Question about Canon imageRUNNER 3300 All-In-One Laser Printer
I have canon ir3300 copier, last week i change new drum. i got the printout every first copy have problem. 3 to 4 mm bar code came the paper corner. today i received the error mesg. original scanning area dirty and print quality is very bad. what can i do? Please help me.
  • Carlos Perez
    Carlos Perez May 11, 2010
    i cant fully get this.
    please clarify, you get the 'dirty scanning area' error or you get any other error code? i fthe problem is the dirty area when using the AFD all yoy gotta do is clean up the scanning area with a wet rug. there's a little glass to the left of the big platten glass. clen them both. then turn off-on and check.
ERROE E000602-0003
Posted on Feb 08, 2009
Error E000001
Posted on Mar 05, 2009
IR 3035 black copy
<Cause>
On some types of paper (especially those with a high calcium carbonate content), toner offset to the fixing film can
start to cake, moving from the fixing film or the pressure roller to the face or back of paper.
<Field Remedy>
Use the following service mode item to change the timing at which the fixing pressure roller is cleaned:
COPIER>OPTION>BODY>FIX-CLN
0: disable cleaning (default)
1: execute cleaning during last rotation every 500 printouts
2: execute cleaning during last rotation every 200 printouts
3: execute cleaning during last rotation every 100 printouts
Feb 14, 2017 | Canon imageRUNNER 3035 Black and White...
Canon ir 3030 printout will be black
Verify charge corona, when you start a new copy, open lateral door when paper is in the right of drum, then look if the drum is full covered with toner.
Dec 05, 2014 | Canon imageRUNNER 3030 Black and White...
How can I better the print quality of Cannon IR3300
How many copies drum made?Maybe you have to change it.Clean the optic mirrors platten glass,transfer roller...
Jul 31, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
White strip on copy
While you make an printout, open cover when the paper is approx. in drum section.Remove drum, and you will see the picture on it, if the piece of picture missing, that is your white strip. On the drum you will see two blue small handles with markings pull. Dismantle it with help of this handle and you will be able to see the developer unit ( magnetic roller cover with toner ). If the white stripe also on it change developing unit, and drum unit.
Jun 22, 2010 | Canon ImageRUNNER 1670F Copier
Canon ir3300 - print but double image and missing a few line
HI,
how many copies do you have, when the last time did you change the drum unit or fixing film?
Try first to check the fixing film if you have double smudged and non fixated copies.
Nov 09, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Front & Back copies, paper has jammed cadrej side some time only.
You need to replace not only the pickup roller but all three paper roller: Pickup, Feed, Separation.
Aug 08, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Trying to copy 3 checks on one page, copier rotates the image and cut part off
Hi!
I'm not sure why the rotation is occurring, but I believe you can find the solution in one of the manuals you can download here:
http://www.mymbs.net/codo.html
Please let me know if this helps!
Bob
Oct 08, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon Image Class D860 copier purchased 2005 - KAB-15948
dog ears are usuallycaused by paper hitting something before the fuser or at the fuser. the claws or fingers that ride on the hot rollers are getting worn or are out of place.
to determine the exact location, stop the copy at different locations by
1- make a copy
2- stop the copy by turning off or openning a door
look at the paper does it have the dog ear at that location? no stop it a little further until it does.
My guess is going to be the claws or fingers on the fuser roller.
Good luck
Dec 11, 2007 | Canon DHD860 Copier
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
675 people viewed this question
old marine
old marine
