Question about Olevia LT27HVX 27 in. LCD Television
Adding new channel to menu
Cannot add channel 60 (dish network channel for 2nd tv) to channel lineup. type in 60 and enter and it says channel not available. help
    Scholar:
  • 150 Answers
Some sets are hard headed and wont take a channle number unless it is autoprogrammed, might try autoprogramming set to see if picks up ch 60, good luck! :-)
Posted on Jul 08, 2007
Channel not available dish
Heather,
I would be happy to help! I would just need some more information to ensure an accurate resolution. When you access the menu, does it say 'Main Menu' with options like 'Program Guide', 'System Setup', 'Preferences', etc...? What cable is plugged into the secondary TV? It could be a Coaxial (single black cable), or an RCA (Red, Yellow, White) cable.
Tommy Faust
DISH Social Media Representative
Dec 13, 2012 | DISH Network Televison & Video
I'm trying to get my 32 inch envision tv to change channels and it won't change at all!! I need to get it to channel 73 to work with my box free dish dvr that's in the other room!! Any suggestions??...
We would be happy to help with that. Some TV's do not havethe ability to go as high as channel 73; this may be the case for yourEnvisionTV. We would recommend changing the channel that your DISH Networkreceiver outputs the picture for your TV2. Start by pressing the"Menu" button, from the main menu press 6 for "SystemSetup", then 1 for "Installation", and then 5 for"Modulator Setup". Under TV2 we are going to change the mode to"Air", the channel displayed beside it should change to 60, selectdone on the right side of the screen to save the changes. Now change thechannel of your TV2 to 60 and you should get the DISH Network programming.
We hope this helps. Thanks so much for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Jan 14, 2011 | Envision L32W761 32 in. LCD TV
Have new E370VL hooked up to Dish Network via coax. The picture jumps/blips? Connections are tight. Help.
This can happen when there is radio interference near the coaxial cables. Sometimes the interference is behind walls. The solution is to try a different combination of modulation and channel than what the DISH receiver is current set.
The DISH menu screen for this setting is Menu-6-1-5. With dual-tuner receivers, typically "TV 1 Out" is the TV that is connected in the same room as the receiver is located. "TV 2 Out" is the tuner that is fed to the remote TV via backfed coaxial signal.
All that needs to be done is to change the channel and mode going to the effected TV to something different. If your channel/mode is currently set to Air/60, try changing it to Cable/73. When you change the mode/channel in the DISH receiver, you need to set the remote TV to the same mode and channel.
Keep in mind that with some TV companies like VIZIO, they call their "Air" mode "Antenna". With VIZIO's the TV must be set on TV input and then go into the Menu to the Settings, Tuner Settings. Change mode type to match what you are trying on the DISH receiver, exit the VIZIO menu and manually enter the channel number.
Eventually with trial and error, you will find a mode/channel combination that isn't effected by your particular environmental interference.
Jan 03, 2011 | Televison & Video
Need to change channel to 73 so my dish tv will work, it seems the highest channel tv set will go is 69
We would be happy to help with that. Some TV's do not havethe ability to go as high as channel 73; this may be the case for your (enterbrand here). We would recommend changing the channel that your DISH Networkreceiver outputs the picture for your TV2. Start by pressing the"Menu" button, from the main menu press 6 for "SystemSetup", then 1 for "Installation", and then 5 for"Modulator Setup". Under TV2 we are going to change the mode to"Air", the channel displayed beside it should change to 60, selectdone on the right side of the screen to save the changes. Now change thechannel of your TV2 to 60 and you should get the DISH Network programming. Wehope this helps. Thanks so much for being a valued DISH Network customer! Phillip Chang DISH Network Customer Service Representative
Nov 30, 2010 | RCA 27F530T 27" TV
Our dish network picture looks horrible. everything else looks good. video games ect. is there a trick ?
There are a few things that you could do for this. You could try a different type of cable. Such as, if you are currently using RCA cables, either try another RCA cable in its place, as the cable may be going bad, or try another type of cable, such as coax. You will also want to make sure that you are using the correct input/channel. If you are at TV1, you will want to make sure that the tv is on channel 3 or 4, and sometimes an input, such as video 1 or 2. If you are at TV2, you will want to make sure that the tv is on channel 60 or 73. You will also want to make sure that the other components are powered off while watching the DISH Network.
Becki Barned
Oct 28, 2010 | Mitsubishi VS-60703 60" Rear Projection...
I need to get to channel 73 to connect to Satellite Dish network, but it keeps telling me there is no channel in list ???? what do i do..Thanks
We would be happy to help with that. Some TV's are not ableto go as high as channel 73. This sounds like you're having an issue with yourTV2, this would be the TV located in a different room than your DISH Networkreceiver. Go to the main TV by the receiver, press the menu button located onthe top left of your DISH remote. Once in the main menu, press the numbers6-1-5, this will take you to the "Modulator Setup" screen. Once there we want to highlight the "Air"option located below "TV2 Out" then press the select button. TheChannel should change from 73 to 60. Change the channel of the TV you arehaving an issue with to channel 60; you should get the DISH Network programmingat that point. We hope these steps help you get that fixed. Thank you for beinga valued DISH Network customer!
Phillip Chang
Oct 16, 2010 | Haier HTF20 20" TV
We move the tv from living room to bed room and we have to change the chanel from 3 to 60 to get the tv to work on dish network, we try to change from 3 to 60 we try evereything whit no result, we call...
Rescan all the channels?Hook the tv and the satalite signal cable in the tv and dish network box correctly check?Go to tv menu.Goto SETUP,pick CH. pick option CABLE enter to rescan all channels.This should have all the channels,belong to the package u order.
Sep 04, 2010 | Televison & Video
TV IS AN ORION TV/VCR COMBO. THE BEDROOM TV IS IN RUNS OFF THE LIVING ROOM RECEIVER. THE TV CHANNEL IS SUPPOSED TO BE ON 60. NO REMOTE 4 TV, TO CHANGE CHANNEL TO 60. TRYING TO PROGRAM DISH REMOTE. 1 CODE 4...
zassyway
I have provided instructions on how to program the remote to your TV. I have also provided codes for your TV brand.
Remotes: Basic (Television Only)
  1. Turn the Television On
  2. Press and Hold the TV Power button for three seconds until the LED flashes
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
The codes are as follow: 720, 220, 748, 721 (694 only has a 2% success rate). I hope this helps.
Ray Calo
DISH Network
Jun 18, 2010 | DISH Network IR Remote Control
How do u get box 2 program from 1 2 100 i can only get 12 channels
hivoltagewes
With a DTV Pal, once you scan for your local channels and add them to the receiver, those are the only channels you have available to view. The local channels available are dependent upon your distance from the broadcast towers. I hope this helps.
Ray Calo
DISH Network
May 31, 2010 | DISH Network DTVPal DVR by
I rescanned my mothers TV this morning then went through all the channels to make sure they were all present.Everything was fine until I went through the channels again and found that I had lost ITV1.The...
Try to manually add cahn 3 or 4 to the lineup. if there is a reciver installed with a coax cable then it should show up on cahn 3 or 4. also you can also try entering the cahn number manually such as pressing zero, three on the keypad or whichever chan you a re trying to access.
Nov 04, 2009 | DISH Network 311 DTV Receiver
Olevia LT27HVX 27 in. LCD Television Logo
182 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
