Question about Kenwood Hand Blender Set kMix HB790, White
Ultrex kitchen preparation center
Need the drive shaft attachment.
How can I find a new Bamix old model spice blender/chopper
Bar mix products made millions for world wide sales
kitchen aids that change design so often
they cant support a large parts division
(R&D is geared to sell the next better barmix product )
if you cannot find a new old part
or super ceeded shaft from the next model up
or used drive shaft for sale online
look for a complete used bar mix spice blender/chopper
some people collect barmix units for a hobby or collection
and sell double ups
when you say old model
if the shaft is plastic ....... its .unfix able
its a heat molded construction process
Vintage Bamix M122 2-Speed Hand Held Food Blender Mixer-Chopper
Sep 16, 2016 | Bamix Blenders
What are the best ways to use a Ninja blender?
It can perform almost all task of your kitchen, can make nice smoothies, prepare chunky ingredients and much more. It can crush ice fast. Would be a great choice for kitchen use, quickly prepare everything you want. It is also affordable and has stylish design.
Check out GroomNStyle.com for more information.
Jul 28, 2015 | Euro-Pro Ninja NJ600 Pro Blender - NJ600
How do I remove the little pin at the base of the shaft so I can attach new rubber drive
That is a roll pin and you need a punch the size just smaller that that little pin. Then you can just tap it out with the punch and a hammer. Remove the drive and replace and tap the pin back into place to hold the rubber drive.
Nov 12, 2014 | For Your Kitchen Bamix Professional Stick...
I have a vitamix VM0109 and the spindle that the drive socket attaches to has sheered off, is it possible to replace it, if so where can i get the part from, whats the part number and where can i find...
Drive socket meaning the clutch drive on top of the motor? If the shaft that part fits onto has sheared off then prepare to empty your wallet because that is the motor.
Oct 23, 2013 | Vitamix 5000 Work Top Blender
I have osterizer food grinder( Detouchable) but machine was lost where can i find a replacement for the machine...
If you mean the one that attaches to a Kitchen Center, they are no longer available, eBay or garage sales are your only hope.
http://www.ebay.com/itm/OSTER-REGENCY-KITCHEN-CENTER-MEAT-GRINDER-ACCESSORY-/270805020990
Same with the free-standing models they had.
Sep 12, 2011 | Blenders
I have an Ultrex blender Model # 08330 need a new blender jar the lip that slides into the blender broke off. Blades are part of the blender jar. Where can I purchase this? Thank you, Marianne...
I HAVE THIS EXACT BLENDER AND HARDLY USED IT AT ALL EXCEL COND, IT'S BEEN IN MY STORAGE CABINET FOR YEARS..TRYING TO SELL IT...ARE YOU INTERESTED?
I HAVE A PICTURE ON CRAIGSLIST IN THE PHILA AREA.
LET ME KNOW...
LV2TYPE247@VERIZON.NET
Feb 01, 2011 | Ultrex Blenders
I need a replacement jar for a ultrex model 08330 blender
I HAVE THIS EXACT MODEL AND HAVE NOT USED IT FOREVER...EXCEL CONDITION, TRYING TO SELL TO SOMEONE WHO WOULD LIKE IT.
NOTHING WRONG, JUST DON'T NEED IT LAYING AROUND COLLECTING DUST.
THIS BLENDER IS AWESOME!
INTEREST?
Dec 09, 2010 | Ultrex 834-334 Die Cast Work Top Blender
Need to order parts for food processor for stainless steel blende
I neede a new blade unit for my phillips smoothie maker, I just googeld the model number + spare part and was redirected to the websites! Eventually you fine it!!
Feb 20, 2009 | Ultrex 834-334 Die Cast Work Top Blender
Replace oster kitchen center base drive part
I'am the guy who posted the comment I found out how to do this.
There are 2 possible solutions the 2nd is not pretty, hope the first works for you it didn't for me.
1- The motor must be lock up, by placing a thin screwdriver through the holes in the base into the fan down into the motor,holding the screwdriver, remove the square drive from the top.The part you are trying to remove actually is screwed into a gear in the gear box, you will need a spanner wrench,(sometimes a strong pair of long nose pliers will work, engage the spanner holes,hold the screwdriver ,and try to unsrew it, you may need someone to hold the screwdriver,because it takes a lot of force to loosen it.These are regular threads,and unscew counter clockwise.
2- if #1 doesn't work-this will- but its not so pretty.The motor assembly attached to the gear box will have to be removed,it will come out as one piece
Remove the bottom plate,unplug the white wire from the speed control,and the blue- white wire from the board,also you will have to remove one of the brushes with the white -blk lead.
Now you will have to actually break off of the top plastic(bakelite)by whatever means you dream up (I actually used a small wood chisel to score a line, and crack it) once its cracked, it breaks apart easily.Once thats done turn it over and remove the four screws holding the gear box to the housing you will now be able to remove the gear-box motor assembly.
Remove the 3 screws from the top of the gear box pry the box open,remove the gear with the piece that needs to be replaced,now you need to get the piece unscrewed from the gear.I did this by locking the nurled end into a vise, and very carefully grabing the gear teeth with large channel locks(if you think of a better way thats great)it work for me,but I was very concerned about the gear teeth,you can't slip.
Try the new piece to make sure it sets all the way down to the bottom of the gear(it must or your head will be to high ,and won't lock down)if all is well,make sure everything is greased,and start re-assembly, the new coupler ,and the square drive will be the last 2 pieces assembled from the top, once again locking the motor with a small screwdriver.
Feb 11, 2008 | Blenders
Need new product
I have a brand new, never used (parts still in plastic, but no box) ULTREX Kitchen Preparation Center model 14008- Blender-Food Processor-Fruit Juicer that you could buy.
Nov 06, 2007 | Blenders
Kenwood Hand Blender Set kMix HB790, White Logo
Top Kenwood Blenders Experts
Ross Keen
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve
Are you a Kenwood Blender Expert? Answer questions, earn points and help others
