Question about Rheem 266K to 399K BTU Swimming Pool Natural Gas Heater ()
How do I set the timer on my Rheem gas spa heater model P M206A- EN-C? What does remote mode mean?
    Top Expert:
  • Rheem Master
  • 8,688 Answers
If running on control unit if not manual
Posted on Sep 15, 2017
gary1121
  • 332 Answers
SOURCE: rheem tankless water heater wont lite
the system was not sized properly, you need to have a 3/4 gas line to the unit for the volume of gas it needs, the tankless water heaters need to have every bit of gas that is says, it sounds like who ever installed di not make sure you had enough gas comming in the house, you might have to either have a new meter installed or run the gas lind directly from the meter to the water heater and cap off the gas line thats there
Posted on May 29, 2009
WonderTech
  • 268 Answers
SOURCE: have a rheem gas water heater for manufactured
First off, the repair man is right that it is the thermostat.I'm guessing his quote was the cost of part and labor to install it. You can buy a new one for around $300. to $350. ish.
Hope this helps.
Posted on Aug 14, 2009
  • 252 Answers
SOURCE: I have a Rheem glas fury model 22-40 gas water - leaking
once they leak it's time for a new water heater. ther is no way to repair a tank leak
Posted on Oct 23, 2009
  • 68 Answers
SOURCE: rheem gas tankless water heater with error code c4 13
problem is inside burner compartment o2 sensor dirty or block..need to have a qualify technician clean it.
Posted on Jul 31, 2010
john224
  • 1378 Answers
SOURCE: What is the manufacture year of the rheem
What is the serial number? The 337A series has only been around since the end of 2004 so it will be somewhere in the last 5 or so years.
Posted on Oct 27, 2010
Testimonial: "thanks. I'm selling it and the buyer wanted to know the manufacture year, and I couldn't find it anywhere on the rheem website. I appreciate your help"
I am getting a Hi Limit 2 Fault message on my heater
overheating check gas pressure if too low will overheat if ok check manual bypass see if spring is bad also make sure filters are clean and pump is functioning ok
Sep 01, 2015 | Rheem M206A 206K BTU Pool and Spa Propane...
Rheem spa heater displays rol service
rollout replace fusible link and check gas pressure
Apr 07, 2013 | Rheem M206A 206K BTU Pool and Spa Propane...
Raypak ignition lockout
means tried to ignite 3 times turn off and on then check gas and ignitor
Feb 21, 2013 | Rheem M206A 206K BTU Pool and Spa Propane...
Pool heater states rol open what does that mean
roll out switch is open. caused by an over temperature situation or negetive downdraft
Aug 15, 2012 | Rheem M206A 206K BTU Pool and Spa Propane...
My pool guy had turned off the remote feature of the gas pool water heater. I have held the 3 buttons and now it says press clock ( clk) and the top right flashes service. How do I get back into remote...
The clock indicator means the firemans switch is open. If you are running the heater remotely and thru a time clock the time clock is still off. Turn all the equipment on including the timer and you should be able to put the heater into remote mode.
If you still have trouble, please comment with your actual model and serial number from inside the heater.
John
Nov 05, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Rheem 266K to 399K BTU Swimming Pool Natural Gas Heater () Logo
158 people viewed this question
Top Rheem Pool & Spa Experts
Steve Slater
Gene Haynes
Tom Chichester
Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
