Question about Kenmore HE2 Plus Front Load Washer
My washer stopped in mid cycle, flashing paus and minutes left, intermittently
I pressed start a few times, but it would not continue. I pulled the cord to get the door to unlock, and rearranged the items, then put it on the spin only cycle but it only flashes paus and minutesof cycle. I took some items of clothing out, tried the spin only cycle again, but the machine just flashes paus and minutes left.I removed all clothing , scooped out as much water as possible, tried to run the washer on several different cycles but to no avail. It seems the door will not lock in order for a cycle to commence, it just flashes paus and minutes of cycle.
  • Jack MacMurray Jan 14, 2013
    I already unplugged the machine and let it sit over night and plugged it in again in the morning but it didn't help. Tried to run it on every cycle and it dosesn't work. The door will not lock in order for a cycle to start.
  • Jack MacMurray Jan 15, 2013
    Had to bring a service person in , it was the door lock that wasn't working, going to replace that item and it should be good to go. on the door that wasn't working.
    Genius:
  • 1,669 Answers
It's time to unplug the power and let the electronic panel reset.
Posted on Jan 13, 2013
SOURCE:
My GE GFWS3505LMS font end load washing machine pauses. Have to press start for it to continue. typically happens at 57min. once I press start again it works fine.
try unplugging the unit for a minute to see if it resets it to factory setting.
if not working after that I think but it's hard to diagnose over the internet...it'll be #3 on this site.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/50---/Washer-stops-mid-cycle
hope this helps a little.
Jan 22, 2018 | GE Washing Machines
I pressed the pause button to add a garment to my Whirlpool frontload washer. After doing so, I pressed the hold to start button, but the washer would not restart the cycle.
Switch the power off from the power outlet for a few minutes , then switch on and reset the wash cycle . Front loaders are not designed to add clothes mid wash.
Mar 18, 2015 | Whirlpool Washing Machines
GE WBSE3120 Washer stops mid cycle
if it makes a grinding sound when in spin this is the tub seals or bearing and basically you'll have to replace the washer.very common with this ge washer,not one of ge's best product,also why it stops mid cycle could be anything,this washer has a computer board biult on top of the motor that also failed,if your having all these issues i think that washer sold for like 500 dollars,it would cost more just to repair it,i wouldn't put 5 cents into it,do yourself a favor and get a new washer.
Dec 04, 2017 | GE Washing Machines
My Frigidaire Affinity is brand new. Just did our first load of laundry and mid cycle it stopped and the PAU is lighting up intermittent with the time left. I have tried everything I can think of and it...
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Dec 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool Cabrio wtw6600 stops at rinse and flshing light and sound, then afert pressing pause resum washing
Press STOP/CANCEL to clear the display and completely cancel the cycle
flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost
Mar 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
419 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
