Question about Ryobi Ry09460 4 Cycle Gas Blower
Blower vac doesnt have any spark .will not start Gudday
I have a factory refurbished Ryobi ZR08510 blower/vac from the factory. I cannot get it started. What should I try first?
Hi Paul:
I'd start by pulling the spark plug, attaching it to the lead, then spin it over and check for spark.
This will probably be a 2 cycle motor (Check to confirm) so make sure your fuel is mixed correctly.
Dec 30, 2015 | Ryobi Blower Vac 205mph Leaf Blower Or...
New blower will not fire
Check for spark at the plug by using a simple spark checker tool. Got to have both or it won't start.
Feb 26, 2014 | Poulan Pro Gas Blower Vac BVM200VS
Gudday, try changing spark plug,check stop switch and wiring failing that try electronic ignition mag. pack...Give it a go......
Dec 31, 2012 | Ryobi Garden
Got a craftsman leaf blower cranks up and runs fine for about 5 mins then starts losing rpms
ITs hard to diagnose these things over the internet, it could be so many things.
Is this a gradual loss of power? If so; Im sorry to say; that it sounds like its losing compression as it warms up. It is not cost effective to repair the unit.
If the loss of power is more sudden it could be a failing ignition module. Ive even seen spark plugs that quit working when they get hot.
To test this you will need a proper spark tester, laying the spark plug against the head will not provide an accurate assesment, and a can of carb cleaner. Run the unit with the air box cover and filter removed till it fails and immediately give a shot of carb cleaner in the carb and restart. If it starts right up it could be fuel related. IF it doesnt start right up then quickly test for spark. If no spark then its likely the ignition module. If it wont run on the extra fuel and it has spark then it has probably lost compression.
Nov 05, 2012 | Craftsman 4 Cycle Blower/Vac
Craftsman leaf blower wont start
The air gap for the ignition coil core to flywheel is adjustable on some engines and the gap does vary.
On a Stihl, I used a matchbook cover first, then doubled it and got the engine to start. That amounts to 8-10/1000ths (0.008-0.010") as measured with a digital caliper after-the-fact.
I'm troubleshooting another engine currently from a McCulloch Airstream IV that only has ~12 hours and no spark but the coil measures roughly as it should; around 1K Ohms. Was surprised to find the company went bankrupt in '99. Another one killed by Asians and fairly poor design.
May 26, 2010 | Poulan Featherlite Gas Blower, with Low...
I am gettinno spark from the spark plug I have put in a new plug,
first check to make sure the on/off switch isnt shorting out anywhere. try resetting the gap between the flywheel and the igniton module. you can use an index card or manilla envelope to set the gap. if it still doesnt work try replacing the module
Nov 22, 2008 | Craftsman 4 Cycle Blower/Vac
Poulan leaf blower wont start
try changing the spark plug. if that doesnt work let me know and i'll help you trouble shoot it.
Nov 02, 2008 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Ryobi Ry09460 4 Cycle Gas Blower Logo
26 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
