Question about SDI iHome iH52B Remote Control for Apple iPod (047532889178)
IHOME IH52B Amp is blown, no sound with volume on max
With the volume set to max, the sound from any of the speakers is so faint you have to have one of the speakers against your to ear. I have replaced the head unit and the problem still remains. Checked the fuse in the sub it's still good. When you turn power on or off on the head unit the sub pops. Switching source of audio (radio, AUX, ipod) makes no difference.
3 Suggested Answers
diodeic
  • 1622 Answers
SOURCE: By ml500guy on Jan 23,
Most speakers are mains powered (either plugged directly into a wall socket, or maybe using a 12volt adaptor), and inside the speakers will use a small amplifier circuit. These circuits are prone to often going faulty and may lose one speaker or both, so instead the speaker will then only play the sound as it gets it from the PC (or hifi etc.).
Audio to speakers is not sent in a 'loud' form, but is instead just a very high quality weak signal that must be amplified to be heard. Typically a PC sound output may be just .5 to 1.5 volts only, just enough to work a set of headphones but nothing much more.
I suggest checking your speakers on another item, such as a CD player or hifi that definatly works, and if its the same, its most likely the 'amp' gone faulty. It's not really worth fixing as they usually only break in cheaper types of speakers - so its as easy to just buy another set.
If they work OK on other devices, maybe check these things:
Is the volume up on the computer ? Check on the volume icon on the taskbar, and also if its a laptop check its not got a volume dial that has been accidentaly turned down/off.
Test the computer with other speakers, to just narrow down the fault.
Some PC's have several output sockets at the rear (or front), so make sure you have it plugged in to the correct socket - even if you have used it before, some PC's software can actually change what comes from each socket, so your MIC socket could now have become your SPEAKER socket, or other settings may have been changed by other software.
Check your operating system is not using a 4 speaker setup instead, and sending the sound to non-existent rear speakers/woofers/tweeters. My own PC has 8 outputs, so I make sure nothing alters my settings or i'd never hear it again ;)
Its also possible for the PC audio chip to go faulty, but that is very very rare. If nothing else works & the speakers are known working ones, you may have to try a new sound card.
Remember that plugging the standard 3.5mm stereo jack plug into the wrong sound card socket will not cause harm, you may just hear a loud 'THUMP' or click as the power goes across.
One last thing is, try reinstalling your audio drivers. PC operating systems can lose driver functions and do any possible thing you can imagine. It may be as simple as a reinstall to wake up the audio card again.
I hope this will help to solve the problem.....
Posted on Sep 15, 2011
damneddle
  • 1607 Answers
It's hard to tell yet if it is a problem related to the amp. What is the model of your iHome? Do you use it mainly for iPod?
Posted on Sep 16, 2011
My iHome iBT60 has a low volume when connected through Bluetooth. I've tried connecting & reconnecting it twice, and it didn't work. Has anybody had success troubleshooting thi
Turn up the volume on your iPhone. Also, try connecting your iPhone or any other media player, e.g. computer, to the AUX IN jack on the speaker and see if the volume is higher for that connection.
Jan 01, 2015 | iHome iBT60 Bluetooth Rechargeable Mini...
This ihome has been playing staticky noises.. It's really annoying PLEASE HELP ME.
Speaker is "blown up" because you have played the volume too loud, im not sure if its expensive or it has hq sound, but you should buy a different one, if you wanna play loud music you should get a bigger one. BTW NEVER play at max vol. or it WILL break if u use it too long.
Apr 14, 2013 | Audio Players & Recorders
I can't get the manual in the internet. for it. ihome model. ih52b
Its on the sellers website, I have same system but my docking station has high pitched sound coming from under it....no idea why, so annoying and manual doesn't say how to fix, but here is link to manual........http://www.ihomeaudio.com/media/uploads/product/files/iH52_IB36272_81_1.pdf
Jun 30, 2011 | SDI iHome iH52B Remote Control for Apple...
Very low sound volume
1. In bottom right of your taskbar is an icon of a small speaker, click on that and make sure the slider bar is at 100%.
2. Click the windows button in lower left corner and then click on control panel. Then click Hardware and Sound, then click adjust system volume and make sure those are at max volume and not muted.
3. Depending on your system there may be software that installed to manage your sound card or onboard sound, if there is usually there will be an icon representing it on the lower right of your taskbar. Open that and make sure sound levels are set to max and not muted as well.
4. Make sure you plugged the speakers into the right jack in the back, sometimes when plugged into the wrong hole you can faintly hear sound but thats it, USUALLY its the light green jack you want but that can vary (some sound card/connections will have small icons by each of the colored jacks as well though they are usually faint and kinda hard to see...they can help make sure speakers are plugged into the right spot)
5. Its possible your speakers are just old or defective and simply need replaced.
Feb 18, 2011 | Computers & Internet
Need more volume on computer speakers
Buy yourself some stand alone speakers, a base & two side speakers, they cheap these days, base speaker has buit in amplifier & plugs into mains, or get surround sound 5speakers & a base, again mains powered, loud enough to annoy neighbours on full. Built in monitor speakers are renowned feeble tinny sounds. Right click speaker icon, bottom right, on your desktop toolbar, open volume control, ensure volume sliders set to max.
Oct 02, 2009 | ViewSonic VX910 19" LCD Monitor
WindowsMediaPlayer silent on Toshiba laptop; sound faint on Skype
GOTO CONTROL PANEL-- check the audio devices, see if its set to the default device under playback and recording device, default is realtek,,,
Feb 03, 2009 | Toshiba (P000377700) Computer Speakers
Open Questions:
SDI iHome iH52B Remote Control for Apple iPod (047532889178) Logo
802 people viewed this question
Top SDI Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a SDI Audio Player and Recorder Expert? Answer questions, earn points and help others
