Question about Little Giant Garden
Little giant sump pump will not pump out water
Model 3E-34N
  • 14 Answers
SOURCE: Hi, I have an inline aquarium pump made by Little
sounds like you need to get that pump off, take it apart and give it a good cleaning in vinegar. I have 135gal reef tank and do mine about once every 6 mos. You need to have cut off valves on each side so you can take it off when you need to. Go to 3reef.com. They can answer any question you've got!
Posted on Jun 14, 2009
  • 156 Answers
SOURCE: sump pump
The big cylindrical thing at the end of the wire hanging is the switch. I believe it is a mercury switch. Try hitting this a little and see if it stops. Sometimes they get stuck. If this doesn't help, then replace that piece. Hope this helps.
Posted on Jul 06, 2009
  • 634 Answers
SOURCE: Little Giant Sump Pump Backup System Alarm Keeps Screeching
is there water? sensor maybe bad, or pump failing to cycle
  • 990 Answers
SOURCE: I want to replace an impeller for a Little Giant submersible pump
This is a plastic impeller on a brass hub. If the impeller is loose it is probally cracked or overheated and melted, ether way you will have to break the impeller off of the hub then you will need to break hub loose from shaft. You can do this by putting pump in a vise and putting a pair of vice grips on hub and giveing them a sharp hit in a counter clockwise direction. you will need to replace the seal and impeller and should check to be sure than you can get these parts before you start.
Posted on Aug 24, 2009
  • 460 Answers
SOURCE: Active Pump Will not shut off.
shutoff float/switch is stuck.. replace the pump.
Posted on Nov 07, 2009
Little gaint 3e 34 n pump has started cycling off for 1 to 2 minutes the back on. this happens once every 2 or 3 days.
this sounds as if the thermal switch is being activated , this ocurrs when an obstruction has entered pump , by design the pumping media (water?) is the cooling for the pump , low to no flow no cooling !!
Aug 19, 2012 | Little Giant 3e 34n, 1/15 Hp, 670 Gph Dual...
My little giant water pump model 4mdsc has three
Sounds like you may have a 220V pump. So you need to confirm that this is a 110V pump and not a 220V pump. There should be a label or more info on line with any other info on the label. If you can confirm that this is a 110V pump, then put a standard plug on the cord - the green is ground and the other two can be wired to either blade of the plug. If you do have a 220V pump and you connect it to 110V anyway, the pump will perform poorly and will probably overheat and fail.
Jun 25, 2010 | Little Giant SPS25 Water Removal System...
Nov 07, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
Sump pump
Jul 06, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
3E-34N spa pump, very hot to the touch. Motor is
Put a clamp ammeter at one of the electrical supply wire and take note of the running current reading (amperes) with the motorpump running. Compare this with the rated current of the motor. It must be lower or equal to the rated current. From your comment that it is very hot to touch, I assume that the running current reading is higher than the rated current. To lower the running current, install a service **** or flow control valve at the discharge line. Then, put back the clamp ammeter at one of the electrical supply line/wire. Start the pumpmotor and slowly close the service ****/flow control valve until your running current reading is 85% to 90% of the rated current (amperes). I can assure you that the motor temperature will be lower.
Jun 27, 2009 | Plumbing
Garden Logo
47 people viewed this question
Top Little Giant Garden Experts
J.D. Browning
J.D. Browning
Mike Squire
john h
Are you a Little Giant Garden Expert? Answer questions, earn points and help others
