Question about Panasonic Home Theater System System
I am gating F16 code - Panasonic Home Theater System System
    Guru:
  • 417 Answers
Check and correct the speaker cable connections
Posted on Jan 14, 2013
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
What does error F:16 indicate?
no one will know without a MAKE and MODEL.
Dec 26, 2015 | Washing Machines
What do's f16 mean on the bosch classixx 6 1200 mean
F16 is a door fault, could be the door is not tightly closed before pressing start, the lock is faulty so the machine is not registering that it is closed or the wiring connection to the door lock is loose.
Apr 10, 2013 | Bosch Washing Machines
F16 error code on washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board.
May 06, 2012 | Bosch Washing Machines
Siemens washing machine - Error code F37 Thanks
Siemens washing machine - Error code.f16
Dec 07, 2010 | Siemens Washing Machines
Internal Light Meter broken
Not worth the money, when I was in college, my professor told us of the rule of "f16"....the speed should be set at 1 over the ISO at f16 at bright noon. You can adjust the setting with one f stop per hour. If you are shooting at...let's say...ISO 400...then your setting would be "f16 at 1/500 of a second at noon." If you are shooting an ISO of 64, then it would be f16 at 1/60th of a second and so forth...hope this helps.
Mar 22, 2010 | Nikon FE 35mm SLR Camera
Error code F16
F16 on a Bosch indicates the door is open / unlocked.
The wash programme should halt when this comes up but you should be able to restart it when the door is closed.
As the cost of a new door interlock isn't overly expensive I would suggest fitting a new lock on a "fit and see what happens" basis.
Aug 10, 2009 | Bosch Washing Machines
Whirlpool Duet
your main processing board is having an communitcation error. if you have taking the kickplate off the tech sheets or on the right or let hand wall and will tell you how to enter the diagnostic phases
Jun 01, 2008 | Washing Machines
F16 error
constant f 16 shown on screen on my Panasonic mini hifi set what the problem.,
Jan 22, 2008 | Audio Players & Recorders
Panasonic Home Theater System System Logo
69 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
