Question about Samsung Computers & Internet
Power cannot be turn on..even if the cord are the one that is used.
    Problem Solver:
  • 6 Answers
My solution would have to be either check with your computer co. or just check how you have it set up check if wires are missing or there unplugged
Posted on Jan 14, 2013
Advent t1600 wont start, it used to start with the mains plugged in was told it was the battery but wont even power up in mains mode now
First try using a different ac adapter/power cord.If after trying that it won't power up it only leaves the power board where the power button is located may be bad or the power jack where the ac adapter/power cord plugs into the laptop may be bad.Alot of the time when the ac adapter/power cord gets weak or stops working at all will cause it to not charge or not turn on even plugged in.
Oct 27, 2011 | Advent Netbook
Hello, I have a problem with my eee 100H5 netbook. I was using it connected to the power outlet, when it randomly shut off. It cannot be restarted and is unresponsive to the power cord, meaning that the...
Unplug the computer and take out the battery.
Hold the power button for ten seconds.
Leave the battery out and plug in the power cord.
Press the power button.
If the computer turns on, put the battery and everything should now work.
This has solved every "laptop not turning on problem" for me and my friends.
sublimedjg
Jun 23, 2011 | ASUS Eee PC 1000HE Netbook
My monitor won't even turn on....do I need a new power cord??
try new power cord, or even take out the pc power cord and try that.
or the kettle lead?
Oct 16, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
Toshiba satellite laptop will not power on if you plug in the power cord.even you take off the battery. but it will turn on if on battery power. if its runnung already it freezes if you plug in the power...
I would suspect that either your power cord or power adapter is defective.
Try testing using a new power cord/adapter & see if this fixes the problem.
Another possibility might be a loose or defective power connector in the laptop. Check the connector where you plug the power cord. It might need to be re-soldered or replaced.
Nov 07, 2009 | Computers & Internet
Tv did not turn on
Look at the power supply to see if anyhting burnt, fuse, bad capacitors. I doubt that the power cord is bad, the same size fuse should be used as the original one.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 04, 2009 | Goodmans GTVL32W27HDF 32 in. LCD TV
Will not turn on at all
Hi, if already to try with another AC Adapter, and the equipment even not turn on, it wants to say that the damage comes from the System Board, which must replace
Jan 08, 2009 | Toshiba Satellite U305-S5097 Notebook
Battery will not charge nor is able to use AC power to stay on.
Hi everyone it seems to me that the DC connector is loose inside your laptops,try wiggling it about gently at the charger to laptop cord nearer to the dc socket to verify this.Only solution is resolder or new dc socket.
Dec 27, 2008 | Acer Aspire 3680 Laptop
Hp photosmart c4580 won't print
Your problem indicates that your printer is not getting the power supply .
  • Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
  • If the power cord is not damaged, plug the power cord into a different electrical outlet without using a surge protector. The product power light should turn on.
  • If the product power light does not turn on, the power cord should be replaced.
Dec 09, 2008 | Office Equipment & Supplies
Dell latitude d600 doesn't turn on
The test Dell advises to narrow down this issue is to remove the battery, hard drive, ram, and optical drive.  Next plug in the a/c power cord and you should get some LED's coming on. If not it points to the motherboard.
Aug 15, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
13 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
