Question about Zoom Q3hd Camcorder
Formatting card When I put in a new 32gb card, the camera asked "format card". I hit "yes", but after about 1 minute filming at low res, it said "Card full"!!! What have I done wrong?
Put films on my 32 GB sd card
Use Windows Explorer (or equivalent) to copy the movie files from your hard drive to the SD card
Jul 10, 2016 | Cameras
The camera keeps showing card error and unplug card. also shows format-yes-no. What is this?
Hi, it sounds like the card has an error and will not work properly if you have another card and you put it in and it works ok then that proves the first card had an error If you put the first card in and it asked you to format it what it does is it makes the card ready for use in your camera and if there is anything on the card and it formats it it will erase everything on the card. When installing a new card on a camera it will always want to format the new card and you let the unit format the card. In the end if you put a new card in and go through the format stage and the camera still comes up with error you have a fault with your camera.
Feb 12, 2016 | Cameras
Cant get past 'card not initialized', even though I've used it in this Fuji finepix jx500 camera before. it erased pics when i hit format, but that's all.
Make sure that you do a format in your computer before you reinstall your card,check to see which format you require some want fat 32 others may require a different format.
Apr 19, 2014 | Fuji Film FinePix JX500 14 Megapixel...
I have a 32gb memory card that when put on my laptop says no pictures are there and when you put it back in the camera it says no pics on card but when you go to see how much gig is left there is 3 gig of...
what format is the sd card in ? most common is the sd card its self I have had loads that have just packed in and just keep asking for it to be re formatted. also some cameras will take the card and load pic's onto it but its in the wrong format as the cad is in exfat file and not in fat32. some laptops don't read exfat and you need to update so it can read it.
Oct 28, 2013 | PNY P-SDH32G10-EFS2 PROFESSIONAL SERIES...
Samsung digimax 4010 camera has error message.
tis logical that sumsung digimax 401 cannot procees a 2gb memory card, use 1 gb will format ok.
May 11, 2010 | Samsung Digimax 4010 Digital Camera
Memory card error?
Hi, Check if other memory card is working on your camera. This is one way of checking if your memory card if still working or there is an issue wither the camera. Formatting Memory card **you should always format a new memory card or one from which you wish to erase all images and other data. ** Please note that formatting a memory card erases all data, including protected images and other file types. 1. (Set up) Menu [Format]
2. Select [OK] and press FUNC SET button.
Low Level format, recommended by cannon
Select the [Low Level Format] when you think that the recording/reading speed of a memory card has dropped. A low level format may require 2 to 3 minutes with some memory cards.
Apr 12, 2010 | Canon PowerShot A610 Digital Camera
Put new memory card in camera but has formatting problem. When memory card is put in it says the new memory card requires formatting. When I continue it states that formatting will delete everything in...
New batteries first!! Make sure they are "GOOD"
May have a bad or incompatible card.
Will you camera take pictures without a card in it?
If yes, you have a bad or incompatible card.
Try another card
Here is all the information you'll need to solve this:
Read it.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=8814&product=EKN031714
Dec 24, 2009 | Kodak EasyShare Z612 Digital Camera
Olympus xd memory card comupter says format
when I put the xd card in the camera ask to format click on yes reads "card error"
Dec 24, 2008 | Fuji FinePix A340 Digital Camera
Formatting problems
Try formatting the card on a computer than again on the camera. If you don't have success formatting the card with a computer than it is a pretty sure thing that there may be something wrong with the card.
Jan 18, 2008 | Konica Minolta DiMAGE 2300 Digital Camera
Zoom Q3hd Camcorder Logo
19 people viewed this question
Top Zoom Video Cameras Experts
matt
matt
Are you a Zoom Video Camera Expert? Answer questions, earn points and help others
