Question about Humax Televison & Video
Channel guide keeps scrolling and cannot select channel
2 Suggested Answers
SOURCE: Turn tv on, and it scrolls through the channels
Had the same problem, channels would not stop scrolling.
It was as though someone had there finger on the channel up button.
Disconnected the sixth wire, starting with the black wire on the wiring harness for the front buttons, on/off, ch. up/down, vol. up/down, etc.
It works fine, no more unwanted channel surfing!!
Posted on Nov 30, 2007
How to change default input to AV1 when power up on Viera?
Go to menu mode. Scroll the list of selections. Mostly in the settings you will find this option. THIS USER CHANGEABLE OPTION. Refer user guide also. You can even a select a desired channel, to get selected on the power on.
Aug 19, 2010 | Panasonic Televison & Video
I live in Pretoria South Africa using Windows 7 I have installed the drivers for DVB S 100 however I cannot find signal scanning with Media center and my Theater please help
Follow this steps and try
in windows 7
On the start screen, scroll to Tasks, click settings, click TV, and then click Set Up TV Signal.
Follow the steps to connect a TV signal, depending on the type of tuner or tuners that the cable is connected to
else try
The Windows Media Center TV Pack has an "Auto Select" option which removes channels that have a weak signal from the EPG. To run the "Auto Select" option to check the list of available channels and to evaluate the signal strength for each channel, follow these steps:
  1. Start Windows Media Center.
  2. In the Start window, scroll to Tasks, click Settings, and then click TV.
  3. Click Guide.
  4. Click Edit Channels.
  5. Click Auto Select.
The "Auto Select" option tests each channel. Based on whether a strong or a weak signal is found, the "Auto Select" option puts a check mark in the box next to the channel. As soon as the detection process is complete, you have to click the "Save" option to save the newly selected channels to the EPG.
esle if the problem still persists
have a look aon the microsofts support in the following link
http://support.microsoft.com/kb/955485/en-us
Feb 19, 2010 | KWorld DVB-S 100 (DVBS100) Video Capture
I have tried to retune my tevion lcd 1507id because of the change in the granada area. The tv retuned but i have no itv, channel4 or channel 5
These will have been rolcated to a different channel number. You can select the programme guide & scroll through all the channels until you find thier new location number, then you could either take note of these new numbers or go into the set up menu where you can re-arrange the channel numbers back to 4/5 etc or set them on your favourites listings
Dec 08, 2009 | Televison & Video
Remote up & down channel buttons will only bring up a few channels. Cannot go through all channels unless I punch in digits on remote
Which Dish model receiver and remote? You likely have a custom guide selected that only includes those channels. On most models, press guide twice and select a different guide or press Favorites to Modify List of the channels in the current guide. If in doubt select All Sub or All Channels to see more/too many channels with up/down. I use All HD for seeing the high-def channels. Otherwise I use a custom list to see a bigger listing. -Ken
Aug 25, 2009 | DISH Network IR Remote Control
How to change channel
Spirit GT: Programming a Frequency to a
Selected Channel:
1. Press and hold down the Push-To-Talk
button while turning the radio on, wait for
approximately 5 seconds then release the
Push-To-Talk button.
2. Use Scroll button to select one of the 8
frequencies.
3. On a Spirit GT+, press the Monitor button.
4. The current channel will flash, press scroll
button to change channel.
5. After the second channel is selected, press Monitor button again, current
frequency for second channel will flash. Figure 16.
6. Use Scroll button to select new frequency.
Exit Programming Mode - 3 Ways
1. Press Push-To-Talk to exit completely.
2. Allow the Menu time to expire (10 seconds).
3. Press Menu button to go to code programming.
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/Spirit_GT_User_Manual_E.pdf
Jul 17, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
Panasonic dmr-eh50 Clock setting greyed out - unable to reset clock after clocks went back.
To resolve this issue follow the steps below:
(1) Remove all discs from the unit.
(2) Set the unit to DVD Mode
(3) From the front panel of the unit, open the middle door to display the up and down channel buttons
(4) Press and hold both the up and down channel buttons until the unit displays "BYE" and then flashes "12:00 A"
(5) Release the up and down channel buttons
(6) This will clear the unit and you will be prompted to reset the TV Guide Settings
(7) Setup your TV Guide according to the on screen display
(8) From your remote select "SETUP"
(9) Scroll down to "Setup", right arrow to the options on the right, and down arrow to "Clock Settings"
(10) Select "Set Clock Manually" if your TV Guide Function is not providing you with the proper time
Good luck!!!
Oct 26, 2008 | Televison & Video
Talk about frequency change
To change channel & code press talk and monitor while turning radio on. Radio will speak current channel. Release both talk and monitor. Press talk to change to next channel or press monitor to keep current channel. Press monitor when desired channel is selected, radio will speak current code. Press talk to change to next code or press monitor to keep current code. Press talk to change code as desired then press monitor when done. Will speak channel and code selected. Set all units in same manner to communicate.
Oct 15, 2008 | Motorola Talkabout T5800 (22 Channels)...
Change channel lineup
1.) Press the TiVo button on the remote (at the top)
2.) Scroll down to "Messages & Settings" and press 'Select' on remote
3.) Scroll down to "Settings" and press 'Select'
4.) Scroll down to "Channels" and press 'Select'
5.) Press 'Select' on "Channel List"
6.) Pressing the "ENTER" button on remote will let you change Channel Line-Up
Aug 28, 2008 | Tivo Series2 TCD649080 Video Recorder
Aug 29, 2007 | GE 32GT740 32" TV
Televison & Video Logo
122 people viewed this question
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Tony
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
