Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whilrpool Refrigerator Model ed27dq water filter location
4 Suggested Answers
Maytag317
  • 1136 Answers
SOURCE: location ofwater filter(s) whirlpool modeled22dq
Hi, The filter is located behind the kickplate. You can see the handle for the filter in the kick plate. I believe you turn the filter handle Counter clock wise to remove it. It will tke a little bit of force. Yes this filters the water in the door.
Let me know If I canassist you further. Thanks
Vic
Posted on May 17, 2009
SOURCE: Change water filter on Whirlpool side by side Refrigerator
Jill, download the instructions here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202205958.pdf.
Posted on Jun 07, 2009
  • 2468 Answers
SOURCE: Mod ED27DQ side by side refrigerator-Freezer works
check the damper door located between the freezer and refrigerator compartment,if it is iced up it cannot open up and let cold air into refrigerator compartment from the freezer compartment,deice this part and then adjust the refrigerators cold control and see that the door opens and closes with controls adjustment
Posted on Feb 03, 2010
I have a Kenmore side-by-side ultrafresh refrigerator model # 5255210, serial# SM0649567. I cannot find the water filter. Where is the water filter located on this refrigerator ?
Owning 1 of these refrigerators will require you to replace the water filter from time to time, in order to keep the water fresh and the refrigerator running efficiently. Kenmore refrigerators are made by Amana, Frigidaire, GE, LG, and Whirlpool, so it is important to find out which manufacturer made your Kenmore refrigerator, in order to make sure you order the right part. Kenmore refrigerators use filters that are located in the bottom, front panel of the refrigerator. Details can be found on WiKi how to change a water filter on a Kenmore Refrigerator.
May 24, 2016 | Kenmore Refrigerators
Jenn-Air Refrigerator JS42SEDBDA Model 12606032GJ was in house when I brought house. No user manual. Does this model have a water filter? The refrigerator has the words water filter,and underneath that...
Remove the compressor cover to locate the filter.
www.appliancepartspros.com has the filter.
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-refrigerator-water-filter--puri-clean--item-number-ap4343710.aspx
Aug 20, 2011 | Jenn-Air JS42SEDBDA Stainless Steel Side...
I have a GD22DQ model side by side whirlpool gold refrigerator. we have looked through the manual and we cannot find were to put the water filter. the manual shows a dial at the bottom of the fridge but...
Hello Dollar1392,
I understand that you can not locate the water filter for your unit. If you have a water filter in your unit it will be located in one of two locations at the bottom of the unit in the grille or in the top of the refrigerator section on the right side in the rear corner. If the filter is not located at one of these locations then there is no filter on your unit. You will need to put an in-line filter in your water supply line.
Thank you for choosing FixYa.com if you have any further questions please post back to the thread.
Justin
Apr 23, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Our Whilrpool Imperial Series ED22LF side-by-side refrigerator has developed a leak (drip) from the in-door water dispenser. The refrigerator is about 10 years old. Can this leak be fixed? If so, can you...
Have you tried to change the remove the water filter? (It needs to be changed every 6-months.)
I find that when I change the water filter on my fridge, it takes a few times using the water dispenser on the door before it totally stops running. But it does stop. In the interim, place a couple folded paper towels under the spigot to catch overflow. When you see that the towels are dry, you are in business.
Put a post-it note in your fridge with the date of the last time you changed your water filter, the model and serial number of our fridge. When its time to replace, either bring the post-it to the applicance store's parts counter and/or input the data into your online order. Change out every six months.
Secondly, if the above does not apply/work, then go to the yellow pages in your area and look up Appliances...small applicance repairs and parts. Contact the vendor and pose your question about parts, repairs degree of difficulty to repair ( like your spouse).
Jan 27, 2011 | Refrigerators
Mod ED27DQ side by side refrigerator-Freezer works fine-refrigerator will not cool below 45 degrees
Jan 31, 2010 | Whirlpool Refrigerators
Water dispenser
My filter is located on the inside of the refrigerator in the top right corner. It twists off and is easy to replace.
Jan 21, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Trying to located the filter because the water in the door has a nasty taste. The model number is RS22AOXMQ00
I could not find your model # but did find This one
RS22AQXMQ00. you might have made a mistake.
If your refrigerator is this model #. I don't belive this model has a filter in the refrigerator. you might have one from the water supply to the refrigerator.
If you don't find one you might want to check the water reservior located in the fresh food side, behind the crispers at the bottom. It should be a coiled water tube. If it looks green inside or nasty then that is your problem.
Jan 13, 2010 | Refrigerators
Water filter
I don't think this model has a filter, I checked under the kickplate, no filter there.
Mar 26, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerator Model FR23W3aw0 Frigidaire
cant bring up that model # there in the refrigertor side top right... in rouund like the fliter, plastic case most filters usually just turn counter clockwise to come off
Sep 03, 2007 | Sub-Zero 680 / S
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
267 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
