Question about Craftsman Snow Blower / Snowblower Bottom Cover :
What kind of oil is in the hydrostatic drive in craftsman snowblower?And how much?
It has leaked oil from drive and id like to drain and top it up.
  • Dan Jan 13, 2013
    It is a sealed unit, there isn't a fill hole
    Genius:
  • 1,669 Answers
5W 30 and fill it just below the bottom of the fill hole.
Posted on Jan 13, 2013
  • Antonio Almeida Mar 05, 2016
    Where is the fill hole? can you show with a picture or a graphic the transmission hydro. Do I have to open the cover bottom
Oil leak craftsman snowblower
Only a few places to leak oil from, Main crankshaft oil seal, Oil fill cap, valve cover gaskets, Cracked engine block, Engine Block gasket (some blocks split apart)
Mar 08, 2015 | Cars & Trucks
Craftsman Snowblower Won't Start
If you did not put gas stabilizer in your fuel tank when you stored your machine the gas will turn into varnish. Try draining the gas and put new gas and try to start it. Good luck
Jan 04, 2014 | Craftsman Garden Tractor Snowblower...
Craftsman track snowblower
it depends on your drive system it its a hydrostatic tranny no it will not unless the engine is running and the lever is engaged
Dec 20, 2013 | Garden
Hi, I have a Craftsman Garden Tractor 18HP Twin, model mo. 917.255919 that has a transaxle leak. The transaxle takes about 5 quarts of SAE 30 Motor Oil. I took the transaxle apart last summer to fix a gear...
I would drain transaxel out and refill with 80w90 gear oil. I think the 30 w is way to thin. You can try some lucas trasmisson sealer and conditioner and see if that helps.
If you have to remove the transaxel I would use hi-temp silicon sealer to seal all seams and arou
nd axel shafts. I have a six year old craftsman garden tractor 18 h.p. twin mod.number 917.2722751 and I'm nearly sure it uses the same transaxel so if you do have to get into the transaxel the oil seal part number is 788088A.I can not find the suggested quanity of oil but I just fill to top thru oil fill plug on top front of transaxel.Hope this helps you. Thanks
Jun 22, 2011 | Garden
While using my Craftmas 17,5 hp lawn tractor with a snowblower attachment, the hydrostatic drive seems to loose power, especially when it working hard and after its been in use for a while. I don't think...
My name is Dane and I'm going to help you with your problem. First, I believe those craftsman units are sealed and there's no way to actually check the hydrostatic oil level. So the first thing to do is make sure that you don'thave any leaks around the transmission assembly. If it looks clean and oil free, I would venture to say that it is more of a 90% chance that your drive belt is the problem, however it isn't from icing up, but rather from the heat of the extra work from the weight of the snowblower, causing it to slip. The belt isn't all that expensive and before I would get excited and start worrying about transmission failure, I would just replace the belt first, and rule it out. Make sure all your pulleys and tensioners don't have any loose hardware, and look alligned.
I think you'll fix the problem though just by the belt replacement. I hope I've helped. Thank you! Dane
Dec 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How would I drain the oil from my craftsman 8.5 26 snowblower, model 536.886190
There should be a oil drain at the bottom of the motor.it should be a plug at the base of motor or below the oil fill.
Nov 19, 2010 | Garden
Mower won't move in forward or reverse, it just makes a loud wining noise. I've had this happen before but I usually can get it moving.
If this is a hydrostatic drive. Check oil level in transmission. If you have been running it low on oil, it may be too late for the hydrostatic drive unit. If it has a drain plug, drain it and change the oil.
Jul 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 15.5 hp 42'' what kind of fluid goes in the hydrostatic transaxle if i need to change it
It takes 15w-50 or 20w-50 synthetic motor oil.Do not use hydrostatic fluid, it is too thin. Amsoil, Mobil-1, Purple Power or Lucas are four of the most popular brands. You have to suction it out from the plug on top of the transaxle and refill it there also to within 1.5 inch from the top,do not overfill,air is needed in top for expansion.
Aug 15, 2009 | Craftsman Garden
Hydrostatic drive squeels and stops pulling when hot
I had a similar thing go wrong. Even though the hydrostatic drives are designed so that the fluid doesn't need to be changed, If it is a hydrostatic transaxle check to see if it is leaking,if it is then there really is no repair to transaxle. If it isn't leaking then It sounds like the oil in transaxle is worn.The transaxle is supposed to be a sealed unit requiring no service but over time the oil will get dirty enough to cause problems like you are describing.Remove the back hitch plate and look at the transaxle it will have a rubber vent hose or a 1/4 Allen wrench fitting on top. You will need to purchase suction bulb and use it to remove as much oil from transaxle as possible. Warm the transaxle up first by running it around,then suction the oil out.Refill with a good synthetic motor oil 15w-50 or 20w-50 like Amsoil or Mobil 1.Do not use transmission fluid or hydraulic fluid. When adding the new oil back fill it to within 1.5 in from the top,be sure to allow this amount of air space in top of transaxle for expansion
Aug 13, 2009 | Mtd Garden
Craftsman Snow Blower / Snowblower Bottom Cover : Logo
513 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
