Question about Kyocera FS-1118 Printer
Kyocera FS1118 mfp gives error code CF 040 after start up
Machine gives error code after about a second or two after saying ready to copy. Its not the mail board i already replaced it with one that i know works 100%. Any ideas? I think it could be engine board but not sure....
  • 622 Answers
Do a google search for the service manual and then lookup the error code in the service manual
Posted on Dec 24, 2009
KYOCERA FS 1118 MFP SHOW ERROR CODE C6000 WHAT B I CAN DO
replace the fuser will fix that. Or if you want to stip it down check the lamps and if their ok change the thermistor and thermostat. But your better off just replacing the whole unit
May 04, 2014 | Kyocera FS-1118 Printer
My kyocera FS1118 MFP displays C6400 error. Can you help me?
C6400 indicates that the engine board is not recieving the correct signal.
I would suggest that you turn off the machine and ensure that the cable that runs from the document feeder at the top rear of the machine into the connector on the rear of the machine (if fitted) is securly tightened.
You can also try turning the machine off at the wall for 10 minutes.
If this fails you will need to call out a technician.
Jul 21, 2011 | Kyocera FS-1118MFP Laser Printer
Not scanning...error code 720f
Software trouble error code
720f Error: Unknown error
Causes:
Unable to determine the
cause.
Check procedures/corrective measures:
Turn the main power switch off and on.
Jan 14, 2011 | Kyocera Km-3060 Mfp Copier Copy Machine...
Kyocera FS1118 mfp
FS1118 scanning issue - this may sound like a long process but its easy...
Just create a folder called scans in your c:/ drive right click and share the folder
Go to the kyocera command centre (type the ip address of the machine into your browser, taking note your machine must be networked)
Once in kyocera command centre
Click on basic
on the left menu select address book, contacts
create a new contact and under SMB
only insert your computers IP address in the host field
and insert the file name scans in the path field.
Click submit...
Once complete go to your machine
insert a page to scan, select the send button
press the address key
select the contact you created
select ip address press enter
now press 2 on the keypad
press enter
press 2 again
enter again
and then press the green start button once complete..
The scanned document will appear in the scans folder
Aug 01, 2008 | Office Equipment & Supplies
Error. Power Off
You have Firmware problem.You must download latest firmware for this machine. After that copy firmware files on CF card type 1. Just put CF card with files in CF card slot in printer( There is slot on the back side of printer.If you have network card you must remove it to access slot.Switch on printer.....After correct download all LEDs blinking.Switch OFF and remove CF card.
Oct 23, 2007 | Kyocera FS-2000D Laser Printer
Kyocera FS-1118 Printer Logo
1,079 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
