One spot on my Sony GTX900ES board gets extremely hot right away turned on and smells hot. Everything works correctly but haven't kept it on for very long cause of the heat. I know where it's heating up but have no idea what it is called. It's the tallest U shaped piece of copper amongst three two others all with a black component attached to the inside center by a single screw. It has some white silicone smeared on it. What is it?
  • 32,281 Answers
It is the fan and heatsink assembly.
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Posted on Jan 14, 2013
  • 207 Answers
SOURCE: Sony Vaio Laptop vgn-sz330p extremely hot
it might be hdd please shut down the computer when it is not needed...and is it radiating heat since when u purchased it??
Posted on May 20, 2008
  • 3 Answers
SOURCE: cpu heat
Overheating is a common problem with laptops, and usually a bit of preventative maintenance is all it takes to keep it alive. The bearings on those fans are pretty durable, however dust (and especially pet hair) can build up and slow it down. The motor may still be good, its just that the fan blades are stuck.
Blow some air in the vent OPPOSITE the direction of normal air flow (In most cases it sucks from the bottom and blows out the back/side) and if you see dust bunnies, your doing good. Be THROUGH! Especially if you smoke in your house, this causes the dust to become brown and sticky. = )
Good Luck!
Posted on Oct 28, 2008
jmgldsmth
  • 1889 Answers
SOURCE: GPU heat sink standoffs came off
to do this i use my aoyue hot air gun and, a lot of flux however; there is an eaiser way: get some two part epoxy glue mix it properly and, it should hold quite well or, use clear silicone automobile adhesive sealant by permatex (you can get it at an autoparts store) wait 24 hours before you handle the motherboard i prefer the permatex
Posted on Apr 28, 2009
SOURCE: USB port getting HOT
These ports can get quite hot & things attached can draw up to 1 Amp of current, and this can make things quite warm over time... as it draws heat away from the device. Keep an eye on it though.
Posted on Jan 31, 2010
  • 1288 Answers
SOURCE: Acer Aspire 9815WKHi Graphics Card was getting
No it is not normal for the graphics to fail unless the heatsink and fan are so badly clogged.
The cpu will stand temperatures of up to 90 degrees but, it gets the main body of the cooling and the graphics chip does not get as well cooled, what happens is the graphics chip then suffers and the solder "bed" it is fixed by melts and the chip detaches.
You may be lucky and by cleaning out the cooling components get it working, but I suspect the motherboard has been damaged now
Posted on Jan 15, 2011
A.O. Smith ProMax Plus GVR 50 101 Safety Question
You need to inspect and clean the air intake located on bottom of unit. Get more fresh air to the water heater and see if problem continues.
http://waterheatertimer.org/images/Flame-trap-inspection-325.jpg
http://waterheatertimer.org/images/State-select-air-intake-400.jpg
Instructions for lighting the unit are located on front of water heater.
Other possible causes include: bad gas control valve, dirty combustion parts, reverse draft down the stack (caused by wind and opening door inside closed utility room), low gas pressure, air in gas line, etc.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Propane gas is heavier than air. So if you have a gas leak, then smell close to floor. Leave house immediately if you smell gas. Install a gas detector close to floor level near gas appliances.
Most water heaters today are extremely safe, because we experimented on prior generations of people, who then passed along their experience.
Aug 12, 2012 | Water Heaters
I have a Sony Bravia KDL-52XBR4 LCD TV.
Sure, but not at minimal cost - it's a sony! Probably the t con board.
Sep 17, 2017 | Sony BRAVIA KDL-52XBR4 LCD TV
. Problem with Sony KDL52W4100 I've
Hello
You haven't specified anything about the picture condition of your Sony KDL52W4100. Will you please give me some more details about it. Do the vertical stripe moves acroos and washes out picture? Do you get well defined picture on the resr of the screen? As you know, this is an Email solution, and I've to get your Email address to post my solution. Sometimes, I may have to upload the service manual [schematic diagram]for your TV to get you more information about the fault, and the method for rectification. So, give me as much as details as you can. either give me your email iddress or send an Email to me at gopalan.gopakumar327@gmail.com. If I may have to upload the schematic diagram and service manual, I can't do it by this window, as this window does not allow me to uplaoad PDF files by it. I haven't placed my solution to your problem till yet. Get me the details I asked for, and help me to detect the actual fault with your tv. OK
Oct 24, 2011 | Sony KDL52W4100
Our laundry smells moldy since we bought cabrio several months ago. We've done everything we know to fix problem ,, but are not happy with the service of this machine or smell of our clothes at all!!
have you tried the super cleaner that works to clean just about everything--- vinegar
I dont know for sure if it affects several washers of that model but i have been a appliance tech for 30 years and haven't been to service that problem ever, the cabrio is what i have in my home and love it,cleans well without any foul smells
Jul 31, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
E3 F1 displayed and will not go away after pressing cancel. Don't know what is wrong.
Please check the full model number of the range.
The F1 E3 error is one found on ranges made by Whirlpool. It indicates that the jumpers in the wiring harness have been set to a different cavity (oven size) then the one previously stored by the range. Check that jumpers are correctly configured to match the actual oven size.
If you haven't had any repair work done on the range recently, you should contact a service person.
The 79012 model number gives me full model numbers similar to 79079012100. Sears Parts Direct does not have parts for the range. However, I suspect the control board has failed.
I hope this helps.
Jul 08, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Ge spacemaker xl1400 model# jvm141obc Turntable still turns..but while making grinding sound Please help
My wife noticed a strong smell of something burning inside our home. Luckily we were home. The microwave was NOT on...and the turntable was turning and making that grinding sound. When I opened the door, the turntable kept turning....all digital lights were OFF. The microwave does not work. I am extremely angry that this unit was able to continue to grind unnoticed. If we were not home, I assure you that this would have caused a kitchen fire. The upper inside portion was extremely hot to the touch and the cabinet on top of the over-the-range microwave was also very hot. This would have easily caused ignition and a subsequent kitchen fire. I am going to report this to the UL.
Feb 10, 2011 | Microwave Ovens
No signal through hdmi ports
Check the hdmi cables be sure their in proper working condition, wiggle the cables around see if picture comes up. If not and the cables are good then the hdmi processor on the main board of your TV is defective. Alot of times hdmi ports tend to burn so see if you smell a burnt smell near or around the hdmi ports. but before you do anything be sure sure your TV settings are correct for hdmi....
Oct 18, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Amana AL480DAW- burnt smell, smoke, still fills then dicharges
You are right on about the belt. If the tub every gets jammed by a full load and has trouble turning, the drive belt can get heated up ( kind of like spinning tires on the road...you get a smell and everything still works).
I would suggest pulling the front cover to expose the belts...look underneath. There are usually two one for the drive and one for the pump. I'd replace them both... with extreme heat, it can change the belt enough that it won't operate correctly with bigger loads.
K
Jul 10, 2009 | Amana ALW480DA Top Load Washer
Sony PFM-42V1 bottom half of the screen is a blurry ghost image of top
The Sony Plasma designe not to repair at component level your problem I believe in YSUS PCB you can adjust a few variables resistors on this PCB make sure to mark on the spot before turn you can alway go back to original point, set your plasma on normal channel turn the variable resistor slowly and observe the picture any spot will effect the picture if you can not adjust you need to replace a new PCB
Let me know how you go
Oct 22, 2008 | Sony PFM-42V1 42 in. HD-Ready Plasma...
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
