Question about Ovens
My jenn air double oven won't unlock after cleaning
W246W
    Sergeant:
    Champion:
  • 249 Answers
What you need is a new Latch Assy part number 12001106
Posted on Jan 14, 2013
  • 833 Answers
SOURCE: jenn air double ovens
First, with the door closed, find the screws at the bottom of the door and remove. With an assistant, open the door and remove any side and inside screws you find. The door will separate into two halves. Be aware that most glass is not clipped in...they can fall and break. Remove the front panel from the door...the door may try to slam shut. To clean the glass, use a blue cleaner and a scrubby or very fine steel wool rubbing gently. Scratches are not allowed! Take pictures of what you're doing so you can replace. Be careful of brittle door insulation.
Posted on Dec 07, 2007
Gigatech
  • 259 Answers
SOURCE: Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Posted on Dec 09, 2007
SOURCE: Problems with Jenn-Air Electric Double-Wall Oven
Try changing the clock assembly --
http://www.partselect.com/ModelFrames.aspx?ModelID=221346&ModelNum=WW30430P&mfgModelNum=&ManufactureID=1&Selected=51238&Position=1&mfg=Maytag&Type=&Mark=1
here is a link to the diagram.
PS120923
Electronic Clock Assembly (Series 10)
Help with series numbers
here is the part number.
Posted on Feb 17, 2008
706Cajun
  • 34 Answers
SOURCE: Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Posted on Apr 25, 2009
taran_2005
  • 10515 Answers
SOURCE: Jenn-air electric double control does not work - clock is on
Disconnect the Power Supply for few minutes, say 30 minutes and then Turn the Oven ON.
Do you see any Error Message?
How old the Unit is?
Do you have any Experience to Fix this?
Do you have all the tools?
Let me know, so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 30, 2010
I just cleaned my Jenne Aire Expressions double oven. Now its flashing and beeping "FC" how do I turn it off?
Check your wiring harness, if its OK then replace the power relay board. A faulty board can cause fan issues and pull up the error you are seeing.
Mar 29, 2011 | Jenn-Air JJW9627C Expressions Collection...
After self cleaning process oven door would not unlock replaced display panel F3 error fan runs constantly lower unit still works upper unit still will not unlock
F3
or
F4
Shorted or open oven temperature sensor
(RTD) Check sensor harness and harness connection
between oven sensor and oven control. Replace oven temperature sensor (RTD) if
wiring is ok.
Dec 04, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
I have an older jenn air double oven and I locked it to clean and now I don't know how to unlock to open it again
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Aug 24, 2010 | Jenn-Air Ovens
Jenn air oven
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
F2 code on Jenn air double oven
One website said its a relay board problem. Years ago I replaced the entire electronic board and did it myself and I am not overly good at such stuff, so it can be done if you find the correct part. I am having that problem and am searching for a relay board or whatever it is.
Dec 07, 2008 | Jenn-Air JJW8230D Electric Double Oven
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Jenn air double ovens
Oct 30, 2007 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
49 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
