Question about LaCie Hard Disk 500GB with Hi-Speed USB2.0 500 GB USB 2.0 Hard Drive
I cannot drop files from my laptop to my lacie n2870. What is the problem?
Error message reads "device not supported by backend"
  • LaCie Master
  • 27,725 Answers
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem
Posted on Jan 14, 2013
2 Suggested Answers
SOURCE: LaCie (300761) 100 GB Hard Drive I get message
Hi, this is most likely occurring due to the fact that the drive or electronics have failed. The device has indicated a fault, and the operating system is misdiagnosing the fault as a "drive door open". which obviously it is not, this is why we can be sure the drive/interface has actually failed.
This failure may only be the "interface" so removal of the drive and re-connection to say a USB - HDD dongle may result in the PC being able to "See" the drive and perhaps recover the data? If this works it may then be used as any "Normal" HDD would be able to be used. This would also prove that it is only the "Interface" electronics that is faulty and NOT the HDD itself, often though, it is BOTH, one must test to be sure.
However often it is the actual HDD electronics itself, but even if this is so, then this too maybe able to be recovered, if the fault is ONLY with the electronic on the drive, the main HDD board attached to the outside, and NOT the HDD's "Internal electronics". IF it is the external board, and an EXACT same type of HDD must be obtained, and the electronics board is then removed from the known good working one, and swapped out with the "Faulty" one, this will/should restore functionality to the bad HDD. This if it works will completely restore the HDD back to full functionality. It is nevertheless a long shot, but again if one must have the data then it is a small cost to pay?
Another way is to send the HDD off to a commercial recovery place, however this is usually rather expensive, but if one must have certain data then one must do what one must do to recover it.
Another thing is to try the HDD on another PC? This also may help?, if it did does work on another PC, immediately recover the data.
Posted on Jul 31, 2011
How do i delete music files on the lacie n2870
Same as on any hard drive whether internal or external, portable, flash drives, sd cards.
LF click---highlight---RT click ---delete.
Apr 12, 2013 | LaCie Rugged All-Terrain (301017) Hard...
Included "Start Lacie" file not
Format the drive with win XP or use a third-party HDD software like partition magic.
keep in mind that the choice of a correct file system is very important, "NTFS support volumes up to 16EB" while FAT12 is limited to 32 MB.
Keep me posted!
May 28, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I have a Lacie wireless space network drive (1TB) connected directly to my router. I'm only using the switch functionality and have my pc connected to the internet through one of the 3 ports on the...
Here is what LaCie suggests about this issue:- first backup any data you have copied on Wireless Space. You can also backup your configuration: from "configuration" tab of "Support" widget, click "save" button next to "Configuration file", it will download a backup file.
- still in "configuration" tab of "Support" widget, tick the third box labeled "Restore device to factory state (data erased)", or any equivalent quote in selected language, and click apply
- the device will reboot, rebuild hard drive image, then reboot on default state. The issue is definitively fixed
- it is recommended to apply latest update downloaded from LaCie website
- you can restore previous configuration in "configuration" tab of "Support" widget, click restore and select previously downloaded backup file
Feb 07, 2011 | LaCie Wireless Space 2TB Wireless Storage...
Receiving the following error when trying to access Agfa 1212u scanner on Ubuntu. Could you advise what needs to be done. "Failed to open device 'snapscan:libusb:003:002': Invalid argument.
If the naming conventions are the same in the Ubuntu libraries as they are in the Mac libraries (no guarantee there, but I was just looking at them, and they look almost identical), it's not finding the appropriate driver for the scanner. I know that the SnapScan 1212u will work with Ubuntu, because I came across several discussions, as I was looking for a solution for my Mac. Have you installed the Linux SANE libraries? Agfa scanners were very popular for years, and mine still works great, too. I know that numerous Agfa scanners, including the 1212u are supported in the SANE backend libraries for Mac, allowing TWAIN acquisitions with devices that may no longer be supported with current scanning software.
I think you just need to install the SANE libraries, backends, and any interface (it's 5 files on the Mac). There's some additional troubleshooting information and links to files, here.
Jan 04, 2011 | Agfa SnapScan 1212u Flatbed Scanner
I/O device error Lacie mini ethernet drive
- Try to install proper drivers for your operating system.
- Check if your device is supported with that server/pc ? does server supports USB2.0 ?
Update NIC drivers to the latest level
Aug 02, 2008 | Computers & Internet
LaCie Hard Disk 500GB with Hi-Speed USB2.0 500 GB USB 2.0 Hard Drive Logo
321 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
