Can't load the Buffalo Wireless N WHR-G300N router IP address
I bought a Buffalo Wireless N WHR- G300N router, connected it to my computer, connected all the cables correctly, did everything right.. it reckons it installed correctly.. however I cant load the provided IP Address to change the configurations to be able to allow a wireless connection. My laptop cant connect to it for some reason keeps coming up as ''The device does not work with the selected settings. Select compatible wireless settings, and then try again''. I'm using vista basic, and any help would be greatly appreciated. Thanks heaps :)
Fingers crossed i maybe able to help you solve the problem if you still have it do you have msn were we can chat to resolve the problem or via email it may be easier
when you connect it to your computer via RJ45 cable right click on the network card and click staus to see your default gateway and is this the same address as you are trying to connect too to change the configurations.
Posted on Feb 06, 2009
How to configure
The WHR-G54S has a default LAN IP address of 192.168.11.1
and Subnet Mask of 255.255.255.0.
Make sure your computer has an IP address in this range 192.168.11. x
Open your browser
type http://192.168.11.1
you will enter the web interface of the router
root is the username and no password is needed.
Configure your router.
http://cdn.cloudfiles.mosso.com/c85091/WHR-G54S-Manual-v1.9-web.pdf
Mar 22, 2014 | Buffalo Technology WHR-G54S Wireless...
Modem issue
Most Router have a Reset button on the back of them you can hold in for about 10 seconds and it does a factory reset on that router. I would suggest to try to do that first.
Below is the manual to your wireless router>
http://www.lmi.net/wp-content/uploads/WHR-HP-G300N.pdf
Jun 09, 2013 | Computers & Internet
Buffalo password
1. Update your iPhones software.
2. Reset the router and follow the setup instructions from scratch.
OR
1) In your browser type in AP's IP address (default is -> 192.168.11.100)
2) type in root as user name and keep password field blank. hit enter.
3) To connect wireless devices to the AirStation, you may either enter the SSID and encryption key manually, or you can use AOSS.( these settings can be found under wirless config tab)
for detailed information about configuring ap refer this manual
-: http://cdn.cloudfiles.mosso.com/c85091/WHR-G300N_Manual_web.pdf
Apr 04, 2013 | Buffalo Technology Airstation N300...
I cant connect i-pad2 to buffalo
Buffalo Technology WHR-G54S Wireless Default IP, Default Username, Default Password
Reset WHR-G54S by holding RESET down while powering it on. Hold 30 seconds, then remove power
Nov 01, 2011 | Buffalo Technology WHR-G54S Wireless...
What is the default password for airstation Nfinity WHR-HP-G300n
The default IP address for router mode is 192.168.11.1, and for the access point mode the IP address is 192.168.11.100. Default user-name is root and leave the password blank.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 27, 2010 | Buffalo Technology AirStation Nfiniti...
How do I secure my Buffalo WZR-G300N? I have lost the pin code and camnt get back in. I have read on another site that to reset the username is: root and Password is nothing (i.e blank). Once this is done...
Some wireless routers have a pinhole reset button on the back of the router. If so, use a sharp point to press and hold this button until the LED lights flash, then release the reset button. The router should be restored back to the factory defaults.
You can then open IE browser and type in the configuration IP address of the router to configure the wireless settings, you most likely need to connect a LAN cable from the computer to the router, configure the wireless settings (ie SSID, encryption etc) take a note of these settings and configure the wireless card on the computer with these settings. Then the computer can communicate with the router without using a LAN cable.
Nov 10, 2009 | Buffalo Technology AirStation Nfiniti...
Buffalo WHR-G300N. we are not a ble to connectiong the wireless, but it detecting
Download Latest Driver And Utility,Install WHR-G300N in Next USB Port and also check any other Software related WiFi.
Uninstall in safe mode del temp file then install.
Jun 27, 2009 | Buffalo Technology AirStation ...
Cannot open web page through router
Try opening network connections TCP/IPv4 on your pc and add ip address manualy to be in the same number match the same as your router ie default gateway and preferred DNS Server eg 192.168.1.1 or 10.1.1.1 depending on what default the router is set on the ip address should be the same apart from the last no. eg 192.168.1.8 or 10.1.1.8 subnet mask will default to the right setting if you push the tab key after entering the ip address
Hope this helps
Feb 27, 2009 | Buffalo Technology WHR-G54S Wireless...
I brought a Buffalo WHR-G300N Wireless N Router, did all the login screen thing, connected all the cables correctly and everything.. but I can't load the IP Address ( 196.182.11.1 .. Not sure if thats...
If you are using the router as an Access Point, 192.168.11.1 wont work unless it is in Router Mode. You should find out LAN IP for the G300N, and use that to access it with username "root"and nothing for the password.
192.168.11.1 is for:
Moderm >>> WHR G300N >>> Computer
LAN IP is required to access
Moderm >>> Router >>> WHR G300N (Access Point Mode) >>> Computer
Jan 23, 2009 | Dishwashers
WHR-G54S
problem is resolved many thanks i found my cd's and restarted the whole loading process from the beginning
Jul 30, 2008 | Buffalo Technology WHR-G54S Wireless...
Computers & Internet Logo
615 people viewed this question
David Payne
David Payne
