Question about Dell 1110 Laser Printer
Dell 1110 faded print left side
I have faded print on printed paper 2inches from left and 10mm is the area that runs from bottom to top of page. All other printing is fine. I believe it happened after the printer mislined the paper feed into the machine and jammed. I yanked the paper out and am think there may be damage. The print is faded with lines almost running through it. Is the any remedies that I can try to fix this. All replies would be very much appreciated.
    Sergeant:
  • 166 Answers
If you have trid a different toner cartridge, then I would first try a new drum (not sure if toner & drum are in same cartridge, some are so you will have to check that) If not that, then I would suggest the transfer roller bar would be my next suspect if the printer has a lot of copies done on it.
Posted on Jan 13, 2013
  • 6 Answers
SOURCE: paper jam
I used the cardboard backing from an 8x11 tablet; I pushed it into the paperholder; it pushed out a small bit of paper which could not be seen; behold, the paper jam was no longer. I paid a computer repairman $15 to do the same thing with a plastic sheet.
Posted on Jan 18, 2009
  • 10 Answers
SOURCE: Paper feeds to the right and Jams
Sounds to me like there is something in the paper chanel, a staple, paper clip or something small enough to get in there. Have you tried turning the printer upside down and lightly tapping the side to see if anything falls out?
Posted on Mar 14, 2009
  • 31 Answers
SOURCE: Left side of page prints lighter than rest of page
You should contact Dell about returning these for a replacement, it sounds to me like a manufacturer's error.
Posted on Jan 27, 2010
pineworks
  • 4041 Answers
SOURCE: paper jam on Dell Photo 926
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
SOURCE: My Dell 1720dn constantly has paper jams. A
here's one for you. if it is jamming with one sheet almost out (the trailing edges is just out of the fuser. it will also jam the same way everytime. you might try a different brand toner cartridge. I have beening fixing several with this.
Posted on Mar 30, 2010
Print comes out beautifully except for smudges on left side of paper
If the cartridge is not causing the problem then the second most common issue is either a damaged fuser, the part of the printer that melts the toner to the page, or something stuck to the fuser like a label.
Feb 16, 2015 | Dell 1110 Laser Printer
Dell 2135 fading left side when printing
It's possible that this could also be down to a toner cartridge inside the printer. I would recommend running off a copy of the colour laser test page found here.
The colour bars towards the bottom of the page separate cyan, magenta, yellow and black. Hopefully you will be able to notice that one colour is affected more than the others and replacing that colour may help.
Apologies if you have tried anything similar previously.
Oct 31, 2012 | Dell Office Equipment & Supplies
Faded vertical section on a printed page.
this problem occurs due to dust particles in the paper feeder belt (steel rod with rubber ) clean it and print
Sep 06, 2009 | Samsung CLX 3160fn All-In-One Printer
Copier Jam and Uneven Printing
Try a different paper, especially if you are getting alot of paper curl, this is a sign of damp paper, or very old paper.
Hope this is of some help.
Ed
Apr 30, 2009 | Office Equipment & Supplies
HP3600N color fade
It is using the colours to make the grey and the proportion is not correct. Do a calibration.
Dec 23, 2008 | HP LaserJet 3600n Printer
Dell 1110 Printer .....when prints there is a mark every 3/8 " or
You may have a problem with the ink cartridge/toner. Try using a different one and print a sample page.
Nov 25, 2008 | Dell 1110 Laser Printer
Fading on one side of the paper - Dell 1815dn laser MFP
The Printhead IS located above the toner cartridge on this model. There is a small opening that allows the laser light to shine through the case to the imaging unit on the toner, but you can not access the the laser without disassembling the printer.
Even though this is a new toner cartridge, it may be defective, even more likely if it is a non-Dell or remanufactured toner. Try reinstalling the old toner cartridge. Even if it prints light because it is low, if it is uniform across the page then the new toner is defective. Return or exchange it with the manufacture.
Sep 25, 2008 | Office Equipment & Supplies
Only top quarter of page is printed
How can a get the # recalled of a document was fax to.
Sep 02, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Dell 1110 Laser Printer Logo
102 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
