Question about Interactive Health Refurbished Htt 10crp / Ht 120 Robotic Human Touch Massage Chair with Human Touch Technology
The power goes from the plug to the mechanism but doesn't get distributed
The part that doesnt distribute the power has this number HHKP-03175
Electrical power loss
Check your evap system (coal filter under car, purge valve near engine), and also check for any vacuum system leaks..
Jun 21, 2013 | Ford Mustang Cars & Trucks
My 97 dodge ram 1500 V8 magnum has a wire on the left side of the power distribution center that I don't know where it goes
that is the power wire comes from battery to the box through the fuse then powers all the fuses and relays in that distribution box. if your talking about the wire connector with no wire in it. that is an aux power source to run anything needing 12volts like a salter or snow plow.
Mar 20, 2013 | Cars & Trucks
Car turn over put will not start
check if you getting spark at spark plug if no then replace cap and rotor and possibly plugs and wires if that doesn't solve it you may need distributer.if you are getting spark then check if you getting fuel pull off fuel line where it goes into motor and turn over
Sep 03, 2012 | 1994 Lexus GS 300
How do i find the posiyion of 1st cylinder to put in new distributer for a 98 4.3 blazer distributer wasnt marked when took out
pull out number 1 plug and put a straw or soft object in hole. turn engine by hand on front crank. when the straw or similar is on the very top, just before it goes down ! this is top dead center, then put in distributor with the rotor button facing the number 1 wire on distributor cap, replace number 1 plug and adjust the distributor, buy turning it after it is installed in vehicle.and vehicle is running. if you do not know where number 1 plug is. call the auto parts store. they should be able to tell you. auto-zone etc. good-day !
Jan 15, 2012 | Cars & Trucks
Purchased Vistaquest FS-503 converter. Used two days. Screen doesn't light up and closing cover doesn't turn off the power (light continues showing through the slot for slide holder). Any easy...
take it back for exchange or a refund. A capacitor in the circuit is at fault not distributing the needed power to operate this camera
Jun 26, 2011 | VistaQuest Cameras
How to put in a distributor in a 88 chrysler conquest
Make sure the timing mark on the harmonic dampner is at tdc. drop the distributer in the hole so as the distributer gear engages with the cam gear , it will rotate slightly. You want the rotor to end up lined up with the number one spark plg wire position on the distributer cap. If the car doesn't fire and you are sure you have power to the distributer, then you will need to pull the distributer out and turn the rotor 180 degrees and reinstall. The motor should then fire.
May 12, 2011 | Chrysler Conquest Cars & Trucks
How can you distribute (x+7)(x-7) on texas instrument calculator?
Well, you can't directly distribute it on the TI-84 because the calculator plugs in a number for x. If you know how to distribute it in long hand though, you can just use the calculator for any math you need help with. Or you could plug in the number you want for x by pressing that number, sto>, x. You can do problems like that long hand in the following way. If you were given (x+a)(x-b) you first do x(x-b) and get x^2 -bx, then a(x-b) and get ax-ab, then add those two answers together, giving you x^2-bx+ax-ab and then x^2+(a-b)x-ab. So your problem for example would distribute to (spoiler warning) x^2 -7x+7x-49 and then x^2 - 49 because the - and + sevens cancel. I hope this has, helped, just let me know if you need anything further.
May 09, 2011 | Texas Instruments TI-84 Plus Calculator
I mixed the distributor cables up,so i need the order to correctly connect
If the wires are still in the distributer, AND, if you have a stock intake manifold, the firing order is on the manifold. If it's a V-8, the number 1, 3, 5, & 7 plugs are on the drivers side of the engine. The number 2, 4, 6, & 8 plugs are on the passenger side. The number 1 plug wire can be located by looking at the distributer from the front of the engine and visually looking between the distributer and the number 1 plug. Visualize the distributer as a clock. The number one position should be located between 4 and 5 o'clock and should have the longest wire of those on that side of the distributer.
If the wires have been pulled from the distributer, then, then, remove the rotor cap, turn the engine over slowly until the rotor is pointing to the number 1 plug. Using the firing order on the intake manifold, starting with number 1, replace the wires going clockwise around the distributer.
Apr 09, 2011 | Chevrolet Chevy Cars & Trucks
Car dies or loses power while driving. Changed out, spark plugs, wires, battery, fuel pump, fuel filter, distributer cap. Not sure what else to check.
My 1995 died after rain storms and high humidity,my mechanic changed the distribution cap, the wires and ignition and its find now 181,000 and still going strong.
Jul 28, 2008 | Plymouth Voyager Cars & Trucks
Interactive Health Refurbished Htt 10crp / Ht 120 Robotic Human Touch Massage Chair with Human Touch Technology Logo
Top Interactive Health Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Interactive Health Health and Beauty Expert? Answer questions, earn points and help others
