Question about HP Compaq Presario SR1617CL PC Desktop
No power, wont come on
Worked that morning but not now
  • HP Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 14, 2013
Why Wont My Straighter Work??
1) check continuity if you have multimeter 2) try to plug in another power socket 3) check the the reset button if any on it
Feb 02, 2015 | Televison & Video
My toshiba tv wont power on
Check circuit breakers, fuses, and wired connections. In some cases a power surge can disrupt the power board. If you had a power outage and the TV was plugged into the outlet, s surge can damage vital parts.
Mar 25, 2014 | Televison & Video
Wont power on and red light isnt on
Main power supply regulator board damaged. Check and replace it.
Dec 08, 2013 | RCA 46" Class LCD 1080p 60Hz HDTV,...
Chevy blazer wont start after sitting for a while
weak alternator not charging the battery fully or an elictrical item in your vehicle using the power , like a light or radio etc
Dec 02, 2011 | 1996 Chevrolet Blazer
My acer al1914 wont power on... was working fine,
The usual suspects, blown fuse, blown capacitors, bad solder joints. Any of this conditions could be your problem.
Jul 16, 2010 | Acer AL1914 19" LCD Monitor
Panasonic television ct22890254 wont power on, worked fine this morning
Unplug,replug not power up,must changed the power supply.
Nov 24, 2009 | Panasonic CT-36HL43 36" TV
Tv wont turn on worked fine last night
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
May 30, 2009 | Spectroniq PLTV3250 32 in. LCD TV
Car wont start in the morning
a toggle switch will work as long as you put the right fuse in it..Good Luck
Mar 23, 2009 | 1987 Chevrolet S-10 Pickup
Mouse and Keyboard wont work after booting system?
First thing I would try is System Restore.
Start
Programs
Accessories
System Tools
System Restore
And go back to a date before this morning. This should take care of your problem most of the time.
Now when you say the monitor was black... do you mean because of the screen saver/power settings turned it black? Or did it go out on its own? If on its own, sounds like it might be overheating. See if it works once cold.
Jan 30, 2009 | Dell OptiPlex GX270 PC Desktop
Wont eject
not getting enopgh power to cold warm it up leats 30 min driving befre use car in cold
Feb 04, 2008 | Jensen CDH-1000 CD Player
HP Compaq Presario SR1617CL  PC Desktop Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
