Question about Sharp LC-40D78UN LCD TV, 40 widescreen Diagonal Size, TFT active matrix Technology, 1920 x 1080 Resolution, 1080p FullHD Display Format, 16:9 Image Aspect Ratio, 120 Hz Enhanced Refresh Rate, 120Hz Fine, Motion Enhanced Motion Enhancement Technology, Progr
My sharp tv model LC-40D78UN is pink in his color resolution
I need to restore de color resolution in my sharp LC-40D78UN to normal because is to much red
  • 53 Answers
SOURCE: sharp aquos LC-37D4ou
What kind of connections are you using?
If component (red, green, blue) double check to make sure they are seated properly. I'm thinking it sounds like the blue one got loose.
Posted on Mar 27, 2008
thaurfen
  • 623 Answers
SOURCE: sharp LCD COLOUR TV MODEL
access tv system through menu change to auto or ntsc
Posted on Aug 09, 2008
SOURCE: remote control tv codes for sharp lc-32sb24u tv
I need the remote codes for sharp LC-32SB24U tv. Thank you!
Posted on Nov 23, 2008
dsacco86
  • 1077 Answers
SOURCE: i need to receive a manual on the operation of my sharp tv
I believe your TV is a LC-32SB24U, not LC-325B24U.
You can download a manual at www.sharp.ca/manuals
Posted on Feb 21, 2009
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
Why dose my sharp aquos lc-40d78un power on then turns right back off
No reset button. Probably a problem with the internal power supply.
Jun 09, 2014 | Sharp LC40D78UN 40 in LCD TV
Have sharp quos 52" screen went pink. Can still
Hi, My guess is your daughter messed it up. Go to menu and color and reset to default should fix it.
You may have to adjust color for your best viewing. Good luck.
Sep 27, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I would like to obtain a product manual for my Sharp LC-40D78UN. I need to access the CC caption option.
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
May 01, 2011 | Sharp LC40D78UN 40 in LCD TV
How do I change the resolution on my Sharp Aquos LC-69E88UN from 480i to 1080p. My satellite box is HD and the tv says its on 480i. Any help would certainly be appreciated
Do you mean the LC-60E88UN? The LC-69E88UN isn't listed at Sharp's USA web site.
Try a different channel; different programs will have different resolutions provided (particularly the local stations). How are you connecting the TV to the satellite box? If you are not using component or HDMI, then get the appropriate cable for whichever of those is compatible with your satellite box. Then change switch the output of the satellite box and switch the input if needed for the TV.
With DirectTV, there is a setup menu option to change the output resolution to the native resolution of the TV. So check that. Menu > Fav's and Setup (press Select) go to HDTV > Video tab. Set Native option to On. The only issue will be that channel changes will be slow as the receiver checks the native resolution. Dish Network probably has a similar feature but it may be in a different menu area. Check your documentation. Both companies have manuals online when you look up the equipment.
I hope this helps.
Jan 22, 2011 | Sharp LC-32D64U LCD TV
Is the Sharp LC32D47UT 32-Inch LCD HDTV suitable for use in Australia
Quite possibly as it can cope with NTSC and PAL
The elegant AQUOS® LC-32D47UT easily enhances the decor of any family room, living room or den. With a 16:9 aspect ratio, HDTV resolution of 1366 x 768 and breathtaking color purity, it is a next-generation TV to carry you into the high-definition future. The LC-32D47UT features a high contrast ratio, 6ms response time and wide viewing angles. The LC-32D47UT includes built-in ATSC/QAM/NTSC tuners, 3 HDMI™ and 2 HD Component Video inputs as well as a D-sub, 15-pin input for PC compatibility. The LC-32D47UT features a black cabinet, and the included table stand easily removes for wall mounting applications.
Features
  • True 16:9 - widescreen aspect ratio with 1366 x 768 HDTV resolution.
  • Built-in ATSC/QAM/NTSC Tuners - provide access to DTV and available analog TV channels.
  • High Brightness - Sharp LCD TVs are very bright, so you can put them virtually anywhere - even near windows, doors or other light sources - and the picture is still vivid.
Jan 08, 2011 | Sharp 19 in. LCD HDTV
I need to change resolution on my Sharp Aquos
it is most likley the setting on the cablr/sat box
Jul 24, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Screen has green corner at first and may changeto pinks and green
It sounds like the De-gauss circuit isnt working. It demagnetizes the TV tube.
It's something only a tech can fix though.
Jan 02, 2009 | Zenith C27V36 27" TV
LC-26D43U LCD COLOR TELEVISION
theres no wires...de dedede...
Dec 26, 2007 | Sharp LC-26D43U Television
Sharp LC-40D78UN LCD TV, 40 widescreen Diagonal Size, TFT active matrix Technology, 1920 x 1080 Resolution, 1080p FullHD Display Format, 16:9 Image Aspect Ratio, 120 Hz Enhanced Refresh Rate, 120Hz Fine, Motion Enhanced Motion Enhancement Technology, Progr Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
