Question about Broadcom BCM5721 NetXtreme Ethernet Controller for Servers
NETWORK CONNECTION ON PC
To work locally on my computer, I generally "disable" the "Network Enable" (LAN) icon on my desktop, just in case, when I no longer need to be connected to the internet. I have a recent problem where the computer is restarting everytime I try to "enable" the LAN icon. The NIC card is fine as it shows up in the devices. The driver seems fine. I have a McAfee AV product installed, so I do not doubt any viruses (however, can't discount any!). Would need some assistance on this, soonest. Thanks.
  • Jason M May 11, 2010
    Click Start -> Run and type
    eventvwr
    Click okay. When the Event Viewer comes up, click Application. Do you see any events correlating to the time you try to enable the NIC? Check out the System section as well.
  • 85 Answers
Install operating again some files has been missing
Posted on Jan 30, 2009
Wireless radio switch
Usually WIFI is Disabled/OFF if you typically use a wired LAN connection, and a lot of systems only allow you to have One Or The Other on at one time, otherwise it would not know which method to send your internet and network traffic.
So, you may have to Temporarily Disable the LAN connection before you can Enable the WIFI connection.
If your dell has an antenna sticking out of the back, then you have wifi, otherwise I believe this model needs a wireless card. If you do have wifi, here's how to turn it on.
- click Start,
- choose Control Panel on the right
- If the top right says 'View by: Category'
click the down arrow on the right and choose either Large Icons
or Small Icons.
- choose Network and Sharing Center
- you will now see your wireless network if the adapter is on,
if it is not on, chick on Change Adapter Settings on top left
- two connections typically show up:
1. Local Area Connection and
2. Wireless Connection
- right click the Wireless Connection,
- choose Status
> the next window lets you Enable your wireless device, check its
Properties, or Diagnose connection issues.
Let me repeat from above:
Just reverse this later if you want to go back to a wired connection on the desktop machine. I use all WIFI at home, then I connect my laptop by a cable to my router if I have an issue to solve, which is maybe once every two years.
It's easier when you are doing it than it may seem just reading this.
Hope this helps
All the best to you,
KerryHos
Jan 27, 2014 | Dell Vostro 200 Mini Tower Desktop...
Cant connect to lan modem
1. check first your lan connections,
click start, go to control panel, click network connections din check your local area connection.
2. right click the local area connection, then try to disable and enable it.
3. if not been solved,
try to look the driver of your ethernet drivers
look at and search your motherboard's brand and model then search it and download for your drivers for your network adapter.
or you may try this,
1. right click my computer
2. click properties
3. clcik hardware tab
4. click device manager,
5. click network adapter
6. right click the name of your network adapter then, click update
Jan 26, 2010 | Gateway 500GR PC Desktop
The computer does not show the internet connection in the monitor. Before I reinstalled the windows it shows the message: no connectivity or limitated connectivity. The comcast modem was damaged so they...
Even though it does not show the connection on your monitor, the connection may still be working. Did you post this problem from the same computer? If yes, then you are fine.
Dec 29, 2009 | Dell Dimension E510 PC Desktop
When i connect to computer ethernet light does not come on
If the link LED does not light up on the computer then the fault is most likely a faulty LAN cable or the LAN card is faulty.
Replace the cable first and if this doesn't work check the LAN card and reinstall the LAN driver. If this doesn't work then then LAN card is faulty and needs to be replaced.
Dec 10, 2009 | Linksys WRT300N Wireless Router
I have aa ACER X3200 and the net work adapter will not recognize the LAN plugged in. The LAN source is active and works on other computers I have.
Check the Network Connections (in control panel) to see if the LAN connection is enabled. If not there, you'll need to setup a new network connection. If it is there, right-click the connection icon and choose enable.
You can also check the Device Manager to see if the network adapter is listed and working without errors.
Oct 03, 2009 | Acer Aspire X3200 PC Desktop
Dell Dimension 4600 - network adapter disabled - I was told that I would need to re-load the hardware disk that came with the computer. Problem is the disk does not work - it's corrupt. What is work around...
Right click on the icon in the system tray and select open network connections, a new window will pop up, right click on the disabled network adapter and select enable.
If the icon is not in the system tray go to the control panel, select network connections and enable the adapter.
If it still won't enable you may have to enable the LAN (network adapter) in the BIOS.
Please post back if you need anymore assistance.
Regards.
Jul 20, 2009 | Dell Dimension 4600 PC Desktop
I have to connect the LAN cable before wireless will connect
Try going to the network control panel and disabling the local connction.
Apr 04, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
How to setup network adaptor
Technically you should provide 'IP Address" to your network card. Generally IP address is provided by the ISP (Internet Service Provider) provider you are using.
Once you get the ip address you can configure it by right clicking on the my network>properties>TCP/IP setting.
This will work.
Regards
Feb 15, 2009 | Acer Aspire RC500 PC Desktop
Although the internet connects on my PC my laptop won't connect via the router
check that your router is working that lan cable is working, and right click on network places in your laptop screen go to the properties and check there local area conection is enable if disable enable it and check your ip, if there is no local area conection you have to install the network adapter driver
Sep 27, 2008 | Computers & Internet
Cannot connect to internet from acer laptop but am connected to a wireless network, what am I not doing?
Check if your LAN card is enable:
Go to Start and click on Control Panel.
2) Control Panel window will appear. Double click on Network Connections.
3) Network Connections window will appear. Right click Local Area Connection.
If the connection is currently enabled, the first option in this menu will be Disable. Otherwise, the option will be Enable.
Click on the Enable/Disable option to enable/disable your network connection.
Jul 26, 2008 | Computers & Internet
Computers & Internet Logo
125 people viewed this question
Top Broadcom Computers & Internet Experts
Prashant M
Prashant M
Are you a Broadcom Computer and Internet Expert? Answer questions, earn points and help others
