 1991 honda prelude...is it easy to do myself or should I take to a mechanic if its location is difficult to reach?
it shouldn't be to difficult to do if it is accessible. Disconnect the battery first, then loosen and remove belt, remove wires and plug from alternator, then remove connecting bolts to the alternator, just go back in reverse order. Hope this helps!
Dec 15, 2008 | 1991 Honda Prelude
Dewalt 18v 18 Volt 1/2" Compact Battery Drill Dc759 Logo
29 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
