Question about Philips Magnavox 51MP392H Rear Projection Television
TV Projection filter screen
What's best for cleaning a Projection TV screen filter? There seems to be something on the inside part of the screen. I've removed it but I want to make sure I use an appropriate substance, that would damage the screen. (Phillip Magnavox rear projection TV model 9P5540). Thanks,
    Scholar:
  • 150 Answers
I would not use any kind of chemicals on the screens, I definitely would not use any liquids on anything besides the screen protector, the inside screen is a Fresnel lens and will wick up moisture, the one with the vertical grooves is the Lenticular and either one will leave a mark, if you have to use liqud, I would try distilled water, but no guarrantees you will get it clean. I usually end up replacing the screens. Looking at your post you said filter, do you mean an air filter? I dont think these sets us an air filter, if it was just dust a t-shirt or microfiber towel usually work, the towel being my choice.
Posted on Jul 08, 2007
We cleaned the inside of our tv and now we have a green screen
Please tell me how you actually cleaned it? Seems you may have hit something that turned the Green CRT gain up higher than the blue and red CRT?
Dec 07, 2014 | Hitachi Televison & Video
How to clean lens on rca projection tv model# p61960 ?
Unless something got spilled inside the TV, I suggest you think otherwise about cleaning inside the TV. You will only make things worse by doing so.
Aug 21, 2014 | Televison & Video
I have a 47" rear
This is usually due to a leaking CRT. Or picture tube oxidation in the cooling liquid. Definatly not a job to be performed in the home. The cooling liquid needs to be changed in all three picture tubes. Cleaned inside the jugs and replacement gaskets. Gennerally about 60 to 85 dollars each.
often, the fluid leaks onto the power supply or sweep module and causes other problems.
Jan 17, 2011 | Samsung PCJ522R 52" Rear Projection...
Red screen(rear projector tv)
Most likely bad convergence amplifiers. They are soldered in components.They can become intimentent and the lines come and go, usually red or blue.
May 14, 2009 | Televison & Video
HD-56G787 JVC HD-ILA Help me clean the mirror!
pop the front strip under frnt of screen off. remove screws around back edge off screen and under the frnt of th screen. Usa a micro fiber cloth to clen screen.
Apr 25, 2009 | JVC HD-56G787 Television
Where is the air filter
No one seems to know what they are talking about when it comes to this issue. I had the same problem for a couple of months. I looked up and down the internet for answers and manuals and came out empty handed. I didnt want to pay a repair guy so i decided to take on this filter problem myself. The OSD should say Projector Fan Filter Unit Needs Cleaning. The fan filter unit they are talking about is on the projector itself. That means you have to remove the back panel. I placed the tv on a blanket screen side down. Revome the board inside the stainless case and remove the projector unit. You have to unplug a few cables...thin gauge wires so be careful. Underneith and on the side of the projector are two foam filters. I vacuumed the heck out of them and its been working fine. You could try getting away with removing the front panel to the right of the lamp. you will see the small foam filter to the left of the projector but there is another one under the projector. Try vacuuming the best you can. My tv was pretty dusty inside so I'm glad to dug in a little deeper.
Apr 04, 2009 | Panasonic PT-50LC14 50" Rear Projection...
REAR PROJECTION TV SCREEN GETTING HARD TO SEE
Your TV requires service and cleaning of screen, mirror and 3 lenses (of CRTs) as looks dusty.
Below is an exploded view how to take off front beznet assembly of this TV to clean inside with moist cotton cloth.
Unplug TV before taking off front of TV.
Jan 26, 2009 | Sony KP-43HT20 43" Rear Projection...
1992 toshiba big screen rear projection tv model tp-55902
let a stinkt fart on the upper right corner of the TV and that should fix the problem.
Jun 03, 2008 | Toshiba 50H81 50" Rear Projection...
Dirt on the inside screen
Usually the best way is to remove the top back cover and clean the inside of the screen with a clean, dry cloth, but be careful because the mirror is mounted on the inside of the top back cover.
Jun 21, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Dirty screen
http://www.screenkleen.com/index.html That stuff is the best you'll find. Ever. You'll need to take your TV apart to access the inside of the TV. Take the speaker grille off and possibly assembly frame surrounding the TV(They usually snap off) you should find screws under that to further assist with disassembly.
May 09, 2006 | Philips 55P8241 55" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
292 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
