Question about Sanyo Televison & Video
I have my Sanyo VCR connedted to my new flat screen TV but I need to get the VCR to chanel L1 it only goes from 01 - 125
Can I get L1 channel on this VCR to watch a tape on my TV the channels go from 01-125
  • lutherl
    lutherl Jan 16, 2013
    Thanks for the help I will try it.
  • Sanyo Master
  • 5,487 Answers
You can't tune a analoge VCR on a TV that is digital. If the TV has a scart socket then pressing the AV button on the TV remote should show the playback. Please not certain TV models will have different indications of "AV" buttons. Check the user guide of your TV. If you only have one scart socket and it's being used for another device, you can get a Scart Switching Box see below from places like Amazon.
I have my Sanyo VCR connedted to my new flat scree - 1_14_2013_12_38_32_pm.jpg
Posted on Jan 14, 2013
  • 1153 Answers
SOURCE: VCR model VHQ 41m
I have not heard of one that doesn't have the selector switch to change to 3 or 4, Could it perhaps be in the front behind a door or just somewhere else?
Posted on Aug 16, 2007
  • 38 Answers
SOURCE: how to connect my (old) vcr to my sony tv
if you connect via SCART lead, then you will need to select your AV channel or channels on your tv.
If its via arial, you will have to tune your tv to find it.
Posted on Mar 04, 2008
mighty thor
  • 51 Answers
SOURCE: had dish network update - can't view vcr tapes
the output of the vcr...
what is it physically wired to?
Posted on Dec 08, 2008
  • 15 Answers
SOURCE: new sanyo hdtv and old vcr...can't get menu to appear on screen
Did you select video input 1 when you installed the vcr?
It should be in your tv's menu.
Posted on Jul 24, 2009
joez47
  • 61 Answers
SOURCE: I can't manually setup the Channels on my Panasonic PV 9451 VCR
In the Menu go to manual channel set-up not auto. When you're in manual set-up change channels until you get to to L-1 and L-2 (should be below Ch 2) and save both to memory. On some TV's the L-1 and L-2 are selected with a separate button labeled "input".
Posted on Aug 29, 2009
I was able to connect a dvd player to old tv with a rf modulator.now is there a way to hook up a vcr on same rf modulator so as not to change connections each time you want to watch the vcr with instead of...
well...the reason its sooo hard is that this modulator is not intended for this use. its used for BIG jobs. you can normally do what you want with a simple rf modulator you buy at walmart or radio shack as it has a cable in and cable out, but
You dont even need a rf modulator.
The VCR can do it for free simply; hook the yellow , white if your vcr has red as well (depending on how old )...BOTH or all Three color to color from VCR(INPUT) to DVD
then use a piece of coax cable from the vcr out to tv.
test vcr by making sure that it work on either channel 3 - or 4 on tv. (leave VCR on)
Then to test your DVD connection first turn DVD player on.;.Then on front of VCR press channel down ON VCR until it says L1 or L2 this is under channel 2 when channel downing.
you should now see the dvd player on screen on either L1 or L2 depending on vcr.
now buy doing this your vcr must be on the L1 (L2) anytime you watch a dvd but when you want to watch a tape you just put it in and press play since TV itself is never changed.
when you want to go back to dvd,...stop tape and should still be right on the L1 or L2 again.
Aug 05, 2011 | Channel Vision E-1200 Video/audio Rf...
I unplugged my Sanyo DVW 7000 DVD/VCR 4 head Hi-Fi system for about a half hour, while we were moving furniture. When I plugged it back in I couldn't get it to work. I can turn it on manually and get the...
I am not sure if you unplugged all the cables from your VCR to your TV, If so double check the hook up. When you unplugged the POWER to the VCR the memory was lost. Try and find the menu or set up on the remote. Again the audio out from the VCR needs to be hooked to the audio in on the TV and the video out from the VCR needs to be hooked up to the video in on the TV. Keep trying !!!
Jul 28, 2010 | Sanyo DVW-7000 DVD Player/VCR
I have a sanyo lcd 32"the problem i have is my dtv chanels go from 6 to 69 theres new chanels coming here i need channel 1 and channel 88 how do i get them help please.
G into the menu function and look for channel search.Usually pretty easy to find .Manual add and auto settings. Use auto if new channels are already operating.Otherwise use manual
Aug 08, 2009 | Sanyo DP32746 32 in. LCD Television
I cant record tv through my vcr.
set the vcr up so that you change the chanels through the vcr,,,check the vcr setup menu
May 16, 2009 | Philips Televison & Video
Hook up analog vcr to hd tv
You must have a converter box for the tv and for the vcr. Set the vcr to receive chanel 3 and set the converter box to the digital chanel you want to record. Put a splitter on the antenae out and route one to the tv converter box and one to the vcr converter box. GOOD TO GO.
Apr 11, 2009 | Sanyo Televison & Video
I have an old sanyo vwm 710 vcr. I have a new hdtv. I can play tapes on the tv if I change the input on the tv. I have selected line 1 on the vcr, but cannot get any channels to come on to record. The...
Not really a solution....RCA customer services (from India, I think), says that there is no way with that VCR because both the front and back (red, yellow,white) ports are input, and the only other jack on the tv is the one for the antenna. Since the digital converter is inside the tv, a splitter would do no good.
I would still have to get either a new VCR with the digital converter in it or get another converter box. An atmosphere of bait and switch is covering this hdtv scheme....
Feb 19, 2009 | Sanyo DVW-6100 DVD Player/VCR
Sanyo dp50747 Plasma HD TV
sanyo recommends using the reset button with cable box on, vcr off and press the reset button 2x, then try pressing channel up button if no message appears on the screen. i have not trid it yet... but good luck
Sep 23, 2008 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
I put the wall cable to the vcr and the cable to the tv to the vcr, and i put the vcr on channel 3 and want to record channel 31, it records channel 3
you state here you put the vcr on chanel 3 but you want to record 31. put the vcr on chanel 31 to record
Aug 01, 2008 | Televison & Video
Tuning Sanyo VCR
Press both channel buttons simultaineously for 3 seconds it will automatically tune your programmes press ok when ok flashes on vcr screen display
Nov 04, 2007 | Sanyo DS27910 27" TV
Televison & Video Logo
79 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
