Question about Noritz N-069M-DV, N-084M, and N-084M-DV Pipe Cover
I have a Noritz N-069M-DV unit that has stopped and has an error code 16 in the display
Error code 16 what does this mean?
4 Suggested Answers
senor8
  • 73 Answers
SOURCE: noritz 069 error 11
Inspect the inside of the unit case for moisture. This would indicate a leaking heat exchanger. Also you may want to clean the ignition plug (they sometimes develop debris over time).
Posted on Aug 14, 2009
SOURCE: I have a noritz n-069m-dv. it is coming up with a
I had the same fault code. Noritz told me it was a Bypass Control valve that was blocked from shutting all the way. It is located inside the unit on the bottom right there is a small motor with two wires attached to the bottom of the valve... these wires could possibly be not contacting... I resolved the problem by tapping somewhat strong on the valve with a hammer with a type of punch... i was lucky the tapping unstuck the valve.... i would reccomend if you can't resolve tis simply get a tech who knows how to work on this... there are two gears inside that are keyed by marks on them... be sure that they go back right if you dissasembe this valve. Good Luck...
Posted on Jan 08, 2010
senor8
  • 73 Answers
SOURCE: I opend Drain Plug on my Noritz Unit N-069M and
The filter is frequently stuck in the filter hole on that model. Look for a black plastic washer with a circular hole in the center; that's the bottom of the filter. You can remove it with a screw driver. Put the screw driver in the circular hole, turn it at an angle, and use it as a lever to wrench the filter out.
Posted on Jul 30, 2010
Do you happen to know what error code 16 means for the Noritz model N-069M tankless propane water heater?
The Model you have has been discontinued and replaced by Model # N-0751M. However, the Owners Manuals for both units make no reference to an Error Code 16. But, both manuals say if other codes than listed in the Owners Manual show up, you should contact a qualified service technician.
For you future reference, in case you don't still have your Owners Manual here's a link to Noritz Owners Manual Page for your Model. Just click on your Model number and the Owners Manual will come up in a pdf format that you can download or print.
http://www.noritz.com/professionals/products/old_models/
Sorry I couldn't be of more help. But, hopefully this will get you headed in the right direction to solve the Error Code.
Feb 12, 2011 | Heating & Cooling
014 code
A 14 code means the thermal fuse (white wire which wraps around the heat exchanger) has snapped. This occurs if the heat exchanger reaches a dangerously high temperature. To correct this error code you need to replace the thermal fuse and keep the heat exchanger from over heating. Typical reasons the heat exchanger over heats are:
1) scaling in the heat exchanger
2) combustion chamber dirty and burning hot
Oct 07, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
I have a red blinking light with code 90 displayed. We were getting hot water this morning and all of a sudden it is just cold now. Wondering how we go about getting it fixed. Thanks.
the 90 code indicates poor combustion. It can typically be resolved by cleaning the unit with compressed air, performing a descale, or corrected an improperly sized gas line.
Oct 01, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
What does a F12 error indicate on a Noritz system
F12 occurs on a multi-system or quick connect. It means one of the units on the system suffered a flame loss. More specifically, it means the flame rod stopped detecting flame on the burner. The most typical causes are as follows:
1) insufficient BTUS (low gas pressure)
2) leaking heat exchanger
3) clog in the manifold, burner, or heat exchanger
4) stuck flue damper or improperly sized venting
5) dirty flame rod
6) damaged circuit board or gas valve
Sep 28, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
Got a noritz elvkoo3 heater shuts off and i get a code 90
the 90 code indicates the unit is overheating and needs to be serviced. I'd recommend contacting a servicer to clean the unit with compressed air and perform a descale.
May 06, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
Light blinking 3 times - no remote - won't come on
You have an error code. If you cut electricity to the unit and wait about 20 seconds before powering it back up, the unit will come back on again. There are serveral error codes associated with 3 blinks, I'd recommend instaling the remote controll to determine exactly which one it is (instructions are in the installation manual).
The most common error code associated with 3 blinks is a 16 code, which is typically related to scale formation in the heat exchanger. This error code can be fixed by performing a descale.
Feb 25, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
I have a noritz n-069m-dv. it is coming up with a trouble code 66. Any ideas?
Dec 31, 2009 | Noritz N-069M-DV, N-084M, and N-084M-DV...
Noritz 069 error 11
error code 11 is an ignition problem. make sure your gas pipe is sized properly, if your on propane check your tank and make sure it's not low or when it's running take the cover off and look in the flame window and make sure it's an even flame if not you probably have a gas control valve problem
Aug 06, 2009 | Noritz N-069M-DV, N-084M, and N-084M-DV...
Need to know what 4 blinks on the red light means
If the unit runs for a while before coding out, it's probably a "high limit error" (20 code). This code can be resolved by performing a de-scale on the unit: http://noritz.com/u/Descale%20Procedure.pdf
If the unit immediately goes into the code after reset, it's probably a "fan motor abnormality" (61 code). This code is either caused by inadequate voltage to the unit (less than 120VAC), or by a damaged fan motor.
Jun 16, 2009 | Noritz N-069M-DV, N-084M, and N-084M-DV...
Noritz N-069M-DV, N-084M, and N-084M-DV Pipe Cover Logo
112 people viewed this question
Top Noritz Plumbing Experts
Kyocera HP Expert
paulcarew
Muzammil Razzaq
Muzammil Razzaq
Are you a Noritz Plumbing Expert? Answer questions, earn points and help others
