Question about Kirby Sentria 192006 Power Cord
Kirby cord has a short in it
My Kirby stopped working and when I wiggled the cord near the electrical socket it would turn on and off.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 88 Answers
Cable overheated at bottom joint, blown wire internally, will have to replace cable. phone 0800 294 4692 for new cable 27.95
Posted on Jan 15, 2013
3 Suggested Answers
SOURCE: my kirby was working fine.cord put out of socket.
I had a simular problem and went and bought a nother than realized that the bag wan't locked into place it wont start unless the bag is locked you may thy that my son just bumped the wall and I guess it just jared it loose I guess
Posted on Jul 19, 2009
mc1bean
  • 3053 Answers
SOURCE: How do I change the electric cord on my Kirby vacuum?
Hello, youngh
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about vacuumcleaners and possibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/vacuum-cleaner.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 29, 2011
I have a kirby G7D ultamite, I recently replaced the switch, it worked for two weeks then it hasnt turned on since. Also I checked the cord, it has power going to it. Please respond asap thank you.
The switch has probably come lose, have you checked the motor to make sure it is good? Usually the cord will short out right by the motor assembly try to wiggle it while plugged in and see what it does, its most likely the cord I recondition kirbys and never have I had a problem with the actual vacuum only the cord.
Nov 21, 2012 | Vacuums
Kirby won't start. cord got stuck and it stopped, but after I wiggled it, it worked again. Then the next time I couldn't get it to start. took cover off of cord, it looks fine, no fraying. Its an older...
The problem is most likely a bad cord. Take off the cord cover on the side of the motor unit, and pull the cord straight out to remove it. The cord can then be tested with a voltage meter, and replaced if necessary.
Jan 24, 2011 | Vacuums
The unit will not run.
Check cord on machine. Plug in and turn on wriggle cord near powerpoint and then near machine and all over, if it starts and stops the cord needs replacing
May 02, 2010 | Kirby G4 Bagged Upright Vacuum
My Heritage II just lost power in the middle of vacuuming. The switch will turn on but no power.??? What is wrong?
It could be the switch that has become defective (the 'feel' of the switch may be different, but needs to be checked with a meter). Another possibility is that the cord has developed a loose connection at or near the power plug. Turn the switch on and wiggle/push the cord near the plug. An intermittent connection is indicated by the motor turning on and off. If so, cut the plug from the cord (they are usually a molded device that can't be serviced) and install a replacement plug from a hardware store or home center. If the switch is determined to be bad, order a new one from an appliance parts store or vacuum repair center. Good luck!
Feb 20, 2010 | Kirby Heritage II Vacuum
Blue sparks from motor stopped working
either cord shorted out or switch failed would replace cord first if that doesn"t work probably have to take into repair shop
Jul 04, 2009 | Kirby Vacuums
My vacum is not powering up
Reason number 1 (not sure why Kirby Co. still has not fixed it) - improperly installed outer bag. You have to push the bag all the way to the unit so it presses the safety switch that is between exhaust and the vacuum shell
Reason 2 - defective cord - try wiggling it. If you know how to do it - try removing cord and supplying power directly to the unit using another cord or wire (ONLY if you know how to work with electricity.If you get zapped - do not blame me)
Reason 3 - bad power switch (instructions on how to replace it HERE)
Reason 4 (very unlikely) - motor KAPUT
Apr 07, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I have aKirby Diamand series 4 years old
Reason number 1 (not sure why Kirby Co. still has not fixed it) -improperly installed outer bag. You have to push the bag all the way tothe unit so it presses the safety switch that is between exhaust andthe vacuum shell
Reason 2 - defective cord - try wiggling it. Ifyou know how to do it - try removing cord and supplying power directlyto the unit using another cord or wire (ONLY if you know how to workwith electricity.If you get zapped - do not blame me)
Good Luck
Rocky
Apr 04, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Vacuum stopped working
Sometimes after years of use the power cord can break internally where you won't see it. Look for damage or twists in the cord. With the vacuum turned on wiggle these areas between your hands and see if it tries to run. If so replace the cord. If not the switch may be bad or the motor needs to be serviced. Good luck. Please rate me so I know if I helped.
Dec 30, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5 intermittent power
I would say that it is a short in the power cord.
Try my troubleshooting guide. It helps with do-it-yourself Kirby repairs. You'll also find links to directions, parts (cords too!!) and free repair guides!
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Jul 31, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby Sentria 192006 Power Cord Logo
52 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
