Question about ASUS F3Jp Notebook
F3jp shuts down ati driver is installed - ASUS F3Jp Notebook
  • John Walker Jan 13, 2013
    To be more clear, My ASUS F3JP shuts down within a minute or two of booting into Windows whenever I have any ATI driver for the Radeon x1700 that I have tried. When I Have the standard generic VGA from windows installed, the problem disappears. I have tried pulling the heatsink off and replacing the thermal compound with Arctic Silver 5, thinking that it might be an overheating problem, but It hasn't made a difference. Any ideas?
  • Lucio Oct 03, 2013
    Try Linux (elementary OS, perhaps)
My hp pavilion g7 series laptop is messing up? it says my ati display driver keeps messing up.
1.Start the laptop up in safe mode with networking by pressing the f8 button while switching it on at the power switch.
2 Once in safe mode remove the ati drivers.
3. Download Eusing free registry cleaner install it and clean your registry.
4. Download new drivers from Ati and install them.
hopefully this should do the trick. if the problem still exist then it could be a sign that your graphic chip is failing,.
Feb 13, 2013 | Pavilion g7-1219wm Notebook PC
I have issues with the second ATI FirePro V7800 card. I am running Window 7 pro - 64 bit. The motherboard is ASUS Sabertooth X58. Intel Corei7. Corsair 24 GB. Both two cards were working fine...
In order to further troubleshoot this issue, I would recommend the following:
Uninstall the ATI drivers from your computer.
Shut down the computer.
Remove the ATI card from your computer, and connect your monitor to the onboard video adapter.
Turn on the computer.
Ensure the ATI software was infact removed.
Reinstall the ATI video Card
Turn On the computer
Reinstall the ATI drivers ensuring to select the proper "CrossFire" configuration
May 21, 2011 | ATI TECHNO FIREPRO V7800 PCIE 2GB GDDR5...
Afteri install drivers for radeon 8500 128mb i get a bluescreen of death when watching a movie or shutting down
This is an issues which I have seen just an few times with ATI (lots) I would revert back to old driver and wait till they fix an bug..It sounds like you updated the driver, You should check microsoft web too for drivers they may have for it..
Feb 24, 2010 | ATI RADEON 8500 Graphic Card
Site for free download for ATI Mobility Radeon 9000 Fujitsu N310?
Some DVD protection routines do interfere with graphics cards. It may be that. I reinstalled Windows etc. and by a process of elimination found the guilty DVD. It sounds like the same problem. Note that just reinstalling the graphics drivers doesn't cure it. But a fresh install of Windows does - at least until you play the same DVD. One small difference was that my ATI used to 'recover' itself rather than Windows shutting down.
Allan
Dec 09, 2009 | Fujitsu Computers & Internet
Resolution problem in Windows 7
Windows 7 official release is in Oct. The Windows 7 version you have is probably the Release Candidate version, this is the last Beta version before its offical release. This version does not have drivers for al lot of devices and if you cannot get the driver from ATI at this stage then you have to wait until it becomes available.
The release Candidate will shut down every hour early next year and will stop working completely in June. You will be forced to buy Windows 7 or go back to XP or Vista.
Sep 20, 2009 | Computers & Internet
Hello again, i have managed to get the drivers for my radeon x1650 pro 512mb installed and removed the old drivers for my other graphics card, the computer restarted so the installation could take effect...
One of two things I 'see'.
1.Not to insult you, but do you have the monitor plugged into the graphics card? Hey! I've had people do it! They plugged the monitor back into the motherboard VGA port. (If you don't have a DVI connector on your monitor cable, there is an adapter you can buy. VGA to DVI. Make sure you get the Female VGA to Male DVI version)
2.You have a driver conflict. Even after you removed the old drivers, there are still drivers giving you a hassle. The drivers CD for your ATI needs to be installed first. Load the software, shut the computer down, unplug it from the surge protector, THEN install the ATI graphics card.
If you install a graphics card first, before installing the software for it, Windows will recognize that a new device has been installed, and try to match up it's generic drivers.
Then Windows goes 'crazy' trying to decide which drivers it should use.
Jul 22, 2009 | ATI RADEON X1650 Graphic Card
ATI Radeon HD 4350 (Shapphire Model)
If your computer keeps shutting down may be with the Driver, try to reinstall the driver or repair it, if you have the driver.
Jan 25, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Asus f3jp
there are no manuals for the disassembling of this machine, i am a pc tech and find it a ball ache to strip the machines down, have a look around the lid hinges to remove the top panel
Nov 13, 2008 | ASUS F3Jp Notebook
ASUS F3Jp Notebook Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
