Video Game Consoles & Games Logo
A
Anonymous Posted on Jan 13, 2013
PC GAMEPAD CONTROLLER HANTOL HGUS002 - Video Game Consoles & Games
2 Related Answers
A
Anonymous
  • Posted on Apr 24, 2009
SOURCE: USB GAMEPAD NOT WORKING!!!
I used one like that for my windows xp home PC (It looks just like the Playstation 2 controller) and it worked with MAME (original arcade games that were downloaded on my computer) It comes with a little CD that has the drivers on it...Look on ebay..they are very cheap coming from China and Hong Kong
0RazR0
Mohamad Ali Kazi
  • 100 Answers
  • Posted on Jul 07, 2009
SOURCE: trying to use controller for call of duty 4 on pc
All hail! Here is your solution. Download this profile complete with instructions. No hassle, no problems!
http://rapidshare.com/files/252613129/Call_of_Duty_4_Rumblepad_2_Dual_action_Profile.rar
5helpful
I need drivers for ttx tech wireless gamepad
the controller didnt come with a disk? the manufacturer doesn't offer drivers from what i could find. is the controller showing up under settings/device manager in the USB area? it should be there. you need to locate a program to assign the keys. PC/Mac
Will the ttx pc mac 2 pack turbo gamepad analog controller w/usb hook up to my hp laptop
yes it is PC compliant. I also got it to work on a mac. You will need to find an emulator controller to assign the keys. some emulators have the assignment built into the emulator under preferences.
1helpful
I got the controller conected to my laptop, but the buttons wont work when i start playing the game, its a p380 dual analog pc gamepad
you must first make sure you installed the software drivers for the controller. when you open the game, make sure that you've setup the controller in your options window. your controller name should show up if done correctly. Note: in some cases, some games aren't compatable with certain controllers, i suggest that if this is the issue, you consider getting a better supported controller, preferrably a Microsoft 360 controller. they're cheap and wireless. Bam. Toaster streudel.
Xbox 360 controller is stuck
1-try rettting the game`s control layout back to default...you might have changed the layout 2-is this problem happening in other games as well? if it does, then we can consider taking the controller for repair 3-there is always ebay and amazon to get you a new controller 4-do you have a wireless or usb adapter to connect the xbox controller to the pc? in windows 7 you can use the gamepad as a gamepad and in "callibration settings" you can test the buttons
game on!
I just bought the logitect dual action usb controller and it came with no download instructions. where would I go to find the correct download for the controller?
I would try Logitech's website first, then if not found I would go to www.driverguide.com. I have a Logitech gamepad that I bought new and Windows detected mine and setup it up correctly without having to find a driver somewhere else.
5helpful
Gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
1helpful
3answers
LOGITECH PRECISION USB GAMEPAD
It may sometimes work without drivers, but its recommended that you download the drivers and have them installed. That way you can also program the buttons for various functions if you want...
Cheers!
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
