Question about Century Pool & Spa
How do i winterize my pool pump?
Have inground pool. Have taken water level down and opened up main drain at the pump to reduce the water in the lines. Have I done all I need to do to make sure the pump has been properly winterized?
  • 372 Answers
That should do it, just check for a 2nd drain plug on the pump housing. Depending on make and model the pump will have 1 or 2 drain plugs. Make sure both are out, if applicable. And don't forget to drain your filter and heater and any other components.
Posted on Jan 14, 2013
2 Suggested Answers
  • 990 Answers
SOURCE: i need to drain my inground pool with a heyward
You can try this but you run the chance of loosing the prime and burning up the pump. if the water is below the skimmer your already further than you should be.
What you need to do is get a submercibal pump. You can usually rent one at one of the big home centers, (Home Depot, Lowes...) or a rental yard. This will cost twenty or thirty dollars and that is a lot cheaper than a new pump. Also if your planing on cleaning the pool it will pick it's own prime so you can wash and rinse the pool.
Posted on Mar 21, 2010
Why does pool pump have way more suction than it used to have after 40 yrs?
you can put a ball valve on it and open only 3/4 way or if you have an inground open the main drain and the other skimmer did you upgrade your pump?
Sep 08, 2014 | Pool & Spa
Closing inground pool
Question:
How do I close my pool for the season?
by Osko Pool n Spa Information
By following the provided instructions, you will be able to professionally close your pool for the winter season. Additionally, you will protect it from winters abuse and make opening it next season...simple.
Required Tools
a) Standard Screw Driver
b) Phillips Screw Driver
c) Ratchet Set
e) Plumber Pliers
f) Sump Pump
g) Extension Cord
h) Garden Hose
i) Five Gallon Bucket
j) Air Pump or Shop Vac
k) Pool Vac & Accessories
Required Chemicals
a) Pool Shock
b) Algecide
c) Chlorinating Tablets
Required Accessories
a) Winter Cover
b) Pool Pillows or Inner-tubes
c) Chlorine Float Dispenser
d) Water Bags (for ingrounds only)
Step One - Debris & Chemicals
Remove any debris from pool water by use of a leaf rake attachment.
Add the appropriate amount of shock treatment to the pool water, as prescribed on the packaging.
Add the appropriate amount of algecide to the pool water, as prescribed on the packaging.
Run your filter for the appropriate time to circulate all water once.
(see your filter documentation for your size pool)
Install your floating Dispenser and winterizing tablets.
Step Two - Vacuum & Water Level
Vacuum your pool while setting your filter to the "back wash" or "waste" setting.
(this will help lower your water level)
After vacuuming, install the sump pump and drain pool to about 6 inches below your thru-the-wall skimmer.
Step Three - Parts Dissassembly & Cleaning
Disconnect all ladders, filter systems, hoses, solar reels and/or other accessories.
Using standard household cleansers, thoroughly clean all ladders, solar reels and/or other accessories.
Dissassemble filtration system.
Remove sand, cartridge or DE powder from your filtration tank.
Thoroughly clean all filter system parts.
Allow all items to dry.
Store all items in an area that will not be subject to freezing temperatures.
Step Four - Pillow & Cover Installation
Inflate all pool pillows or inner-tubes.
Install one pillow for every 15' of linear water surface.
(example: a 15' x 30' would require at least two pillows)
Tie pillows to pool area via nylon rope and place equally with respects to pool walls and each other.
(this is extremely important! This prevents freeze damage)
Install winter cover as prescribed by the covers manufacturer.
Step Five - Winter Tips
During the winter months, remove any excess snow from the winter cover.
(If you have a solid cover, this will prevent excessive weight form tearing you cover)
(If you have a mesh cover, this will prevent excessive water build up)
Hey, Your Finished! Congratulations, you just saved money while doing a professional job
Nov 11, 2013 | Hayward SAND FILTER, PRO SERIES
Spa Drains Down to Pool Level
install check vales - this will stop the water from leveling off between the pool and the spa
May 22, 2012 | Pool & Spa
How do you winterize a inground pool heater? model# H200ed2 serial# 21130507102557001
Drain it using the drain valve on the bottom-side of the inlet/outlet header; make sure the heater sits level or slightly tilted down on the header side. You also need to drain the water tube that feeds the pressure switch inside the heater cabinet. Turn off the gas and power off the circuit and you are done. If you cover it DO SO LOOSLY! Wrapping it tightly and not allowing air to flow thru will lead to rapid rusting of all the sheet metal.
John
Sep 19, 2011 | Hayward H Series Pool & Spa Heater 400k...
I have 2 inch PVC system for my pump and filter. Fafco inground system has 1.5 inch piping. Where is the best way to reduce 2 inch pipe to 1.5 inch (at the diverting valve or at the panel)? Another...
Honestly, I think you are over thinking both your problems. Reduce to 1.5 inch pipe as close to the ground as possible. It is more work for your pump to push water up a 2" pipe then a 1.5" pipe, but it will do either without any real problem.
As far as mounting your panels, as long as they are above the water level of the pool the water is going to drain out of them just fine. You can slope them slightly, but you don't need to.
Apr 16, 2011 | Fafco Inground Deluxe Solar Heating System...
First year with my new Hayward H 250fd heater. Closing pool this weekend and live in Michigan so you understand our winters. What do I have to do other than opening the drain plug if anything.
Other than the drain you'll need to remove the pressure switch from its feeder tube and leave it hanging by its wires for the winter. Be sure the heater is level or tilted towards the header to allow all the water to drain out. More than a few people have lost a heat exchanger to freeze damage after draining it because the heater wasn't level and water remained in the low end of the tubes.
John
Sep 08, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
I need to drain my inground pool with a heyward pump the water level is down just past the skimmer, do I need to close a valve so the pool will continue to drain from the main drain in the deep end? or...
Mar 21, 2010 | Pool & Spa
How do you winterize?
pull the three (or so) drain plugs in your heater ... use a shop vac (without the filter in it) to blow and then **** out any remaining water.
hopefully, your pressure and suction pipes lead away and down from the boiler. Make sure you **** out those pipes as well.
You know how to drain your filter(s) and pumps ... right?
I hope this helps you
a
Oct 05, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
De filter pressure too high water is cloudy
backwash the filter from main drain until sight glass is clear-this will reduce filter pressure. After backwashing return gate valve to filter position, then filter from main drain only. check water chemistry. add a clarifier to water
Jul 28, 2009 | Pentair 3/4HP Pinnacle High Performance...
My pool pump won't prime
If the pump is above the pool water level the it is unlikly that the tank will fill completely with valves open (which is ok).Most pumps are self priming and will pick up a prime with water level below suction inlet on strainer. Try starting on main drain again and slowly open skimmer line. Did you remove water from skimmer line and winterize(if in cold weather climate)during closing?.I know this sounds stupid, but make sure water level in pool is well into skimmer. If air situation remains after scspriggs' and these thoughts then prepare for a pressure test on skimmer line to determine location of leakage.
Apr 21, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Pool & Spa Logo
56 people viewed this question
Top Century Pool & Spa Experts
Jay Finke
Jay Finke
Lawrence Oravetz
old fart58
Are you a Century Pool and Spa Expert? Answer questions, earn points and help others
