Question about Radio Communications
Uniden SC-200 DC Jack Part # & Source / SC-230 S1 Switch
I have an SC-200 Scanner that I am trying to fix for someone but do not have service manual or part #'s. Emailed Uniden a week ago, no response from them. Does anyone have the part # or source for the DC jack that is in this scanner, its small & has 3 prongs on one end that attach to the board. Also have an SC-230 I need S1 rotary switch to replace if someone has that . Thanks in adavance.
I have a miller dim 452, Dc amp meter on the (+) lead and it reads 81 amps but the PC2 digital meter reads 130 amps. How can fix this problem so both amp meter and pc2 board can be reading the same?
If it has the original display board then there should be three adjustment potentiometers on it. I don't have the manual in front of me but they adjust the zero and offset for the meters.
Feb 23, 2015 | Miller Dimension 452 Three Phase DC Power...
Sc 230 scanner shuts down immediately after power is turned on
have you ruled out the battery pack it should have--total dead?
Nov 03, 2012 | Uniden SC230 Handheld Scanner
Hi I want to purchase a AC DC 12watt Power Adapter for my old ARTEC 1236P Scanner. Can someone tell me if I can use my spare Input 230V ~ 50Hz 9W (Output - 12 to 9v) adapter? If not what should be the...
This will mean the input on the first device is 120 V and input on the 2nd device is 230 V. Right? If so Yes you can use this if it belongs to the same scanner however you will have to plug the power into a 230 V Circuit. You cannot adjust, manipulate, change the Volts/Watts/Amps under any conditions. If the 203 V (Out put) plug is the same as the 120 V plug and there is a place to plug it in to the scanner then go for it. Volts/Amps/Wwatts/AC/DC are very specific to a specific device.
Jul 24, 2011 | Artronix Technology Artec 1236 P Flatbed...
My Uniden wireless phone doesn't have a dial tone,
I would be willing to bet that it's the line cord that is plugged into your phone's base unit. Try a different cord, and/or try it on a different jack.
If it's neither of these, see if any phone you have gets dialtone. If no phone gets DT, contact your service provider. If other phones work, and the new cord didn't fix your Uniden, then chances are that the jack has been ripped from the circuitry. If that's the case,
contact us at IdacomUSA and we'll be glad to set you up properly.
Jun 17, 2009 | Uniden EXS9950 900MHz Cordless Phone
Nc6320 external power problem
most case cause DC jack connection is not stable or damage
you may try
1) to open cover find out the DC jack 2 or 3 pins on the motherboard then to fix it use iron and flux.
2) check any disconnection DC/DC circuite near the jack
3) repleace the new jack if the jack damage
Oct 26, 2008 | HP Compaq nc6320 Notebook
Battery chargeing
roger 2, hi, usually a new charge will take from 8 to 12 hours and a recharge usually 2 to 4 hours. hope this helps you out,,, let us know; Mechanic
Mar 08, 2008 | Uniden SC200 Handheld Scanner
Scanner sc 230 uniden
1. Cellular is blocked out on most scanners. You might find a mod on the internet to unblock it....but
2. Most cellular now a days is digital anyway, so even if you could listen to the frequency, it would just be noise.
Geno
Feb 25, 2008 | Uniden SC230 Handheld Scanner
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
