Question about Proform 860 Competitor Treadmill
How do I remove the housing on the Proform 860?
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: proform 860 treadmill, want to undo incline feature, & use it without it
Run the software calibration for easy diagnose, troubleshooting, and fix it.
God bless you
Posted on May 17, 2012
860 Proform runs but the belt won't turn
could be the drive belt is broken. remove the motor cover on the font of the treadmill and inspect
Aug 17, 2014 | Exercise & Fitness
Treadmill is stuck in fastest position and will not change
1) LUBe the elevation motor, in shaft and gear
2) adjust the small POTentiomenter for to liberate the elevation motor
3) clean the relais contacts, and tight every connector.
see the diagram and fix it.
Jan 18, 2013 | Proform 860 Competitor Treadmill
Proform 860 competitor motor wont run
Lube the deck belt with 100% siicone or wax
2) Lube the rollers bearing
3)test tbe drive belt for worn
4) Test the input voltge motor, if there are the motor need repair, see my personal TIPS for motor help
5) Test the the output board, for input voltage motor if there are Not the board is faulty.
God bless you
Dec 05, 2012 | Proform 860 Competitor Treadmill
Proform 860 treadmill, want to undo incline feature, & use it without it
God bless you
May 16, 2012 | Proform 860 Competitor Treadmill
I have a Proform 860, I moved it to another room in the house and now I am not getting anything...won't come on
Hello. Check these items:
1. The outlet - plug something else into that same outlet to be sure you don't have a blown fuse or a kicked circuit breaker. 2. The treadmill key. Remember that your treadmill will not turn on with out the little magnetic key in place. 3. The switch on the treadmill near where the power cord goes into the machine.
Hopefully one of these will solve your problem. Regards, Joe
PS Kindly rate my answer as helpful. Thank you.
Feb 09, 2010 | Cardiozone 5 Hp 325 Lb Limit Breeze Elite...
My proform 860 has belt slippage and sometimes stops after a few minutes
I had the same problem and was about to change the walking belt. Instead I removed the 5 screws holding on the hood and adjusted the Reed Switch and took a walk. Whenever I stomped on the belt hard it would stop. I Could now see (because I removed the hood) that the motor continued to spin and the Motor Drive Belt was slipping and was the culprit. Something that I had noticed before was all this fine rubber dust coming out near the left front corner where this belt is. If you see that it's a good indicator the motor belt is slipping and needs to be replaced.
Dec 09, 2009 | Proform 860 Competitor Treadmill
I got my ProForm 860 treadmill and the previous owner said it shuts off after 1.5 miles (overheats). The company said its due to friction. How do I know what is causing the friction. Loose belt, worn belt,...
Be sure there is no damage to the walk board itself before replacing the belt. You may want to try lubricating the board before replacing the belt.(silicone spray from any hardware store) This is also caused by overtightening of the drive belt and/or walk belt. Good Luck, Tim
Nov 11, 2009 | Proform 860 Competitor Treadmill
Proform 860 QT doesnt have power
There's a little breaker near the main on/off switch that has tripped. Re-set the breaker. (also check the main on/off switch, typically near where the power cord enters the treadmill...
Mar 13, 2009 | Exercise & Fitness
Proform 860 Competitor Treadmill Logo
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
