Question about Konica Minolta magicolor 2500W Laser Printer
ALL NEW TONERS BUT WON'T PRINT GREEN COLORS
I PRINT BUSINESS CARDS WITH GREEN IN THE MIDDLE OF THE CARD BUT IT ( GREEN) FADES. IF I CHANGE THE COLOR ITS OK?
  • 63 Answers
If your asking if changing the tones might work yes it should...
If not try also changing the Fuser unit...
Let me know...
Matt
Posted on Jan 23, 2009
  • Boli Jan 23, 2009
    Let me know...
    Matt
Changed ribbon and it comes out in black & white or faded or if in color all the same color
Goto Printer settings
advanced/
Find where Print in color
is an option. And select it.
Your printer Thinks you have a Black Ribbon in the machine.
Oct 25, 2013 | Datacard Group Cp40 Plus Card Printer...
Dell 2145cn Print is faded in middle of page
Check the transfer belt, also get a air spray can, look for the opening to the laser unit inside unit on top side, spray opening to remove dust or toner deposits. Lastly check fuser, it should have a uniform coating on it, if it looks faded in the corresponding area of fades you will have to change. Hope it helps.
Jun 24, 2013 | Dell 2145cn Multifunction Colour Laser...
Why won't the website www.iambored.co.za load but everything else loads just fine?
Laser Jet 1018 when print fade color out
Hi my name is Robinson from Ethiopia,Addis abeba my printer is laser jet 1018 i need to ask I am buy another cartilage new one and then install in my pc affter install the cartilage toner i see this things
1.when i print fade color out but the cartilage toner is new what is this problem i am guse may be paper quality or weather selection i am ask this one when some other place change the printer print pure with out fade may be guse more u tell me plz if u can now
Thank u!
Jun 25, 2009 | HP LaserJet 1018 Printer
Samsung CLX-2160, keep getting faded toner stripe down page. changed toner numerousof times The same problem occurred for me after only 300 pages. The black color on the all prints is faded out on the...
Everyone will tell you that it's the Imaging Unit - happy to say that's not true. If it was the imaging unit the colors would not come out right either. I bet if you print a test page that all the colors come out fine across the page. It's only the black.
Also - if you replace the black toner cartridge, or reinstall your printer and drivers like some people will tell you - still no results.
The problem is in the black toner cartridge PATH inside the printer. Something has jammed it up a bit. Try taking out the black cartridge and blowing firmly into the small hole at the bottom of the spout that looks to have a sponge inside. Use a straw and make sure your air blown is dry. Then lightly tap the cartridge a few times. Then use the straw and once again blow very firmly inside the receiving path (inside the printer) for the spout on the cartridge. Make sure you are blowing into the spout path at the bottom - not the gear drive path in the middle - as that will not do any good.
Replace the cartridge, warm up and print another black and white page. You should see that the faded out section is gone or diminished in size. If it is not gone, simply repeat the above steps until it is gone. You will see that the faded out strip gets smaller and smaller each time until it's gone. I had to repeat five times, but eventually got it corrected. Now prints like brand new so don't get discouraged.
Loki
May 18, 2009 | Samsung CLX-2160N All-In-One Printer
Red color faded and red color is mis-aligned.
Hi We've been seeing alot of the HP Color Laserjet range of laser printers coming through with a "prints lightly with red" or "red is faded" fault report, we've been able to resolve the problem mostly by cleaning the scanner. Misalignment is normally resolved therafter by calibrating the machine using its calibration function. (if it has one) Wouldnt suggest this gets tried unless one is familiar with stripping and reassembling these machines though. Hope this helps.
Mar 23, 2009 | HP Office Equipment & Supplies
I am printing business cards and I am using thick paper but colors come out dull looking but if I change the paper to PLAIN then the colors come out just perfect, full, vivid and rich but I am afraid that...
Its most likely the paper you are printing on. It sounds like this is an ink printer. The way ink works is that it is absorbed into the paper you are printing on. Some paper pulls the ink too far into the paper causing it to look dull and faded. You need to make sure you are printing on paper that is designed for inkjet printers. There are a lot of companies that make special paper designed for printing your own business cards. I prefer Avery products since they have a guarantee.
Check this link out for some options on InkJet business card options.
http://www.avery.com/avery/en_us/Products/Cards/Business-Cards/_/Ns=Rank%7C1%7C%7CProduct%20Number%7C1
I hope this is solves your issue....Violet
Jan 23, 2009 | Office Equipment & Supplies
Color problem!
If you the image is faded and your toner supply is good, the problem is the developer blades in the imaging unit. It sounds like the magenta blade needs to be cleaned. During the normal use of the printer, there is a buildup of toner that sticks on the developer blade. The developer blade meters the amount of toner that gets to the drum that ultimately makes it to the paper. As the toner buildup increases on the blade, less and less toner that gets to the drum cause the image to fade.
To fix this problem you will need to disassemble the imaging unit and clean the blades or buy a new imaging unit. I have clean my blades and I have a document to show you if you are handy.
Jan 13, 2009 | Samsung CLP 300 Laser Printer
Samsung color fading-light on lft side to dark on rt side
i want to download the driver softwere of samsung clp-300 series vista ultimate supported
Jan 05, 2009 | Samsung CLP 300 Laser Printer
Page is printed but fade
The toner cartridge is faulty. It is possible that when you pulled out the strip that the whole thing didn't come out. Return the cartridge (with a couple of printed sheets to demonstrate printing) and the receipt and you should get a replacement.
Oct 24, 2008 | HP Color LaserJet 2600n Printer
Color toners are empty
Press Green Tick, Right, -> System Setup -> Right, Right, -> Print Quality, Right -> Replace Supplies. Change from stop at out, to override at out. It'll let you print, and you'll get loads more out of your toner before the pages start to fade.
Dan :-)
Sep 30, 2008 | HP Color LaserJet 2600n Printer
Open Questions:
Konica Minolta magicolor  2500W Laser Printer Logo
74 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
