Question about Samsung S630 Digital Camera
Horizontal lines in pictures
I think there is a shutter problem. lines present in all pictures, but none in video.
    Genius:
  • Samsung Master
  • 1,019 Answers
This needs shop repair.
Posted on Jan 26, 2013
How do I get rid of horizontal lines
The picture should be free of horizontal lines. If the lines are present on the TV screen, press the SMART button on the remote control and select Settings > SUPPORT > Picture Test. This menu will appear on the test picture. Select which option best describes the result you have.
Aug 21, 2017 | Televison & Video
I have horizontal lines
The picture should be free of horizontal lines. If the lines are present on the TV screen, press the SMART button on the remote control and select Settings > SUPPORT > Picture Test. This menu will appear on the test picture. Select which option best describes the result you have!
Lines in pictures
There are two common faults for this problem. 1 is shutter failure and the other is sensor failure. To determine which is simple. For shutter failure put the camera in full optical zoom. Turn off the flash and look through the lens and take a picture. You should see the shutter completely cover the lens inside. Any gaps will result in over exposed pictures or horizontal lines. the other is video mode. if the problem is apparent in video mode too then sensor failure is the likely problem.
Aug 24, 2012 | Sony Cyber-shot DSCS2100 Digital Camera
All pictures that I take present horizontal line, so tell me what,s reason and what can I do !
The reason for these lines is your shutter sticking or not firing at all.
The video function should be unaffected due to it not using the shutter and is the easiest way the determine the fault.
What causes it is moisture residue building up on the shutter leafs.
On this model if camera it is quite difficult to rectify because the shutter mechanism in side the lens is a sealed unit. It can be done however but takes longer than other models of fuji camera because of this sealed unit.
Cheapest option would be to find a second camera for donor parts. Even if it is damaged you can still remove the shutter mechanism and swap it over.
Jan 06, 2010 | Fuji FinePix F470 Digital Camera
Horizontal lines on lcd after taking photo
Sticking shutter. It will require either cleaning or replacing.
lines on photo's are due to the shutter sticking.
the video function does not use the shutter so is un affected.
Dec 11, 2009 | Fuji FinePix F470 Digital Camera
FinePix F470 Lines on images and faded colors on photo mode.
You have over exposed pictures due to the shutter sticking.
The video is the clue to the problem. It doesn't use the shutter.
Shutter needs to be cleaned. This is no easy task im afraid
Sep 11, 2009 | Fuji FinePix F470 Digital Camera
Fujifilm camera f470 white lines problem horizontal
your shutter is not closing over the lens completely. try taking video, that should be ok. your lens will have to be stripped down to clean the shutter
Apr 02, 2009 | Fuji FinePix F470 Digital Camera
Overexposed photos in otherwise normal settings in casio ex-s500
It is the shutter (or at least it was for me) I found a simple test here: http://www.mydc.com.tw/repair/knowledge_en/casio-exilim-ex-s600-overexposure-t17.html
I repaired it myself, but it took me a whole afternoon and lots of patience.
The hard part is taking the camera apart, once I got to the shutter I just activated it manually so to dislodge any pieces that might have gotten jammed, then placed it back together again and it worked! :).
It's really hard to take apart, it's like a puzzle sometimes, to find which screws are keeping it together. I also had a bit of hard time when it came to put the zoom back together again.
But I guess it beats throwing the camera away.
I'm still puzzled on how the CCD works so that an overexposure would make horizontal overexposed lines, but everything points to that. Fixed shutter, lines be gone.
Apr 29, 2008 | Casio Exilim EX-S600 Digital Camera
Pictures are a mass of horizontal lines.
the flex wire of the shutter is open already and the shutter is not closing when you take a picture and is overload thats why a horizontal lines appear when you take a picture..it need to be service your camera now...do not attempt to open the lens assembly cause it is too difficult to fix the flex wire of the shutter if you are not a technician...
Sep 25, 2007 | Canon PowerShot A70 Digital Camera
Samsung S630 Digital Camera Logo
21 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
