Question about Juki DDL-8300
My Juki DL 5555 won't pick up bobbin thread
Just got an old juki 5555  and have set it up properly so far according to the manual.  it won't seem to pick up the bobbin thread when i start sewing, Help!
  • 1 more comment
  • jeffacebook Feb 22, 2009
    CAN I USE THE 5530 OR 5550 JUKI TO SEW A FABRIC..PLS EMAIL ME AT JEFFACEBOOK@GMAIL.COM
    TNX
  • Anonymous Mar 18, 2014
    thread the bobbin
    thread bobbin
    Brigadier General:
  • 8,619 Answers
It is possible that you have the bobbin in backwards. Try inserting the bobbin so that the thread pulls in the opposite direction than it currently does. Also, sometimes you have to really push the bobbin case in to make sure it snaps into place. Other than that, you may have a dull needle...try replacing it, or it just may need an overhaul.
Posted on Jan 30, 2009
  • sew king Jul 24, 2011
    start on top of machine. Is the take up arm threaded. Is the needle in correctly the scarf of the needle needs to facetowards the hook underneath. next and lastly the machine is out of time. lower the stitch size to zero and rotate the hand wheel. on the needle bar you will see a cut groove. rotate needle bar until groove is even with the bottom of the needle bar guide. th needle is now in the correct position to ck timing. tilt machine up on its rests and look at the hook in relation to the needle. the hook should be 1/16 " before passing the needle. or just in front of the needle depending on what weight goods u r sewing. timing from there is easier if you remove the feeder plate and one screw from the feeders in order to see the relation of the hook to needle. remember the needle bar needle bar groove need to be lined up properly. loosen the three screws and move hook to right position. good luck!
Which way does thread come off of bobbin for juki tl 2200 qvp
According to the manual (pg 20), it appears the bobbin turns clockwise in the bobbin case. So when the bobbin is loaded and the thread pulled, the thread direction goes right, then doubles back through the tension mechanism to the left.
http://jukiquilting.com/media/catalog/product/t/l/tl-2200qvp_stand-up_manual.pdf
Dec 04, 2017 | Juki Sewing Machines
My Juki LU-563 stopped picking up the bobbin thread, changed needle, took out bobbincase to look for thread, none, still won't sew because of bobbin thread not being picked up.
If you've properly installed a brand new needle that is correct for the machine, threaded it correctly, checked that the bobbin is installed correctly and the bobbin tension threaded properly, most likely the machine is out of time. In other words, the needle is arriving at the bobbin at the wrong time in order to intercept the bobbin. (You can open the bobbin area, hand rotate the handwheel and watch how and where the needle moves in relation to the bobbin to see where and why it is not connecting.) You can search the internet for web sites and videos that discuss machine timing or you can take it for service.
Nov 09, 2016 | Juki Sewing Machines
Juki.co.jp
Make sure you are threaded correctly. Also be sure that your bobbin is sitting in the casing correctly. If the timing is right and the hook is catching, the thread may not be pulling through correctly. Clean your machine as well. Make sure your tension spring is clean and doesn't need to be tuned up.
May 01, 2014 | Juki Sewing Machines
How to fix bobbin tension on a juki
first clean bobbin case loosen thread tension screw and clean under tension spring, hi pressure air is the best. its important to clean under tension part because material builds up and does not allow the flat spring to put the proper pressure on the bobbin thread. tighted tension (second screw) accordingly. all thread tension depends on thickness of goods being sewn. the heavier the good the more tension u need on top.
Apr 14, 2014 | Juki Sewing Machines
Juki ddl 8700 my machine was sewing fine I put in a heavier (jean) thread. Now it wont pick up the bobbin thread to sew at all? Help?
try changing the needle to one that will work with heavier thread
you may have to change the bobbin to heavier thread also
try adjusting the tension also
Sep 25, 2012 | Juki DDL-8700
JUKI BOBBIN THREAD WILL NOT FEED
Most machines require that the bobbin in the case unspool in a certain direction its considered common knowledge I guess because it doesn't seem to be written in the text of manuals... but is indicated in the photos. make sure it's unspooling correctly.
Secondly. Please make sure you have the correct needle for your machine. Some machines do not use a 15x1 (most common needle) Let me show you. (see photo below) Clearly the 241x1 won't fit into your machine. BUT the 15x1 will go into the machine that requires the 20x1.... and the result is it won't pick up the bobbin thread.
Start there. Then check your timing.
Sep 05, 2012 | Sewing Machines
My juki hzl35z will not pick up the bobbin thread suddenly! Help!
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
Apr 26, 2012 | Juki HZL35Z Mechanical Sewing Machine
Juki TL-98QE thread comes out of needle, won't pull up bobbin
It can be many things but first make sure the needle is in correctly, follow the manual to be sure, if it still does not pick up the bobbin thread you may want to bring it to a repairman to see if it is out of timing.
Jul 06, 2009 | Juki TL-98Q
Juki 5555
You probably need to insert a new needle but here is a link that should help you Claven.These things happen to all of us at one time or another
Jan 23, 2009 | Juki MO-655 Mechanical Sewing Machine
Juki DDL-8300 Logo
757 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
