Question about Panasonic HDC-SD9 Flash Media Camcorder
Panasonic camcorder screen flops open...spring broken?
Need to know if this is a 'home repair' possibility...
  • foxy50 Jan 15, 2013
    It's just a spring that biases the LCD screen open or closed, but getting at it is probably the hard bit....
  • Mark Sep 03, 2013
    got the same design failure, is there any hope, that someone from panasonic social media team could answer this - please :-)
3 Suggested Answers
electronios
  • 126 Answers
SOURCE: panasonic sdr-s7 camcorder broken lcd panel
how can i help you?better ask the nearest panasonic service
Posted on Oct 14, 2009
SOURCE: Panasonic NV-DS33EG mini DV Camcorder : It
how can i connect my panasonic nv-ds33eg to my pc? i suppose it's with a dv-cable; but is there on the other side? a usb and is there software to get the images to my pc?
Posted on Feb 20, 2010
The dishwasher door no longer has a return spring. It just flops down.
Bob, make,model# and order spring and replace, not hard to do.
Check that your spring, just did not pop off first.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Feb 24, 2016 | Dishwashers
Screen hinge is broken so LCD screen won't stay closed or open properly, anything I can do about this?
5 days after my warrenty ran out, my camera broke those hinges too.
I did tried to get i fixed at a servicecenter, but the price for it are sky high.
150$ for fixing it in Denmark ??
Mar 24, 2012 | Panasonic HDC-SD9 Flash Media Camcorder
My Dell D830 wireless switch seems to be broken. It just flops back & forth. Unfortunately it's broken in the off position. Is there another way to turn on the wireless?
If you are not willing to risk your laptop, do not continue. If you are, be sure to take all possible grounding and electrocution protection measures.
If you look at the service manual for the D830, you can access/see the inside switch to the left, below and to the left of the red arrow, in the first diagram here: http://support.dell.com/support/edocs/systems/latd830/en/SM_EN/sysboard.htm#wp1084976
The pins that push the slider on/off have probably broken on your case, but you can probably manually flip the switch to the ON position. The switch may still be broken, but you can at least use your wireless!
Note the series of instructions on that linked page are to REMOVE the system board - you will not need to do EVERYTHING, but it gives all the steps to open up the case which will let you access the switch. Taking out the keyboard is not enough.
Feb 11, 2012 | Dell Latitude D830 Notebook
When I open out the screen of my Panasonic NG- GS17 Mini DV digital camcorder, the picture gets all fuzzed and turns to blank white. It's only if I open the screen out more than roughly 2cm, when the...
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Aug 01, 2011 | Panasonic NV-GS17 Mini DV Digital...
Door doesn't lock closed and cooking unable to proceed
The spring is off inside.
Normally the problem is not the spring itself, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
Normally you have to separate the door panels as shown in the attached photo to get to the innards.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Dec 24, 2008 | Panasonic NN-T990SA Microwave Oven
Broken door catch, possible spring, Panasonic Slimline Combi microwave oven NN-A554W.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
The best place to order parts is Tritronics. You can also call them at 866-779-5835.
Nov 26, 2008 | Microwave Ovens
Have a panasonic slimeline combi microwave and the plastic hook which helps keep the door locked is broken, therefore the microwave will not work
Of course the door latch head (hook-like device) is easy to replace or repair if that's the issue.
You can order Panasonic parts here.
Sep 23, 2008 | Panasonic Microwave Ovens
Dimension 4 microwave nn a725m door will not close
You can order Panasonic parts here. You can find an authorized Panasonic servicer here.
Sep 08, 2008 | Panasonic Microwave Ovens
Door does not latch close on the Panasonic Microwave Oven Model No. NN T444SF
Aug 26, 2008 | Panasonic Microwave Ovens
Panasonic HDC-SD9 Flash Media Camcorder Logo
187 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
