Question about Intuit QuickBooks Pro 2001 for PC
I am having problems with my QuickBooks Pro 2001 program. It will not update and it will not recognize the drives for a restore.
The program cannot start the update module, something about an active x control. When I try to restore, it won't recognize the drive for the flash drive, even though I done it before.
    Habit-Forming:
  • Intuit Expert
  • 256 Answers
To install the Manual update:
  1. Click the link qbwebpatch.exe above.
  2. In the File Download window, click Save.
  3. In the Save As window, choose the location to save the update file.
  4. If QuickBooks is open, close it.
  5. Locate and double-click the downloaded qbwebpatch.exe file. If you have difficulty finding the file on your computer, see "Find a file on a computer that is running Windows."
  6. When the installation is complete, restart your computer.
  7. Open QuickBooks, and then check the current program release.
  • Press F2 to open the Product Information window.
  • The first line in this window displays the QuickBooks 2013 version followed by the release number (for example, QuickBooks Premier 2013 Release R12P). If the release number contains R12, then you have successfully installed the latest release.
  • Click OK to close the window.
  • If using QuickBooks in a multi-user environment, follow the above steps on the other systems. Once each machine has the update, open QuickBooks and log in to the company file as normal.
  • http://support.quickbooks.intuit.com/support/ProductUpdates.aspx
for more help visit QuickBooks Online Support
Posted on Sep 02, 2014
    Champion:
  • Intuit Expert
  • 237 Answers
We would need to know the actual error message it is giving. Sometimes you are dealing with damaged installs, and running Reboot.bat from the program folder will fix it.
Posted on Jan 18, 2013
  • 108 Answers
SOURCE: QuickBooks has experienced an error on startup
Step one is run scandisk. If you have a cross linked or corrupted file it will sort that out automactically. Step 2 is to google "where is the quickbooks repair feature".....odds are someone has used it before. Step 3.....save your Quickbooks database (in at least two places) and delete and reinstall Quickbooks if all else fails.
Posted on Jan 24, 2008
SOURCE: Quickbooks Pro-restoring a back up from a previous version 2005
If is any help - we have just had the same problem.......had version 5 (very old) of QB
changed computer to Vista and would not work so had to buy Pro 208 for Vista . We really had to get in touch with Quickbooks - they send you a free upgrade kit (disc which is Pro 2006 version (not a fuull version but enogh to get the data over) then you load that on your old machine transfer your data to that then copy that again - then load into Pro 2008 - worked fine for us - have come across a hiccup with VAT - but however I guess we are going to have to give in and phone them after the Bank holiday........apart from that everything was fine.
be brave and phone 'em - tech support was helpful.
Posted on May 24, 2008
SOURCE: problem installing quickbooks pro 2005 software
right click on the install cd and click on QBooks, then setup and it will install withou tthat happening
Posted on Feb 03, 2009
  • 112 Answers
SOURCE: Quickbooks Pro 2007- Not Responding
It's likely a problem with the PDF Converter provided by Intuit. Here are the instructions to fix the problem:
http://support.quickbooks.intuit.com/support/pages/knowledgebasearticle/1007856
If that does not fix your problem, take a look at turning User Account Controls either ON or OFF -
  1. From the Windows Start menu, choose Control Panel.
  2. Double-click User Accounts, and then click Turn User Account Control on or off. Click Continue if asked for permission to continue.
  3. Select the checkbox Use User Account Control (UAC) to help protect your computer and click OK. Close Control Panel.
  4. Restart your computer
Please let me know if this has been helpful or if there is anything else I can do. Thank you.
Posted on Sep 19, 2009
laseramp
  • 314 Answers
SOURCE: Quickbooks Pro 2007 has stopped working. when i
uninstall the software 100% reboot the machine so the information obtained in ram is not going to interfere with new installation. using your original cdrom that came with the kit, install your quick books 2007 software register it with the original code and product id sequence numbers. when it tries to run theirs 3 things happening now. the program in initializing it;s visual c run time libraries. and well as calling the dynamically loaded libraries from the windows directory and other locations. if a program was removed that used these files and it was uninstalled with the files then it is possible you will have to install qb from scratch and use the qbw or quick books workspace file to run your company files afterwords. backup the qbw files encase of problems. this is often tell take sings of viral or system melware. then scan with your virus software. and see if anything was crashing the program. other options involve system files missing that are used. good luck.
Posted on Sep 20, 2009
How do you fix quick books error code (-6177,0)
How to fix it
Intuit recommends 4 solutions for this problem. The first solution may solve your problem, or you may need to try all 4 to resolve the issue. For best results, perform the solutions in the order shown.
Solution 1: Move the file to the local hard drive
Solution 2: Be sure your version of QuickBooks is updated to the latest release
Solution 3: Run the QuickBooks File Doctor
Solution 4: Manually resolve -6177, 0 without using the QuickBooks File Doctor
http://support.quickbooks.intuit.com/support/Articles/SLN41400
for more help call 1-855-383-7236 or visit QuickBooks Tech Support
Jul 10, 2014 | Intuit QuickBooks Pro 2007 Full Version...
QBW32.exe error del sistema
Note: Make sure the QuickBooks CD is in the computer's CD drive so that damaged files are properly repaired.
To resolve this error:
Refer to Repair an existing QuickBooks installation for steps to repair the installation.
  • Reapply the product update.
  • If the error continues to occur:
Locate the default installation folder (typically: C:\Program Files\Intuit\QuickBooks [version]).
  1. Right-click the default installation folder and choose Rename.
  2. Rename the folder by entering old at the end of the folder name.
  3. Remove and reinstall QuickBooks, being sure that QuickBooks is installed to the local hard drive.
  4. Open QuickBooks.
  5. If necessary, install the QuickBooks update again.for more help visit
Apr 24, 2012 | Intuit QuickBooks Pro 2008: Windows
When I start Quick Books Pro 2005 that has been working fine for years, it opens with only a small portion of the top of the page showing and the page cannot be moved up the screen and the ENLARGE button...
It sounds as though the program may be damaged. The first thing I would do is reinstall the software. There is a possibility that your windows has received an update, or their has been an update to Internet Explorer. Since the QuickBooks program uses Internet Explorer to display various portions of the program, if you did receive an update it may be that the code for the Qb 2005 can no longer handle the later versions of IE.
If reinstalling does not correct the issue, you can also try right-clicking the QB icon on the task bar and choosing Windows, Cascade. There may be an open window in the software that has moved off the side of the screen.
I would seriously suggest updating the software as soon as you can, as the obsolete code from the older version can do little but lead to problems down the road.
Oct 27, 2011 | Intuit QuickBooks: Pro 2005 for PC
I want to back up a 2nd copy of a quickbooks pro 2006 file but it won't work. When i try and load it from the backup file on my hard drive it says that windows cannot open the file, and to use a program...
You need to make the backup from quickbooks using file,
backup. Select the drive you want the data stored on. Then if you need the backup data you need to use file, restore.
you are only backing up the data so you have to run the
file from the program, with the restored data.
Sep 19, 2017 | Intuit QuickBooks® Pro 2006 Full Version...
Opening QuickBooks Pro 2009
Sounds like your re-installation of QB did not update your registry files properly.
I would suggest:
1) make a backup of your data
2) uninstalling QB
3) delete the QB installation folder entirely
4) re-install QB
5) restore your data
If this doesn't work, I can provide "remote desktop support" to try a more comprehensive approach.
Jan 27, 2010 | Intuit QuickBooks Pro Edition 2009 Full...
Our Computer crashed. Quickbooks 2005 was
Make sure you have successfully installed the most recent program update for 2005 - available at:
http://sharedldfp.intuit.com/pub/quickbooks/2005/
Then, try to restore the .qbb file or read a .qbw file
Jan 13, 2010 | Intuit QuickBooks: Pro 2005 for PC
How can i make quickbooks 2005 run on a vista laptop?
Here is how to load and activate Quickbooks 2005 on Vista...
First of all, if you already have an activated copy of QuickBooks 2005 on another computer open it and go to "help" "my license information" and print this out so you have the details needed for activating your reinstalled copy (you don't need a fresh activation key and you may have trouble getting one as QuickBooks 2005 is no longer supported by Intuit).
On your new Vista computer, insert the QuickBooks CD but cancel any program install windows that pop up. Go to my computer and find setup.exe on the CD, right click and select the option to "run as administrator"
Once installed, navigate to the QuickBooks folder on your hard drive (typically C:\Program Files\Intuit\QuickBooks) right click on QB32.exe and on the compatibility tab select both Disable visual themes" and "run as adminstrator". Now open this file to run QuickBooks and select "file" "Update QuickBooks" to download and install all updates. QuickBooks will not work properly until you have downloaded the updates, closed and reopened the program.
I had problems with activation but I got around this by unplugging my network cable so that I had no internet connection. If you run QuickBooks without an internet connection, when the screen pops up asking you to "activate" click next and the screen to enter your license details will appear. enter your details (printed out from your previous installation) and you are done. You can restore the internet connection and use QuickBooks 2005 normally.
Andrew
Jul 09, 2009 | Intuit QuickBooks: Pro 2005 for PC
Opening quickbooks
Run a system restore and restore your computer to a time before you did the windows update. If the update caused QB not to open, the restore will remove the update from your computer. To access system restore, click on start, programs, accessories, system tools, system restore...and follow the onscreen instructions.
Thanks and please take a moment to rate as fixya.
Nov 08, 2008 | Intuit QuickBooks Pro 2007 Full Version...
Quickbooks pro 2005, Multi license
This can be a frustrating situation, and there may be more than one cause. Network permissions, user permissions, version and release of the QuickBooks program....all of these can play into this.
One suggestion would be to download the manual update from the QuickBooks support website. Save the file to a disk or a jump/flash drive, then run the update on all of the systems. You may have to open the task manager ( ctrl + alt+delete) go to the processes tab and end process on anything that begins QB.....
If they are all on the same release ( check by having the program open and do ctrl+1 on the keyboard, in the info screen it should have the version and an r number) the issues may lie with permissions, or even a stuck image file. Make sure the c: drive on the server, and the QuickNooks folders are fully shared, and that anypne logged into windows is a power user or higher.
Oct 26, 2008 | Intuit QuickBooks: Pro 2005 for PC
May 05, 2008 | Intuit QuickBooks Pro 2008: Windows
Intuit QuickBooks Pro 2001 for PC Logo
173 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
