Question about Samsung Infuse 4G Smartphone
My phone ssignal just stopped working and it wont work anywhere
It wont work anywhere cause the signal .... the signal stopped working and wont work
    Master:
  • Samsung Master
  • 520 Answers
Hello ::::
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Posted on Jan 14, 2013
My signal lights in my dash both light up when i apply the breaks and only works when i let go of the breaks
Usually this is a short in one of the sockets that holds the bulb, your brake lights are back feeding power causing your turn indicators to glow on dash when you hit the brakes and will stop the turn signal from flashing when you step on the brake pedal also. Start with sockets on rear and look for any shorted or blackened socket ends.
Jan 20, 2014 | 2000 Toyota Avalon
Harley wont srart.turn signals wont work
A lot more information would save me from writing you a VERY long multipage description of everything that might cause a starter not to work properly or the bike not to fire or etc.and similarly with signals not working like when did they stop working, same time as no start condition or separately etc. This lack of information is likely why no one has responded to your query.
Sep 14, 2012 | 2004 Harley Davidson FLHRCI Road King...
Speedometer not working
Problems arise when there is trouble anywhere in the above mentioned functioning process. The most common ones are problems in the speed signal sensor, as a result of which the speedometer stops working. If you notice problems in gear transmission or find the 'check engine' light on, it is because of a faulty speed signal sensor. In case of your speedometer using the 'eddy current' technology, there could be a trouble with the connecting cable which causes this problem. Ticking noises are a sign of this problem. In either case, you will need to replace the cable or the speed sensors to solve your problem.
Jun 11, 2012 | 1999 Chrysler Sebring
My turn signals stopped working suddenly on my 1992 ford probe lx. Prior right side was blinking faster. Changed signal switch next to steering column changed turn sinal/hazzard flasher by the clutch...
If this is not working on the right side and is OK on the left side then one of the indicator lamps on the right side has blown out. The reduced load on the right hand indicators causes the flasher can to flash faster.
Try turning on the hazard switch then walk around your car to see which lamp has blown out.
Feb 24, 2012 | 1992 Ford Probe
No service anywhere i go
This may be due to the signal IC or antenna circuit. It can be replaced with minimum cost so give it to a known service man. If some one says that it cant be repaired dont believe them it can be done but little tricky task thats y most of the service person wont commit to it. Have a nice day!!
Aug 22, 2009 | Samsung Propel A767 Cell Phone
Phone does not get a signal anywhere.
ya ur guss is rite...might be antanna problemm...still i suggest u to restart ur phone without sim once...n again switch off and again switch it with sim card...
if u had ur phone in water contact??if so then plz contact the sony service center @ the earliest..
dont try to dismantle ur phone...just show to service center...
ne other prob's do tell me..N plz do rate me
cya
Apr 15, 2008 | Sony Ericsson Walkman W810i Cellular Phone
No Signal
Your brother might have selected offline mode on ur handset and u change it to norrmal mode,, and selected network manualy then it will work,
Sep 06, 2007 | Nokia 7373 Cellular Phone
Samsung Infuse 4G Smartphone Logo
41 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
