Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Bosch dishwasher sgs43c02gb cycle problem.
First of all thanks to everyone who posts on here as it has helped me get to where I am at the moment.
My dishwashwer just gave up the ghost, so with help from here i have got it to go so far then stops.
I had to change the inlet solenoid for starters as no water was coming in. It would then rinse and empty and stop, so I cleaned out the float switch ( very sludgey lol).
Now I have got to the heating but it stops with water in the bottom and the end light comes on.
I know what you are thinking, the heater matrix. This is where it gets confusing. While I had my head down and turning on the washer, I didn't realise that my son was leaning on the three program buttons. It started with two program buttons flashing. I let it run. Believe it or not it did a cycle and warmed up the water.
Controler unit faulty?
Does anyone know where I could get a schematic or have any ideas, to try and save me £100.
Thanks in advance. Ian
I found the problem for pump noise & water in bottom. The dishwasher hose connection under sink had small plastic piece stuck in narrow elbow
Posted on Feb 13, 2009
Incessant end of cycle beep. Can I stop it? My new Bosch shx68p05uc drives us nuts. My 88 year old mother-in-law sleeps near the kitchen and I cannot run this dishwasher at night due to this darn...
Welcome to FixYa.
To turn the volume down of the signal or to turn it off entirely is as follows...
Hope that solves your incessant beeping problem. Thank you for choosing FixYa and good luck. Please take a moment to rate the info provided here as well as a brief testimony is appreciated.
Regards,
Macmarkus :)
Apr 19, 2011 | Bosch SHX68P05UC Dishwasher
I am just looking for the decible rating on the bosch shu5306uc. Can you help? MINE IS ALMOST TEN YEARS OLD AND HAS STOPPED WORKING AND WOULD LIKE TO REPLACE WITH SAME DB LEVEL OR BETTER WITHOUT...
Welcome to FixYa.
I see your post is roughly a week old, but I`ll post an answer anyway, hopefully you`ll see it.
The SHU53** series Bosch dishwasher has an advertised "silence rating" of 52dB via the AVS² insulation system.
By today's standards you should be able to purchase a $500 or $600 Bosch Ascenta SHX3AM02UC with a "silence rating" of 53dB.
Hope that answer's your question. Thank you for choosing FixYa.
Please take a moment to rate this answer accordingly and leave a testimony if you feel it`s warranted.
Good luck.
Regards,
Macmarkus :)
Sep 06, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
After the wash cycle dishwasher beeps
Hello, welcome to FixYa. While I don't have access to my PC files at the moment as I am on my iphone, I believe this is the procedure for most B/S/H/ built dishwashers ( that means Bosch, Thermador, Siemens and Gaggenau ). To Enable or Disable the Cycle Completion Signal... 1. Open the door, hold down the ?Quick Wash? button and simultaneously turn the Dishwasher on. The ?Quick Wash? light will blink (program mode). 2. While the light is still blinking, push the ?Quick Wash? button. ? If the machine beeps, then the Cycle Completion Signal has been enabled. ? When you push the button again and it doesn?t beep, it means that the Cycle Completion Signal has been disabled. 3. Turn the Dishwasher off to take it out of program mode. I hope this answer's your question. Thank you for choosing "fixya". Please rate the solution favorably if indeed it was helpful, if not please let me know. Good luck. macmarkus :)
Jul 13, 2010 | Bosch 24 in. SHV4303 Built-in Dishwasher
Bosch dw shu043 dishwasher stopped working in middle of cycle
Hi and welcome to Fixya. Based on your post, I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line. Remove the murret's and visually inspect the wire for "resistance burn" and strip the wires back and install new fastener's if necessary to repair. This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance". The end result is no power to the controls. Check it out and post back what you find. Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you. Good luck. Macmarkus :)
May 19, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Restarting the dishwasher
Hi Kathleen,
Welcome to Fixya, you came to the right place.
I`m not sure what model you have, but typically you should be able to select another cycle by choosing a button and pressing it twice quickly.
For instance if you want`"normal" press the normal button twice in 2-4 seconds and it should go to normal cycle.
Let me know how you make out. Good luck and thanks for visiting "fixya".
Please take moment and rate this solution favorable if indeed it helped you, if not let me know and we`ll move forward from here.
macmarkus :)
May 05, 2010 | Bosch Dishwashers
I have a BOSCH model 53L06UC dishwasher and was
every bosch dishwasher unit is different. you can get odor from different source. #1 solution to fight odor is the proper maintenance. every month run the cycle with just a cup of vinegar on a hot wash. i am a old bosch tech and alot of people dont add the jet dry properly. this is for drying,spots and-cleaning you must add the jet dry or rinse agent (same thing)into the compartment. close compartment,then lower and raise door 3 times,then fill again repeat until you cant add anymore then it is filled.if this help please send me a 4 thumbs up post. thanks
Feb 28, 2010 | Dishwashers
Bosch shu4006uc dishwasher timer problem
REPLACE YOUR MODULE. IM A OLD BOSCH TECH. POST 4 THUMBS FOR THE INFO THANKS
Feb 08, 2010 | Bosch SHU4006 Dishwasher
Pump continues to run
make sure you dont have water sitting under dishwasher in tray. it can cause pump only to run. If there is water in bottom, look under water valve, there is a float-is it surrounded with water?
Jan 01, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
SHE45M05UC
the problem is the float switch is stuck
Dec 11, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
383 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
