Question about Jenn-Air JGR8850 Gas Kitchen Range
Jenn Air Older Oven wall unit only
We have an older Jenn Air oven. Stove is counter top model. We bummed the delay setting instead of the timer and now we can not get the oven to come on. It says to push for manuel control. It has a timer knob. Then a start knob and then a stop knob with time. Can't find the book. Any help would be greatly appreciated. Thanks
  • Shannon Schreffler Jul 08, 2007
    Hi
    Tried with the breaker and it did not work.
    The thing is I know we have had this problem before and I can't get it now. Up top we have the oven temp knob. Down in the middle is time and timer. Then is the start know for delay and below that is the stop time. It says push for manuel. I think I have tried almost every combination of pushing the knobs. Any other suggestions would be great.
    Thanks for quick response.
    THANK YOU!!! THANK YOU!!
    It worked. You are great. I will save your website for future help on matters. Thanks so much.
    Shannon
    Scholar:
  • 76 Answers
Shannbooks The first thing I would recommend to do is to reset the power. Turn off the breaker for the range for couple minutes and then turn it on. In the most cases it works. Set the time of the day and try to use the oven. If it would not solve the problem let me know. Good luck. Gendos. post back...
Posted on Jul 08, 2007
  • Gennadiy Kagan Jul 08, 2007
    Shannbooks
    I thought your range has an electronic control but according to the later information you've provided it has an analog clock. It makes very big difference. The knob were it says -Push for manual- has to be pushed in and the other knob -Start- has to be popped out. Rotate this knob until it pops out (it should do it at the point were it shows the time of the day on the oven clock), then rotate the -Push to manual- knob to the same position and push it in. Now your oven should work.
    Gendos
    post back...
I have an older jenn air model ww30430 and I cant get the fan to turn off or the upper oven to work. any suggestions
if your unit is switch position is the upper heating element is have convection? you cannot turn off the fan,but if your unit have separate option to choice the other option to oparate separately the upper heating element this one can be use.
Dec 24, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
(90s) Jenn-air single wall oven locked
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
I hope this helps
May 13, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
How do i remove a jenn-air built in wall oven? (older oven model W131B)
IF YOU OPEN THE OVEN DOOR THERE SHOULD BE SCREWS FROM THE SIDE OF THE OVEN INTO THE CABINETS THERE COULD BE MORE THEN SIX
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Mar 07, 2010 | Jenn-Air JJW8330D Electric Single Oven
Help with wiring for a drop in stove top
This is not to code. The white is neutral and is of the same polarity as a bare wire. The red and the black are considered hot and would be 220.
Apr 07, 2017 | GE Cooktops
I have a jenn air oven and stove top. the
Just a suggestion, turn the breaker off to the range and leave off for 30 secs. This may reset the board. That's the easy way. If that doesn't help I'll try to find more on it.
Jul 24, 2009 | Jenn-Air JES9800A Electric Kitchen Range
Jenn air oven analog clock
If it's an older oven, forget about getting a new clock. Instead, have it removed (or do it yourself, mark wires and of course discontinue using oven) and try your local parts guy to see if he can send it away to have it rebiult. Best case scenario. Either that or have a technician "bypass" it for you.
Jan 01, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn Air Range SCE30600
i would pull unit out adn look for a bad thermostat on back wall wired inline from bake and broil elemnts, probably tripped during a clean cycle or something got to hot, common for oven to shut down because of bad safety thermo, yet stovetop function without interuption
Nov 26, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Jenn-Air JGR8850 Gas Kitchen Range Logo
199 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
