Question about Thomson 29DM400 29" TV
Unable to get full color, imges often turns pink/orange
Images often portrayed in orange/pink tone, after a day/two I would get amazing full colour image, sound/audio is perfect. My Tv is 16months old and often left on for 14-15hrs daily but the problem started 2 months ago. I'm sure it turns pink/orange due to lack of green and yellow tones. Please help as I love my TV very much and scared to take it to a technician because I might be taken for a ride/overcharged.
    Brigadier General:
  • 8,619 Answers
Hi!
Go into the menu settings and check whether it has a warmth tint function o, if on then turn it off and adjust the settings accordingly.
If this doesn't work then Maybe a power surge has damaged the box. Try using a different scart/hdmi cable which you know works... it could be a damaged wire.
If not, unplug the box and leave it with nothing connected for 24 hours to get rid of the static and try again. Thanks Rylee
Posted on Jan 23, 2009
  • Rylee Smith
    Rylee Smith Jan 23, 2009
    If this doesn't help then what i know is that the convergence circuit going bad. it will be hard to say till it goes all the way out. now as far as you doing a repair... i would say if you solder very good and can use a meter?? then you can do a repair. if not you will need a repairman and a cost will range around 300.00.
    You have to change stck ics of your tv, Look up for stk IC's (look part no.) on e-bay or amazon.
HP PhotoSmart C3140 All-In-One Inkjet Printer will not print in color
ok let's try this
Step One: Remove, inspect, and reseat the problem cartridge
Figura 4: Opening the printer cover (make sure the power is on)
c00308401.gif The print cartridge may not have full electrical contact with the printer. Removing and reinstalling the cartridge may help.
[img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
NOTA:HP cannot guarantee the quality of remanufactured or refilled cartridges.
  1. Make sure the printer is on. Press the Power button if it is not lit.
  • Open the printer cover, then wait until the print cartridge carriage is idle and silent.
  • Press down lightly on the end of the problem cartridge to release it. Figura 5: Removing the tri-color cartridge
    [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/95/c00484998.gif" alt="" border="0">
  • Slide the cartridge out and inspect it: [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/caution.png" alt="">
    ATTENZIONEDo not touch the copper electrical contacts or the ink nozzles.
    Figura 6: Electrical contacts and nozzles
    [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/640/c00211537.gif" alt="" border="0">1 - Copper electrical contacts
    2 - Nozzles
    Check the electrical contacts for debris.
    Make sure all the clear nozzle protective tape has been removed.
    ATTENZIONEDo not attempt to remove the copper electrical strip!
    Figura 7: Removing the clear nozzle protective tape
    [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/767/c00211538.gif" alt="" border="0">Printer Reference Guide supplied with your printer.
  • If the cartridge is compatible, reinstall it in the printer:
    • Cartridges marked with a triangle go into the left carriage slot.
    • Cartridges marked with a square or pentagon go into the right carriage slot.
    Figura 8: Sliding the cartridge into the carriage
    [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/222/c00484999.gif" alt="" border="0"> Figura 9: Pushing the cartridge into place
    [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/408/c00485000.gif" alt="" border="0">
  • Step Two: Clean the problem cartridge contacts
    1. Gather the following items to clean the cartridge and carriage:
      • Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
      • Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
      • Sheets of paper or a paper towel to rest the cartridge on during cleaning.
    2. Open the cartridge access door and wait until the carriage is idle and silent.
    3. Disconnect the power cord from the back of the printer.
    4. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up.
      NOTA:Do not leave the cartridges outside of the printer for more than 30 minutes. If the cartridge is outside of the printer for too long, the ink can dry and clog the nozzles.
    5. Dip a clean foam-rubber swab or lint-free cloth into distilled water, and then squeeze any excess water from it.
    6. Clean only the copper-colored contacts
      Figura 10: Clean the contacts
      [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/172/c01954145.gif" alt="" border="0">1 - Copper-colored contacts
      2 - Ink nozzles (do not clean)
    7. Repeat these steps for the other cartridge.
    8. Lightly moisten another cotton swab with distilled water, and then squeeze any excess water from the swab.
    9. Use the swab to clean the electrical contacts in the carriage, located inside the printer on the carriage slots.
      Figura 11: The electrical contacts in the cartridge slots
      [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/869/c03743456.gif" alt="Image: The electrical contacts in the cartridge slots" title="Image: The electrical contacts in the cartridge slots" border="0">
    10. Wait 10 minutes to allow the cartridge and carriage electrical contacts to dry.
    11. Reinstall the cartridges.
    12. Close the cartridge access door.
    13. Reconnect the power cord to the back of the printer.
    14. Press the Power button to turn on the printer.
    15. Try to print a page.
    16. If you are still unable to print, repeat these steps to clean and reseat the cartridges. Multiple cleanings might be necessary to restore printing.
    Figura 12: Print carriage contacts
    c00906469.gif Step Three: Repeat reseating and cleaning steps If the problem is not solved, repeat the reseating and cleaning procedures above
    Apr 04, 2014 | HP PhotoSmart C3140 All-In-One InkJet...
    Tip
    How To Install Replace Fuel Filler Neck Oldsmobile Alero 99-04 1AAuto.com...
    http://c.fixya.net/fixya20/uploads/images//images/utube.png
    on Feb 14, 2012 | 2003 Oldsmobile Alero
    Tip
    How to Rejuvinate Your Motorbike Leathers
    So here's how to. Its actually real simple but can be time consuming if doing a colour change.
    Can be used for your old faded set, ones you've had a slide in or even if your looking for a colour change.
    [B]1.[/B] Go to any shoe repair shop that sells Leather spray dye's in lots of colors.
    [B]2.[/B] Also you need the leather deglazer.
    [B]3.[/B] Prep leathers, clean, dry and deglaze the area you want to color.
    [B]4.[/B] Mask the area you want to color , this is what is time consuming. it gets real messy.
    [B]Pic of lowside damage[/B]
    [IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/1-5.jpg[/IMG]
    [B]5.[/B] Apply dye roughly 4 or 5 coats (if changing colours, less if just touching up). This takes awhile cuz it take long to dry inbetween coats and work on one area at a time.
    [B]Pic of Repair (still fresh)[/B]
    [IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/2-4.jpg[/IMG]
    [B]6.[/B] When all finished let the Leathers sit to fully dry and cure for 4 days to a week if possible.
    [B]And now for the all important pics.
    This is what the suit looked like before
    [IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/3-3.jpg[/IMG]
    [IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/4-4.jpg[/IMG]
    [B]And after the new colour scheme:[/B]
    [IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/5-5.jpg[/IMG]
    [IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/8-1.jpg[/IMG]
    [IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/7-2.jpg[/IMG]
    [IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/6-2.jpg[/IMG]
    [B]Some close ups:[/B]
    [IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/9-1.jpg[/IMG]
    [IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/13-1.jpg[/IMG]
    [IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/12-1.jpg[/IMG]
    [IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/11-2.jpg[/IMG]
    [IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/10-1.jpg[/IMG]
    [IMG]http://i598.photobucket.com/albums/tt61/Shaved4U/15-1.jpg[/IMG]
    on Apr 27, 2010 | Motorcycles
    Need color codes for spesker wire for 1993
    Good day. The wiring is as follows:
    Left front + orange/gree
    Left front - black/white
    Right front + white/green
    Right front - black/white
    Left rear + pink/green
    Left rear - blue/orange
    Right rear + pink/blue
    Right rear - green orange
    Hope this helps. Good Luck and please rate.
    Mar 08, 2010 | Sony Car Audio & Video
    Hi. I'm trying to print some images but the colours seem to turn dull and washed out, going towards a yellow-ish tone. I have a Canon MP460 and the colour ink is full whist the black is half full. Is there...
    Good day
    Was wondering if you are using refills or orginal catridges, if so, get a printer head cleaning kit, so you can clean the head of the printer ink feeder,
    http://www.retrevo.com/d/ds/progress?doc=4ec91b25854bbb510ea419f43c93afe6
    Go to this page and get the manual, may explain to you how to remove the cover and then clead the header,
    feel free to message again
    Jan 02, 2010 | HP DeskJet 5550 InkJet Printer
    Acer Orbicam Colour Problem!
    The display is gone. Replace it.
    Nov 29, 2009 | Acer Aspire 5100 Notebook
    Problem with colour printing. Orange and green
    Wow, that's a really old EPSON printer. The life expectancy of a EPSON printer is just three years, after that, the printer wouldn't work because of the clogged permanent printing head. The authorized service center is unable to repair it because the spares are no longer supplied.
    Throw it to a recycling center.
    Nov 03, 2009 | Epson Stylus Color 740 InkJet Printer
    I bought new ink black and color but i try to print in pink and i can't how can i print in pink
    Hi alexgallo01
    Do you get other colours except pink?
    If that is the case,reasons could be:
    1. there is not enough RED or BLUE in the cartridge.
    2. you haven't selected pink colour on the text or images you are trying to print.
    If you are typing a document highlight the text you want in pink, and choose PINK color for the font.
    Then print the document. The printer will use color closest to your choice, if it does not have the exact color.
    Hope this will help.
    If it help you, please give a rating
    Cheers
    luciana44
    Sep 14, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
    Adjusting color on printer
    There must be a colour adjustemt somewhere. I would look at the printer driver settings first. You might be able to correct the colour balance there.
    Oct 06, 2007 | Brother MFC 420CN All-In-One InkJet...
    Thomson 29DM400 29" TV Logo
    158 people viewed this question
    Top Thomson Televison & Video Experts
     Grubhead
    Grubhead
    Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
