Question about GE WSM2420T Top Load Stacked Washer / Dryer
Ge wsm2420 will not drain after washing
The washer was working fine as of yesterday. I have unplugged it and removed the front panel. The hose was not kinked. The spin cycle works without issue. I don't hear the motor turn on after the wash cycle. Could it be clogged? Do I need to replace the motor?
  • 1294 Answers
SOURCE: GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Posted on Sep 12, 2007
SOURCE: GE WASHER WON'T GO THROUGH THE DRAIN CYCLE AFTER WASH CYCLE
Most likley it's the drain pump! check the wiing and pump
Posted on Jul 09, 2008
MNTECH
  • 1543 Answers
SOURCE: GE WJSE3110A washer, won't drain
On a scale of 1 -10, I'd rate this about a 3.5 in difficulty.
Un plug machine.
Use a putty knife to push the clips in at the seam of the front panel and the washer's top, about two inches in from each side to allow you to pull the front panel forward and then lift it off the bottom pegs.
If you took off that drain hose, you shouldn't have any water left in the machine, so take the two squeeze hose clamps off the pump hoses, the electrical wires off the pump, and the two 3/8 size bolts holding the pump to the washer's base.
Now check to see if the pump is plugged or obstructed with an object. Replace pump with cleaned out or new pump as necessary.
Posted on Dec 10, 2008
cbrown801
  • 3 Answers
SOURCE: washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Posted on Mar 30, 2009
SOURCE: GE washer WSXH208AWW does not spin and drain out.
my GE washer does not spin out all the time on final spin
Posted on Dec 31, 2009
I have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 13, 2011 | Roper RAS8445KQ Top Load Washer
IT WILL WASH BUT WONT DRAINE
Unplug machine and remove front bottom panel by removing one screw from the bottom left and right corner on front of machine. Remove hose from pump (be ready to mop up water) and clean out obstuctions from pump and sump area (rubber boot just before pump). If no obstuctions found, replace pump.
Jan 12, 2011 | GE WSXH208A Front Load Washer
Where?s the filter on my GE WSXH208A Front Loader? Thank you beltronic205 (GE WSXH208A Front Loader won?t drain). I drained the tub by lowering the drain hose as suggested. But where is the filter, what...
There is no acutal filter on this unit...You cab remove the back panel to access the drain pump ...Or tilt the washer back and access it from the bottom...Remove the drain hose from tub to drain pump...(careful of flow of water from tub)...Check the hose for any blockage...If no blockage then your pump is bad..
Apr 20, 2010 | GE WSXH208A Front Load Washer
GE front load washer- error msg "door locked"
have you checked for any foreign objects in the drain pump itself this if the most likely problem.or the drain pump has completly stop.make sure you pull the drain hoses from the pump and check for foreign objects if there is still water in the unit use a shop vac and connect it to the drain hose to remove all the water before disconnecting the drain hoses. after the water is drain this may unlock the door as well
Sep 16, 2009 | GE WSXH208A Front Load Washer
Water does not empty from tub
Unplug the washer.
Remove the front panel. putty knife needed.
Remove the drain pump and clean it out as well as the drain hose from the tub to the pump.
If they are not blocked replace the pump motor.
Feb 21, 2009 | GE WBSE2090A Top Load Washer
GE WJSR2050T2WW Washer fills up,Spins but won't drain out?
The most common reason for no pump out is a blockage in the pump. Best to drain as much water as possible. (even laying the drain hose down to allow as much of the water to drain out as possible) Un-plug washer. Next, open the front of the washer by using a putty knife to push in and release the clips about two inches in from each side at the seam where the front panel meets the washer top. Pull the front panel forward and lift it off the bottom pegs. Remove spring clamps from inlet and outlet of pump with a plier. Remove two pump mounting screws to allow pump removal after unplugging electrical leads. Remove obstruction from pump. Most pump bodies can be separated if necessary. Reassemble, plug back in and test.
Jan 15, 2009 | GE WDSR2080D Top Load Washer
Un plug machine.
Dec 10, 2008 | GE WJSE3110A Top Load Washer
Washing machine won''t drain
HI thanks for your questionOn your washer theres a electric pump sometimes foreign objects get caught in pump remove front panel . Using a blade screwdriver insert between top & front panel about 2 inches from corner .The front should now come off .The pump is on the left side . Disconnect pomer If your washer is full of water now put drain hose on floor or in bucket to drain water . Now remove hoses from pump & clean reinstal . Thanks for your question The appliance doc
Sep 06, 2008 | GE WHRE5260E Top Load Washer
Fixing a clogged pump on GE Profile washer
Take a putty knife and slide it in between the front panel and top to pop the clips that hold on the top. Remove the front panel and you will see the pump down in the front corner. Remove the hoses (watch for water) and you should see any clog. Check hoses and drain line (home) to be sure there is no clog in those while you have it apart. Be sure to unplug your machine before working on it as well. Good Luck!!! Jim
Sep 09, 2007 | GE Profile Prodigy WPSE4200A
GE WSM2420T Top Load Stacked Washer / Dryer Logo
96 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
