Question about Black & Decker Blenders
Looking for black and decker 550w 5 speed blender owners manuel
I recently got this blender as a gift and used it a few times to make smoothies. the other day it just stopped working, the buttons lit up when i pressed them, but the blender didnt start blending. it didnt make any noises like the blade was stuck or like the motor was running at all. i know there was a reset option for this blender but didnt keep the manual. i was hoping to get the manual before trying to return it as i dont have the original box and dont know if it will be accepted
  • 351 Answers
SOURCE: Blade won't spin
Check the blade with it off the base and make sure that it spins freely. Check the spindle on the base and see if it feels hard to turn. If the spindle turns too easy , then the connection inside the base is broken and needs replacing.
Posted on May 04, 2010
Testimonial: "Great feedback! thanks! "
SOURCE: blinking lite in black and decker cyclone blender
Throw the Black/Decker away. I am going to. This is my second blender form them that has done the nonresponsive red light blinking thing. I figured that the first one was a lemon; however, it must be that Black/Decker is only concerned about meeting walmarts demands on price. Black & Decker's saying should be - Who needs quality when you can pay less the first time.
Posted on Jun 26, 2010
SOURCE: Black & Decker BLC12600B 650W Cyclone 12-Speed
I need a new glass jar for my Black
Posted on Sep 02, 2010
  • 3 Answers
SOURCE: I have a Black &
Should just need to reset. Try unplugging and waiting a minute or two.
Posted on Feb 02, 2011
SOURCE: Waring Pro Blender is leaking and blade assembly is loose
I know this is an old, old post, but I could not find a solution anywhere, so hopefully this will help someone. We have a model 51BL25, similar to scottman55's blender, and it had the same problem. There are two separate nuts in the blade assembly. One holds the blade on, and the other holds the seal tight. When the latter gets loose, the blender shakes and leaks.
To fix it, first you have to remove the top nut holding the blade on. I had to get in there with pliers, but a ratchet with an extension would be perfect. This nut is right-handed ("normal"). Once that nut is loose, you can remove the nut and the blade. You will also want to remove the washer immediately under the blade (take note of which side goes up).
Now, you can pull the whole axle out by the wheel on bottom of the blender. This exposes a really thin, flat nut. In my case, this nut had come completely off, so nothing was really holding the seal together at all. Again, make sure you remember which direction the nut goes -- it is not quite symmetrical. That nut is what comes loose when the blender starts leaking. By the way, it is a left-handed nut, so it screws on counter-clockwise ("backwards"). Screw it in tight, then put the rest of the blade assembly back together, and your done. If you have the right tools, it should take only maybe 5 minutes.
Depending on your problem/model, this may or may not solve your problem. Hope it helps!
Posted on Sep 09, 2011
Try Googling (Black & Decker)(550w)(manual) without parens.
Jun 22, 2017 | Blenders
I turn the blender on and a blue light turns on, blender isnt functioning, is it burnt out, is there a reset button besides unpluging it for a few minutes?
Unplug the blender. Use a baking soda and vinegar solution to clean the metal contacts on the bottom of the metal blender blade. (You will see a small circular inverted washer looking thing). Use the solution on the main blender unit also. (You will see a small circular metal piece in the center) Scrub them both with the solution and wipe. These seem to be some type of sensors. I then replugged the blender back in and it worked for me!! Good luck!
Aug 08, 2012 | Black & Decker BL1900 5-Speed Blender
Blender stopped working
Sounds like the motor burned out.
Jan 30, 2012 | Black & Decker Blenders
We have a Black & Decker BL9000 blender. On top of the base, there is a plastic disc that meshes with the bottom of the jar and drives the blades. I think one of the kids was making smoothies and...
Available replacement parts can be found here:
http://www.directpartsandproducts.com/blenders-bl9000-c-1_4_60.html
or here:
http://www.abtecparts.com/Black_&_Decker_blenders_BL5000BL6000.htm
I have not seen the drive gear made available. You could try making an inquiry with either of the above sites to see if they can locate a replacement. Alternatively contact a local small appliance repair shop; they may be able to scavenge the part from another blender.
May 16, 2011 | Black & Decker BL9000 Blender
I was using my blender and stopped to add more ice for a smoothy mix, but when I tried to start it up again the lights began flashing at random but the blender would not work. Why?
It sounds like it may have overheated. Firstly, Switch it off and let it cool down for a few hours. Quite often it will burst back into life. If not, you will probably need a new control board. These come in several variations:
9708845 Silver 110v 9709339 Black 110v W10291857 Silver 240v
Mar 25, 2011 | KitchenAid KSB560 5 Speed Blender
Blinking lite in black and decker cyclone blender keeps blinking and blender wont work at all!
Jun 16, 2010 | Black & Decker BL1900R Blender
Blenders Logo
123 people viewed this question
Top Black & Decker Blenders Experts
john h
Are you a Black & Decker Blender Expert? Answer questions, earn points and help others
