Question about Horizon Rst 5.6 Treadmill Walking Belt
The belt will not speed up - Horizon Rst 5.6 Treadmill Walking Belt
    Top Expert:
  • Horizon Master
  • 12,223 Answers
LUBE THE DECK BELT+ROLLERS BEARING SEE THE VIDEO AND DO IT.
However if the problem persist , TIME to replace the old board deck belt.
God
Posted on Jan 14, 2013
Yardman mower wont run in lower speeds how to adjust
the pulley in the center the one that the belt from the engine and the other to the rear axle needs to slide the pulley changes where the belt rides in turn changes the speed most times the pulley can be removed and cleaned and reused
May 21, 2012 | Garden
I just replaced the drive belt on my Troy built auto transmission Bronco 42" riding mower, and now it goes a lot slower. The belt seems to be routed correctly
The bronco is a variable speed mower from what I remember. There is a belt that goes from the crankshaft to a variable speed pulley and another belt from the variable to the transmission. If your 1st belt is too long it will never get up to speed. Do you have to push the pedal down further now than before to get it to move. ? If so your main belt is too long.
Jun 05, 2011 | Mtd Drive Belt 42"
Delta 12" Variable Speed Drill
try cleaning the pulleys buy a good belt (gates) install belt and make sure you have good belt tension
Feb 06, 2011 | Delta Machinery Delta ShopMaster DP350 12"...
Varable speed milling machine belt smelling speed not up to RPM.
Hello. I would say that either the belt is worn too much and thusly not making contact with the variable speed pulley. Or, the variable speed pulley does not adjust and is sticking. Either way the belt will slip, heat up and cause the rpm not to run the machine at the speed you want. Check the width of the belt with a new belt, I am sure that this will prove to be the issue. The belt should have a number on it.
Jan 16, 2011 | Garden
Belt just runs at max speed automatically :(
Yes. Replace the speed sensor. In the unlikely event that the problem still is not solved replace the circuit board. J.
Jul 31, 2010 | York Yankees Bedding MLB Comforter
My treadmill is a proform 345s crosswalk. It doesn't keep a constant rate. This just began this morning. It speeds up then slows down and it's impossible to exercise with the variance. What's going on?
You may have a belt and deck problem. Test by the following procedure: without the power on stand on the walking belt, push the belt in the direction it normally turns, if the belt is very difficult to turn (on most treadmill) this means that you have high belt/deck friction. Apply silicone lubricant between belt and deck beginning laterally at the motor shroud to end of the rear roller on each side
The deck should be smooth without any grooves, pits, or exposed wood. The belt should have a consistent ridged feel from one side of the belt to the other (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Visually look at the underside of the belt. It should have a consistent look. Black streaks in the belt are a sign of bottom-layer wear through. Very worn belts will feel smooth in the areas you normally walk- you would think smooth is good but not in belts because the smoother the belt, the more contact area. On occasion, you may have already damaged the DC board if you have high belt/deck friction. If the belt walks freely, you have a different problem. 2. If it passes the belt/deck checks, you may have a DC board output problem. If the belt tests ok and you have a speed variation, try this test:
Set the speed to 2.5 MPH. Let the treadmill run without anyone on the belt. Check to see if the speed is constant or if there is a variation.
If there is no variation, step on the belt. If the speed slows down or speeds up, you may have an output problem on the DC board. This is the board that connects directly to the motor.
You may have a short in the motor. If you turn the machine on and have erratic speed, you could have a problem in the DC board or the motor or both. With a simple multi-meter, you can test on the continuity scale to see if you have a closed circuit between either DC motor lead and the common earth ground. You should always have an open circuit.
You may have a speed signal problem. Your controls on the upper panel send a signal to the lower electronics to help them set the appropriate speed. If there is a problem in the signal generator, the communication links, or in the feedback links, you will have erratic speed operation.
Communications test- Look on the board for a flashing signal as you increase speed on the treadmill. Most boards have a signal feedback test light. If a LED flashes, your communication is ok.
Feedback test- If your unit is equipped with an optical feedback (disk inside a sensor) you can swap the feedback unit with the incline (it is the same part on many Icon machines). If it tests ok, you don’t have a problem here. If it is a magnetic feedback unit, you can test continuity with a multi meter or replace with a new part to test. Many times passing a kitchen magnet in front of the signal will make a speed display on the console if the magnetic sensor is good.
Signal Generator- If you have a problem with the signal generator, your speed will be erratic with either a person on the machine or without a person on the machine. You may even get a speed error code from the unit.
Jun 15, 2010 | Proform CrossTrainer Treadmill
I have a LifeStyler Expanse 1500 treadmill. It appears to start normally, but when you get on it, it starts to speed up. For example, when the speed is set to 2.9 and you get on, it will speed up to 4.2...
without the power on stand on the walking belt, push the belt in the, direction it normally turns. If the belt is very difficult to turn (on most treadmill) this means that you have high belt/deck friction I first apply silicone lubricant and see if that clear up the problem. Most problems originate from the belt and deck 75 to 85% of the time.
Jun 12, 2010 | RTO Exercise & Fitness
I have a 1997 MTD 600 series with 18.5 hp(7 speed) that I always used to pull trailer with light loads for various projects on our 10 acre property. Trouble seemed to started a couple years back when I...
Did you replace BOTH of the ground drive belts?
The deck belt has absolutely nothing to do with the pulling power of the tractor.
The 600 series MTDs have a single speed transaxle with a variable speed selector to give you the different speed ranges and requires 2 belts, one from the engine (the top half of the pulley) to the variable speed mechanism and one from the variable speed to the transaxle if one or both of the belts is worn, it will cause a loss of power to the ground
Oct 18, 2009 | Garden
Drive belt problem
ck var speed pulley for movement on middle part
of pulley
Jul 29, 2009 | Garden
Horizon Rst 5.6 Treadmill Walking Belt Logo
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Jerry Kramer
Jerry Kramer
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
