Question about Toshiba Satellite R15-S822 Tablet PC
Cleaning inside lcd panel for toshiba r15 s829
Some dust has entered into gap between LCD and front panel. How can I disassemble LCD panel to clean it.
Remove battery then remove trangular black tabs (2) at the top of the screen. Then remove square silver tabs (4) at the bottom of the flip top. This can be accomplished with either a push pin or sharp knife just get under one corner and peel off. They are just thin pieces of plastic with and adhesive backing. Remove the screws underneath ( 6 in all) with a small screwdriver. Run your fingernail around the entire outside edge of the flip top to pop off the plastic front with screen. Wipe off LCD and inside of the screen with a soft damp cloth; do not spray anything directly on to the LCD. Reverse the above steps and if you were careful you can just reattach the plastic tabs over the screws.
Clear view again!!!
Posted on Mar 27, 2009
MY PC WAS CRASHED R15-S829 IS MODEL NO. HOW CAN I FIX IT?
Posted on Oct 17, 2009
Toshiba tablet R15-S829 has only c drive .can i do partition in this hard drive. is it accptable for this laptop or not.please help
I think the problem is only that your system crashed. So you can try some data recovery software to recover the wanted data from system partition and then reinstall OS,
I suggest you can use a free data backup software to create a recover disc once you enconter such a problem you can recover your data and system easily.
Freeware AOMEI Data Backuper: http://www.aomeitech.com/aomei-data-backuper.html
Jan 22, 2013 | Tablets & eReaders
I have a Toshiba R15 S822, my problem is that my touch screen is not working, I would like to know how do I reset my computer to factory setting?
I might not be necessary to reset to factory settings. Just go to the Toshiba.us support site and download the drivers for the Tablet PC (that includes the WAcom driver, all the tablet PC extensions).
If you have the Recovery CD, you can run it from inside Windows XP and reinstall selectively all you need.
Just to set things straight, the screen of the R15 reacts to the Wacom pen only, not to your finger or some other plastic tipped pen.
Aug 14, 2011 | Toshiba Satellite R15-S822 Tablet PC
How do I remove the HDD from a Toshiba r15 s822 laptop
Hi!
You can click this link to download the manual for your Toshiba r15 s822. Please click here Toshiba r15 s822.
Jul 20, 2011 | Toshiba Satellite R15-S822 Tablet PC
Want to download a recovery disk for my Toshiba Satellite R15-S829
you will need to contact toshiba to order the disks if you misplaced yours or if it did not come with it.
the recovery disks can not be ordered.
thanks adi
Dec 24, 2009 | Toshiba Satellite R15-S822 Tablet PC
My toshiba satellite R15-S822 laptop will turn hot everytime i turn it on and has unusual noise. what do I have to repair or buy to replace the damaged parts?
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here.
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
You may also want to remove the hard drive and ROM drive.
Take a
peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
To make newer laptops last longer between cleaning a good 3 fan cooling pad is suggested.
never use a laptop on soft surfaces as the ventilation can act as a mini vacuum cleaner and encourage dirt build up.
Soft surfaces also block the vents causing fans to run more and burn out sooner.
Hope this gives you the information you need
Oct 07, 2009 | Toshiba Satellite R15-S822 Tablet PC
My Satellite R15 S829 recovery disk was lost
You can call (800) 457-7777 and get a new set. I see Toshiba has bumped the shipping and handling to $24.95 standard, $29.95 next day. Have your serial number and a credit card handy.
Jun 14, 2009 | Toshiba Satellite R15-S822 Tablet PC
Replace fan on Satellite R15-S829
MAKE SURE YOU HAVE REMOVED THE TWO SCREWS UNDER THE COVERS AND THE ONE VISIBLE AFTER REMOVING THE DVD.
Apr 03, 2009 | Toshiba Satellite R15-S822 Tablet PC
Clean dust from tablet pc screen
You have to remove the screw covers (the black squares around the screen), remove the screws and gentley pry the cover open with yor finger nails or a flat head screw driver, but be careful not to dent the sides with the screw driver. You can then take a can of air and blow the dust out. I would not touch the sensetive screen under neath. You could take a anti static, micro fiber cloth to wipe off the tough stuff.
Jan 26, 2009 | Toshiba Tecra M7 Tablet PC
I have an R10 tablet.
I once asked a Toshiba certified technician if I could remove the screen cover and I was told that I am not supposed to do that.
Maybe you shoul take the unit to a Toshiba repair center in your town, or country.
Hope it helps.
Jan 20, 2009 | Toshiba Satellite R15 Tablet PC
Replacing the LCD
I need to do this on mine as well. Ive already taken it apart, just have to find a new lcd. the front cover on the screen is held on by 6 screws, 4 on the bottom under the silver stickers and 2 on the top under the black triangular stickers in the corners. Then the screen itself is held on by 8 little screws on either side (4 on either side). Where did you buy the replacement lcd for it, and do you know the part number?
Aug 13, 2008 | Toshiba Satellite R15-S822 Tablet PC
Toshiba Satellite R15-S822 Tablet PC Logo
640 people viewed this question
Top Toshiba Tablets & eReaders Experts
micky dee
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
