Question about Aiwa NSX-D7 Shelf System
TX-N9 Compact disc player press button system not working
NSX-D7 9H,E,K)
3 Suggested Answers
  • 4234 Answers
SOURCE: My Compact Disc Stereo System NSX-AJ50 is tripping
One or more of the output transistors has failed or you have a bad speaker. Try disconnecting both speakers and turning on the unit. If it still shuts down, then the transistors are likely to be defective. These can be replaced for about $15-$25 plus labor at any service shop that handles audio gear.
Dan
Posted on Feb 20, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: right i have an aiwa mx-n9 + mx-n7 systems mx-n9 keeps
These little fans are driven by fluctuating currents not DC current. It is a problem with the circuitry the drive it. The current are pulse width modulated, which is how the speed of the fan is controlled.
Posted on Jul 01, 2009
HOW TO PLAY COMPACT DISC WHEN COMPACT DISC PLAYER IS ON?
You press the play button......
If you have multiple disks, press the appropriate disk and it will play
How to Use Six CD Changer
6 Disc CD Changer Instructions eHow
Feb 10, 2016 | Panasonic Technics 5 Disc Compact Disc...
I have an old Aiwa NSX-V150M Compact Disc Stereo System. I cannot load CD's into the unit. Pressing the "Load" button causes the internal mechanism to cycle up and down 5 or 6 spaces and then a "CHECK"...
Hi! I also have an (old) NSX-V150M that does nearly the same, I suggest two problems on mine: 1) maybe the laser assy has to be changed because it doesn't detect the actual CD anymore and skips to the next one. 2) there is a tiny limiting switch on the moving platform that seems defective, or the rubber belt (?) is too stretched, so that it doesn't detect when the CD is in place from the changer. Then the unit starts again "CHECK"ing, as when the memorized list of CDs doesn't match the detected list of CDs. For the first one, maybe the Sony KSS210 or KSS213 spare part could be used, not sure of it. For the limiting switch, I have glued a match to keep it in place to keep the CD part quiet. Result: no more CD playing for now, but the unit doesn't "CHECK" anymore, and tuner and amplifier still work great. Need to look inside one of these days.
Jan 09, 2013 | Aiwa Audio Players & Recorders
How to unlock nokia N9
Do not enter any wrong unlock codes on your Nokia N9 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia N9 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia N9 without any sim card.
2 - Don't bother as to what is displayed on your Nokia N9.
3 - Compose #pw+CODE+1#.
4 - The Nokia N9 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia N9 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly The letter w appears if you press the button star(*) four times quickly The symbol + appears if you press the button star(*) two times quickly The CODE you need to enter is the unique unlock code for your Nokia N9 Each Nokia N9 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia N9 mobile phone using the form above.
from: http://www.nokian9specs.com/1797/unlocking_nokia_n9.html
Feb 23, 2012 | Nokia Cell Phones
I have a nsx-a508 unit,the 2nd tape deck got stuck i was able to open it but now neither deck plays and the cd player did work when this happened originally but does not work now ,the lights all come...
I think I can help you with the tape part, but as for the CD, that's a whole different story.
First, you should reset the unit by holding down the stop button (clear), and then pressing the power button. Everything stored in memory after purchase is cleared, including the radio stations, clock, etc.
Check if deck 1 is now playing.
I had a similar problem with my AIWA NSX-AJ310, and after some digging up, I realised that the belts were busted. They're not hard to replace though, unless you don't trust yourself to replace them. If you don't, let a qualified technician see about that for you.
The CD player in my system has retired also, so, we're in the same boat as with regard to that issue!!
Hope my solution was helpful!!
JaHa
Jun 21, 2011 | Aiwa NSX-A505 CD Shelf System
The tray of cds does not work properly, does not allow the change of disc to disc and stuck
Try pressing repeatedly the eject button while you turn on the unit. If this doesnot work
then it is a mechanically problem in your player .
You need to manually open to take out the cd .
The rubber thread which should be connected to the motor inside the cd player might have moved from its place.
You need to place the rubber thread to proper place.
Also if the belt is slipping, the mech never gets the "drawer closed" signal, and the disk will not spin.
Mar 04, 2009 | Aiwa NSX-A505 CD Shelf System
My Compact Disc Stereo System NSX-AJ50 is tripping off every time I turn it on. Henry dulcerito@live.com Thanks.
Dan
Feb 20, 2009 | Aiwa Audio Players & Recorders
AIWA NSX-2700 Alarm
On the remote hold shift and press timer button.
It should go off.
Hope this works for you
Kurt
Dec 27, 2008 | Aiwa NSX-2700 Shelf System
MY microphone doesn't work in my machine
you have to remember that microphone is a sensitive device. it may or may not be work with other same or different devices. But can work with same model device.
Sep 29, 2008 | Audio Players & Recorders
Aiwa nsx k570
i need the circuit diagram for the CD player in NSX K 570 Aiwa 3 CD changer music system . I am Located in mumbai colaba. 9819890987
Mar 18, 2008 | Audio Players & Recorders
Aiwa NSX-D7 Shelf System Logo
13 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
