Question about Philips Magnavox 51MP392H Rear Projection Television
Power turning off and on
My television is just over a year old, and is now turning itself off and on. When you turn the power on, the power/standby button flashes then it turns itself off. After about 30 seconds to a minute it will turn itself back on and then back off, and repeats.
    Scholar:
  • 150 Answers
This may be the main digital module, I would suspect that this set is a couple years old and would be having issues with maybe the SSB module in that case, unplugging the set for 1 min might help, but I bet that it will require service.
Posted on Jul 08, 2007
2 Suggested Answers
SOURCE:
  • 135 Answers
SOURCE: the picture goes off. the power/standby light
Replace the lamp
Posted on Feb 01, 2010
Why no picture?
Probable power supply failure
Apr 14, 2016 | Insignia Televison & Video
Samsung HC-P4752W Does Not Turn ON
The proble you have is an intermittant power supply or sweep power supply. Unless you can find a bad connection on the power and deflection board, this could be a very difficult problem to find. I have ran across this problem a couple of times, and after spending countless hours troubleshooting, I replaced the main board and all the problems were taken care of. The board part number is at samsungparts.com and I found the board for you. it is located here: http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP94%2D01266A&search%5Fmodel=HCP4752W Good Luck
Jul 04, 2007 | Samsung HC-P4752W 47" Rear Projection...
Rca 42pa30rq
Hi! Hope this will give hint... I understand some televisions nowadays are fully controlled using remote but there is always a standby power button for the television remote function. If the there is no power after turning on using the standby power button please check power cables, supplies and fuses. If the television has a standby power waiting the remote to act on but no response after pushing the remote's power button check the battery and its contact. Goodluck.
Mar 18, 2014 | Televison & Video
LG 47LD450 comes on, then unexpectedly shuts itself off. No standby power indicator, no nothing. It turns itself back on after 2-3 minutes. This isn't a sleep timer issue. What else could it be?
Well I'm not a T.v. expert but sounds similar to over heating problems. Is the ventilation covered or filled with dust? Try unplugging it and take an air can to the vents to blow out any dust it's collected over the years.
Feb 10, 2014 | Televison & Video
Sony KDL40S2010 Bravia LCD TV... turns off / on on it's own
If TV does not remain in standby and turns on itself then power switch on top of it could be defective and power supply board is also suspected. Take off its back cover and unplug top switch connector just to confirm is that cause of On-Off its own. If problem still exist then power supply board has problem and will be replaced. Let me know the results to move forward.
Jun 13, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My 10 year old KV-27V22 turned off by itself and won't turn back on. No fault code(standby light) no nothing. Power to set is good.
Take the back off of the set and check the fuse if it is bad replace it be sure to uuplug your tv before you take the back off of it after you replace fuse if it is bad plug it up and see if it will come on if the fuse blows again then you have a deeper problem like the bridge shorted or transistor, restors in the power supply of the set.
Mar 04, 2009 | Sony Televison & Video
Set wont turn on red light just keeps blinking
this is a malfunction of the power supply block (inside your TV-device),or over load of it.please contact the nearest repair shop.
Aug 08, 2008 | Sony Televison & Video
Panasonic switching to standby mode on its own
Is this a recognised symptom? yes the problem in power supply. it is due to switching oscillator& switcing output circuit probabaly capacitor & transistor. as set is very old so after power supply is ok check for horizontal output also. can it be fixed? yes it is common & not major problem
Oct 05, 2007 | Televison & Video
Philips Magnavox 51MP392H Rear Projection Television Logo
67 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
