Question about Hitachi CP-S235 Multimedia Projector
Seeing yellow spots on my CP-S235; getting bigger over past 2 weeks
    Problem Solver:
  • 9 Answers
This is the blue lcd burning out and is the end of the projector.
Posted on Jan 18, 2013
3 Suggested Answers
SOURCE: Hitachi CP-S235 Data Projector - yellow tint to projected picture
Replaced cable and the problem was solved.
Posted on Feb 12, 2009
Larrysito
  • 73 Answers
SOURCE: my hitachi cp-s235 projector has a blueish hue on
i think it is mothing to do with the bulb it is the stup of the 3 color frame inside ,or iternal dirt ....need profesional store ....
Posted on Aug 30, 2009
To replace a bulb in the Hitachi CP-S235 LCD Projector, do I just unscrew the two screws under the plate underneath the machine? Are there any precautions I should take, like not handling the bulb? I have...
Yes to replace the lamp you need to remove the 2 screws. You can touch the lamp but I try not to. After the lamp is in you need to reset the hr timer for the lamp. to do this you need to look in manual on page 34.
If you do not have the manual you can get it here at link below.
http://www.aboutprojectors.com/pdf/hitachi-cp-s235-manual.pdf
Good luck
Oct 05, 2009 | Hitachi CP-S235 Multimedia Projector
My hitachi cp-s235 projector has a blueish hue on the left side. how do i fix it, it is a brand new bulb
Aug 30, 2009 | Hitachi CP-S235 Multimedia Projector
Hitachi projector model CP X260 projects yellow spot on screen
This is probably the polarizing filter. It will need to be replaced. It should not cost very much to fix.
Jan 07, 2009 | Office Equipment & Supplies
The change filter light keeps coming on
In the manual, it says you have to go in the menu to the OPTION submenu. Go down to FILTER TIME and hold the right arrow down for 3 seconds. It will then go into a mini-submenu that, when you press the up arrow, will reset the filter time to 0. The key is to hold down the right arrow initially for THREE+ SECONDS to get into the reset filter time menu. This is NOT the submenu that has RESET - EXECUTE. That is a different thing that doesn't reset filter & lamp time.
Here's the manual online:
http://www.hitachi-homeelectronics.us/supportingdocs/forhome/DisplayTechnologiesGroup/lcdprojectors/SupportingDocuments/01CP-S235-OG-ENG.pdf
Jan 05, 2009 | Hitachi CP-S235 Multimedia Projector
Hitachi cp-s235
Did you clean the air filter? You should vacuum it or use an air dusting can to clean it out.
Afterwards, reset the time in the menu. In the manual, it says you have to go in the menu to the OPTION submenu. Go down to FILTER TIME and hold the right arrow down for 3 seconds. It will then go into a mini-submenu that, when you press the up arrow, will reset the filter time to 0. The key is to hold down the right arrow initially for THREE+ SECONDS to get into the reset filter time menu. This is NOT the submenu that has RESET - EXECUTE. That is a different thing that doesn't reset filter & lamp time.
Oct 07, 2008 | Hitachi CP-S235 Multimedia Projector
Yellowish spot on the lower left hand corner of tv screen
Good Day, There is a device that can be used to correct your concerns. Symptoms can be correct by EE PROM CORRECTION TOOL:
LSUQ0100. Instructions included. Try calling 1-800-458-6053. It's under $100.00 and takes about 1 hour from start to finish. Good Luck, big IRISH.
Jul 07, 2008 | Panasonic PT-52LCX65 44" HDTV
Hitachi cp-s235 projector- red lights and projector turns off
There is a small tab on the lamp cover that should press into an "L" shaped slot on the lamp housing. This tab may break off, and not press into slot far enough to make the lamp dectection switch click. When the lamp heats up, the plastics expand and the detection switch opens. The projector quits as if no lamp is installed. The fix is to make an extension for the tab. I cut a small piece of sheet metal and crazy-glued it to what was left of the plasic tab.
Feb 20, 2007 | Hitachi CP-S235 Multimedia Projector
Hitachi CP-S235 Multimedia Projector Logo
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
